Joist Cutouts
Old 11-12-2007, 08:38 PM   #1
rjordan392's Avatar
Joist Cutouts
I just advised a diy to get a professional opinion on the cutouts that were originally made to accomdate 4 inch soil pipe through what appears to be a 8 inch wide joist. I suspect the original work was not done to code. Now this diy cut some more out of the joist compromising the strength of the joist even further. Would anyone care to look at it and offer some sound advise?
The post is named "Removie Cast Iron Pipe" and is located on the Sister DIY forum at:
rjordan392 is offline
Old 11-12-2007, 08:55 PM   #2
Carpenter/fencing
nywoodwizard's Avatar
Re: Joist Cutouts
Many Years ago I did a job that sounds very similar,2x8 joist ,4 1/2 hole bored in it for the toilet waste. With a giant wirlpool and a ton of mud and tile going to sit on it,it had to be fixed So we created a chase specifically for it. Part of this home was on a slab and couldn't break up the floor,there was a new radiant heat system just installed so bringing the waste up anywhere else wasn't going to work.
Learning without thought is labor lost; thought without learning is perilous.
nywoodwizard is offline
Thru hole for joist & 2x2 in column Danno6102 Decks & Fencing 3 10-18-2007 03:50 PM
Floor Joist dante1 Flooring 0 02-14-2007 06:02 PM
3/4 Hardwood laid parallel to joist? pburchett Flooring 9 10-08-2006 11:37 AM
Joist Jaw Woodcrafter74 Tools & Equipment 8 08-04-2006 08:57 AM
HELP! HELP! Joist Hangers allsolutions Construction 19 05-27-2006 11:08 PM
