Trade: HandyWOMAN
Load Bearing Wall
Would the wall above the tub be considered a load bearing wall in this picture?
Thanks,
Pat Harris A HandyWOMAN Service, LLC "Why call a handyman when you can call A HandyWOMAN? |
Re: Load Bearing Wall
Not likely, - - but to determine if an interior wall is load-bearing, - - determine it's location in the basement, - - and if there's a girder under it, - - it's load-bearing.
Load bearing walls 'carry' all the way down to 'footings'.
http://www.tr-built.com |
#3 | |
Trade: HandyWOMAN
Re: Load Bearing WallQuote:
You mean the louvered doors??, - - could be, - - again you'd have to check below. Any interior wall that's got a girder below it would be load-bearing, - - and all exterior walls are considered load bearing.
You want to take a look at whats above the wall in question, also. Is it open floor space, another bathroom, etc... Also I noticed what appears to be a vent in the ceiling, does that mean that there are no exterior walls.
It appears from the picture that the wall above the bath tub is not inline with the wall with the door in it, is that the case? There are 3 different scenario's in my mind, if you were to tear it out you might find a beam there which is needed for supporting a load above, or you might find a beam which is there just for the open span but not needed to support anything above, or you might just find no beam and just 2"x 4" framing for attaching the wall material. |
Custom Builder
Find out where the rafters seat in the attic.
Bob
Bob |
#7 | |
Trade: HandyWOMAN
You are correct that the the wall above the tub is not inline with the wall where with the door (bath closet).
Trade: architect
The second floor joists are held up by a beam or a wall or both near the center of the house. These supports are usually parallel to the exterior long walls of the house and support joists that are perpendicular to supports but sometimes the framing is is more complex. You need to determine exactly how the joists are held up and if there are any irregularities in the framing like stairs, chases, etc. that interrupt the joist pattern and determine how those are supported, in order to eliminate this wall as a bearing wall. The basement and attic contain the best clues. Any one familiar with house framing would be able to figure it out so you need not guess; get some help.
Custom Builder
What are you trying to do Pat? Open a second side to the tub/shower?
Bob
Bob |
Trade: Project Superintendent
And they are not a bearing wall, they just lower the lid in the tub area for looks.
Trade: remodeling and new construction
I would about stake my life on it not carrying weight. Like Edos says looks like a soffitt. I would suggest having someone with the proper knowledge take a look.
Trade: remodeling/specializing in kitchen & baths
those short walls are really good at trapping steam so it struggles trying to get to the fan! check tha attic to see if the ceiling joist break on it but very doubtful. do a quick check of the ceiling height inside/outside the shower to make sure they didn't drop it a few inches for a trap or hvac. thats easy to miss.
| 6X6 Load Bearing Cap | apex1 | Construction | 3 | 01-07-2009 08:26 PM |
| Load bearing wall or not??? | BMAN | Remodeling | 26 | 07-28-2008 07:16 PM |
| Framing a header after removing a load bearing wall | tnt | Framing | 2 | 12-13-2006 10:17 PM |
| ?? removing a load bearing wall | bamaboy | Framing | 9 | 11-01-2006 04:30 PM |
| Load bearing walls | EDT | Framing | 3 | 06-21-2006 07:20 PM |
