Load Bearing Wall
Old 08-22-2007, 05:21 PM   #1
tsicby's Avatar
Trade: designer
Load Bearing Wall
We created a 5' opening to a load bearing wall in a residential house on a concrete slab foundation using a double 2x6 header and have noticed a few wall cracks coming out 4 weeks later on adjoining walls that seem to be "active" (we fix them and they open back up).
How long can it take for everything to settle? Should I get an engineer to look at it?
tsicby is offline
Old 08-22-2007, 05:40 PM   #2
RYANINMICHIGAN's Avatar
Trade: builder of stuff, real nice stuff
Re: Load Bearing Wall
2X6 Would not fly here...
RYANINMICHIGAN is offline
Old 08-22-2007, 05:56 PM   #3
Builder/Remodeler
ChrWright's Avatar
Trade: Builder/Remodeler
Send a message via Skype™ to ChrWright
2x6 sounds too small to me, too.... Two story house? What's the load factor on this wall section (size & span of floor members above, roof load, etc.)
I would have at least talked to my lumber yard to get the beam properly sized.
Where are the cracks? How did you seam the drywall? That can also affect cracks over time on load bearing openings.
I'd be careful of damage to what's above as well...If there are baths up there... with tile... you could be in store for a lot more damage long term--especially if there's a bath tub... I've installed whirlpools that will hold upwards of 100 gallons of water=800+ lbs=cracks & damage if not properly supported.
Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50
www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling
Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here
ChrWright is offline
Old 08-22-2007, 06:06 PM   #4
Thom
thom's Avatar
You need to do the load calcs just like these guys said. Then, check the slab. You've added a concentrated load. Was the slab thickened enough to support the additional load, is the slab sinking/cracking? Is the headder deflecting? Loading is one cause of cracking. There are others.
thom is online now
Old 08-22-2007, 08:46 PM   #5
Priced In
JustaFramer's Avatar
Trade: Exiled For Life
should you get a engineer. Anytime you do something structural a engineer should be used. Since for one you used a double 2x6 to begin with. a double 2x6 doesn't even hold a candle to a actually 4x6. If you are using this dimension for head height then you should be looking at a PSL or a glu-lam.
JustaFramer is offline
Old 08-22-2007, 08:58 PM   #6
georgia dawg's Avatar
Trade: general contractor - SFR
Hardly any code allows double 2x6s to span that distance. Also, remember code is the minimum requirement. Build better than code.
Example:
Only supported scenario under IRC for doubled up 2x6 headers would be max. 5'5' span on an exterior bearing wall supporting only a roof and ceiling (no other floors) with building width no more than 20 ft. and a 30lb snow load.
No other scenario comes close. You can forget any interior load bearing span of this size meeting code or anything with another floor above it. see IRC 2006 tables 502.5(1) and 502.5(2) for reference. In most jurisdictions, if it's in the code book, you don't need it engineered. Just look it up.
"How much per sq.ft? Well.. gimme $1K and I can build a shed. Gimme $1M and I can build the same size shed with gold plating and encrusted diamonds."
georgia dawg is offline
Load bearing wall or not??? BMAN Remodeling 26 07-28-2008 07:16 PM
Framing a header after removing a load bearing wall tnt Framing 2 12-13-2006 10:17 PM
?? removing a load bearing wall bamaboy Framing 9 11-01-2006 04:30 PM
Load bearing walls EDT Framing 3 06-21-2006 07:20 PM
Load bearing wall pitterpat Framing 11 12-12-2005 06:11 PM
