Trade: general contractor - SFR
A Landing Or A Stair?
A stairway into the basement terminates at the bottom on a 38"x38" landing that sits about 2" above the concrete floor. The landing will eventually transition to a finished basement floor when the basement is finished at a later date. The local inspector says the landing is a stair and either the entire stairway needs to be redone to a 3/8" max riser variance or the entire basement floor has to be finished at 2". We use IRC, here. I think it's fine as is. I'm debating whether to appeal or not.
Any thoughts? |
Chief Toilet Mover
Trade: Bathroom Remodeling
Re: A Landing Or A Stair?
Put in a ramp from the "landing" to the basement floor and tell him to inspect that.
As far as I am concerned, - - he is correct.
A landing is just a 'wide step' . . . On what grounds would you argue it ?? |
Is it a small floor, or a wide step?
#5 | |
Re: A Landing Or A Stair?Quote:
Funny, but you can either lament now and labor later, - - or just labor now . . . |
So true. As the saying goes, "The inspectors are always right, even when they're wrong." Grin and bear it, or try to make a point and get on the inspectors s*** list. Easy choice if I plan to build in this county again.
General Contractor
How high is the final floor going to be?
-Robert F |
#8 | |
But I also think it's also best to play it safe with the 'liability' factors these days, also. Anybody ever takes a fall, - - it's YOU who's REALLY 'goin down'!! Last edited by Tom R; 07-08-2006 at 06:36 PM. |
The homeowner wanted 3/4" thick hardwood over 1" thick p.t. sleepers over poly for 1 3/4" total. We could even use 1.5 thick p.t. sleepers if we have to. The inspector says he allows up to 3/4" max for various floor thicknesses.
Maybe tell the homeowner you'll give him a $1000 discount if he has you do his floor now
Moderator
Well, the inspector is going to have the be the happy one, but think on this for a sec... does the inspector know that this is the first phase of a multi-phase project, and that the flooring will be done at a later time?
If so, can the work to level up to the "max 3/4" floor variance be handled on that phase of the project? Doing it now will address his issue for the unfinished floor but actually recreates it for the finished floor. |
| Stair Jig | RISENRUN | Tools & Equipment | 7 | 02-08-2010 08:30 PM |
| Stair Designer | hatchet | Carpentry | 10 | 01-18-2009 08:14 AM |
| Turning a staircase 90 degress at the landing | bujaly | General Discussion | 6 | 05-14-2007 10:12 AM |
| Light Switch at Landing? | thom | Electrical | 22 | 04-01-2007 11:10 PM |
| OSB hangerboard for stair stringer? | Spencer | Carpentry | 26 | 04-05-2006 07:58 AM |
