Trade: GC/Developer
Laser Level For Top Plates On Partition Walls?
Last year I upgraded from two plumb bobs and a chaulk line to a robotoolz rotalry laser level which has two lasers. The one is a self leveling and the other is a self plumbing.
I fell in love with the laser, you mark out the two end points of the bottom plate, fire it up and it gives you a rotary plumb line for you to use to attach the top plate. I want to get another laser for the crew to do layout, however this laser is about $400. I already have a good rotary laser for them to check level so I was wondering what other people are using to do laser lines for layout of top and bottom plates? |
Trade: Stuff
Re: Laser Level For Top Plates On Partition Walls?
I use the PLS5x ($400).
http://www.yorksurvey.co.uk/products...r/topcopls.htm It shoots a "laser point" in five directions and is self leveling. Using it instead of a plumb bob is great. Unfortunately, using it to layout 90 degree angles is a little tedious, but it is very accurate (1/8" off at 100'). Luckily, in October PLS came out with a self leveling, laser square (PLS90E) that will do the same job by projecting two "laser lines" on the ground at 90 degrees (1/8" off at 100') for about $400. http://www.engineersupply.com/Produc...ES1697&affid=7 If you don't need that kind of accuracy, Stanley makes a similar product with an accuracy of 1/4" off at 60' for about $120. http://www.engineersupply.com/Stanle...ax-77-198.aspx Chris |
Man, am I behind the times! I do use a rotary laser for site levels, but we frame the old fashioned way...I need to learn some new technology, for sure.
| Block Walls | DaHammer | Masonry | 29 | 03-06-2009 07:11 PM |
| I Need Some Laser Level Advice | needthingsdone? | Tools & Equipment | 13 | 11-11-2006 11:10 PM |
| laser level suggestions | dirt diggler | Excavation & Site Work | 8 | 07-05-2006 09:33 PM |
| Laser Level | reveivl | Tools & Equipment | 2 | 03-02-2006 01:18 PM |
| Bridging for above grade Concrete Walls | ETHICS05 | Construction | 1 | 11-21-2005 12:43 PM |
