Trade: Kitchen & Bath
Joints In Top Plates
I have always cut my top plates so that joints are split on a stud on all walls, including double top plated walls.
Three times recently I have had occasion to be looking at other companies' framing and see they split their top plates willy nilly. What do you guys do? |
Trailer park boy
Re: Joints In Top Plates
I always split them on studs, with as big a stagger as possible for the double
"Industry without art is brutality"
#3 | |
Re: Joints In Top PlatesQuote:
According to code...you don't even need a top plate...
R602.3.2 The exception Bearing Studs come into play @ R602.3.3 http://www.richmond.ky.us/codes/Form...nstruction.pdf |
#5 | |
Trade: general
We split 1 stud on each side with a 1/4 so separation, so we can suck the joints together. Pretty sure most codes are 4 ft. from partitions and corners . Where you can do this.
I think it's mostly about quality and personal preference, but I split all plates on a stud, even the second on top...just makes me feel warm and fuzzy inside.
#7 | |
Trade: Framing Contractor
If you're following IRC Chapter 6 R602.3.2 Top Plate. "End joints in top plates shall be offset at least 24." "Joints in plates need not occur over studs."
Joe Carola |
Trade: General
Makes it a little easier on the other trades who might be drilling up. No chance of hitting nails.
Plumber / Carpenter
As a plumber I have respect for the other trades. When I frame EVERY lock plate is broke on a joist and EVERY lock plate is nailed over a stud so the others drilling do not hit a nail. Want to piss me off? Nail between the studs. I will find you and bitch like a woman!
Trade: Carpentry / Fencing / Decks
I always break the top plate over a stud. The main reason I have done this is to keep nails out of the other trades way.
www.ParkerFenceandDeck.com |
#11 | |
You beat me to it.
I was called on it once under the UBC. Never looked it up to see if the inspector was giving me ****. From that point on I did it always just out of habit and not wanting to take the chance I get another inspector with his specific interpretation of the code, know what I mean?
#13 | |
Got the hint. Also, no dropping things on the floor when the plumber has his head in between the floor joists below you. That really seems to piss 'em off good.
#14 | |
Super B
#15 | |
Trade: Remodle and Framing
Since the beginning of time , you always connect wood to wood, anything else is just not right.Any transfer of loads needs to be on bering points? yes or no?
#16 | ||
I'll change framing according to new codes as the years go by, but I won't change the way I do top plates until the code changes, or for some crazy reason I think that there's something wrong with landing joints off studs, which will never happen. Quote:
I nail all plates above the studs. The only nails that get nailed in between a stud will be at a joint.
Joe Carola |
It is nice to keep them nails out of everyone's way at 50 bucks a bit.
#18 |
Trade: Build, Remodel, Roofing, Siding etc...
I always order 10' lumber for plates. that way i can make nice easy 10' sections to stand at a time. i break all three plates every ten feet. It makes the job very easy, especially when all but one employee call out sick. you all should try it!
#19 |
Re: Joints In Top Plates |
| Azek butt joints holding up? | LeonardDB | Finish Carpentry | 39 | 11-28-2009 08:30 PM |
| Control/Movement joints | Cache | Flooring | 6 | 11-02-2008 01:10 AM |
| control joints in concrete steps | basinbuilders | Concrete & Paving | 3 | 10-16-2008 09:42 PM |
| Inaccessible wireway, plumbing joints, etc. | Magnettica | Electrical Picture Post | 9 | 09-15-2008 08:29 AM |
| Hardwood Floor Pattern and End Joints | 4yanx | Flooring | 25 | 07-29-2007 07:14 AM |
