Load Bearing Walls
Old 06-21-2006, 04:47 PM   #1
EDT's Avatar
Trade: Trim Carpentry
Load Bearing Walls
Hello framers, Im a finish carpenter and have no structural experience. Im in need of some help regarding a side job Im thinking about doing. The customer wants to remove a 14' load bearing wall and support it with a beam. I know how to do this but what size beam should i choose? I was thinking a 4x10. Is that sufficient enough?
Also, he wants a pony wall with a half door installed in place of the load bearing wall. It wont have any shear strength because he wants to use plexi glass instead of sheetrock. Im wondering how Im going to support the half wall which will be in the middle of the room.? Without any support from bottom plate to top plate I dont see it being very stable unless I "L" off each side.
EDT is offline
Old 06-21-2006, 05:07 PM   #2
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Re: Load Bearing Walls
Regardless of how you decide to do it, you better make sure your insurance covers dealing with load bearing walls, I know mine doesn't.
Mike Finley is offline
Old 06-21-2006, 05:22 PM   #3
fettycan's Avatar
Trade: roofer
14' is a lot mabe a steel flinch plate or some LVLs it depends on the style like a header for a cased opening or flush with ceiling
fettycan is offline
Old 06-21-2006, 07:20 PM   #4
joasis's Avatar
I will say this carefully, but it isn't as simple as saying a 14 ft load bearing wall replaced by a beam. How much load? What is above it? I have seen where homes were added on, and someone decided to remove a load bearing wall, that used to be an exterior load bearing wall, with serious results. It is even worse when a wall is removed, and they the "remover" finds out it holds up more then the wall itself.
Before you can determine a beam size, you need to know exactly what you are supporting, and then plan bracing in to support the weight while you build the beam in and secure it.
The pony wall isn't a big deal, there are several acceptable ways to attach it to prevent movement.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
joasis is online now
6X6 Load Bearing Cap apex1 Construction 3 01-07-2009 08:26 PM
Load bearing wall or not??? BMAN Remodeling 26 07-28-2008 07:16 PM
Framing a header after removing a load bearing wall tnt Framing 2 12-13-2006 10:17 PM
?? removing a load bearing wall bamaboy Framing 9 11-01-2006 04:30 PM
Load bearing wall pitterpat Framing 11 12-12-2005 06:11 PM
