08-23-2009, 09:36 PM
#1
Trade:
General contractor
Lam beam question
I have a load bearing wall that I am eliminating and putting in a lam beam. My question is, what is the best way to tie into the existing walls on either side of the wall we are dropping. I am just curious as to the best way to tie the lam beam into the other walls to provide a solid structural tie in. The beam is only a 10' section of wall that we are dropping. what would be better for this application a 2x10 or a 2x12 lam beam ? Thanks for in advance for your help
08-23-2009, 09:38 PM
#2
Trade:
Framing
08-23-2009, 09:47 PM
#3
Trade:
General contractor
any thoughts guys ?
08-23-2009, 09:52 PM
#4
Home Depot aisle walker
Trade:
home remodeling
Originally Posted by brian1780
any thoughts guys ?
If you havent figured out the load or dont have an engineer to figure it out go with a steel I-beam. Better safe then sorry. I like steel, much stronger, cheaper and less flex.
The Following User Says Thank You to willworkforbeer For This Useful Post:
08-23-2009, 09:58 PM
#5
demo master
Trade:
Remodeling General Contractor
What do the stamped engineers plans say, the ones that were submitted to building dept?
08-23-2009, 10:08 PM
#6
Trade:
home remodeling
Originally Posted by kevjob
What do they stamped engineers plans say, the ones that were submitted to building dept?
I dont think they say, because I dont think they exist
08-23-2009, 10:50 PM
#7
Trade:
Sure, what you got?
I am not sure I have an answer but, I do have a question.
How much a sq/ft for installing slate?
Originally Posted by Gus Dering
It may be just a gateway tool to the hard stuff. Be careful
08-23-2009, 11:11 PM
#8
Trade:
home remodeling
Depends on how guud you want it installed. I can do it for $2 ft if you dont mind a slight unevenness and a little grout displacement.
08-24-2009, 07:58 AM
#9
Pompass Ass
Trade:
Certified Building and Certified A/C Contractor
tree fiddy
08-24-2009, 07:59 AM
#10
Pompass Ass
Trade:
any thoughts guys ?
I think you should hire a licensed general contractor who knows what they are doing and have a P.E. figure the loads, get the plans sealed and pull a permit.
08-24-2009, 01:45 PM
#11
Trade:
Carpentry & Remodeling
Any "GC" should know how to post up a beam in a wall. Do you know what jack studs are
Do what you would do, as if i won't Do anything after you Did It!
08-24-2009, 01:48 PM
#12
Trade:
Is" xxxxxxxxxxxxxxx" on the east or west coast?
08-24-2009, 02:04 PM
#13
Plausible Deniability
Trade:
General Contractor
How do you pronounce that
e-xxxxxxxxxxx-S
"The problem with socialism is that eventually you run out of other people's money."
08-24-2009, 02:06 PM
#14
Trade:
General Contractor
We sometimes call'em trimmers on the left coast.
08-24-2009, 05:16 PM
#15
Trade:
Tru dat,.. i hear that out here too sometimes.
08-24-2009, 05:21 PM
#16
Trade:
Are the "existing" walls part of the wall you are removing, and in line with it on either side? if so, treat it like a header in a R.O. just use 3 or 4 jack(trimmer) studs.
08-24-2009, 05:25 PM
#17
Framer
Trade:
framing/remodeling
Simple answer to the last question.
A 2x12 beam is BETTER than a 2x10 beam
Always glad to help with the tough questions.
08-24-2009, 08:08 PM
#18
Trade:
General Contractor
What a lot of HO's err people forget to consider is not just the header size but also the footing size.You are taking weight that was spread out over a 10' span and now it is going to be bearing on two 6" or so areas.If the wall was holding up only ceiling joists it is not usually a problem.But anything else and you can have big trouble.
08-24-2009, 08:35 PM
#19
Trade:
Framing
I wonder if he put the slate in first?
| Thread Tools |
Search this Thread |
| Display Modes |
Rate This Thread |
Linear Mode
