Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Carpentry > Framing
Old 09-04-2009, 02:00 PM   #1
Trade: Spec GC
Irregular hip, unbacked
Irregular hip, say major (lesser) pitch is A:12, minor pitch is B:12, and hip member is C width.
The hip member will not be backed, and thus the roof planes are to bear on the arrises.
The center of that hip member will fall on a line that is parallel to the hip plan line. How is that offset calculated, and to which side, major or minor, does it shift?
Edit: I am attaching a little visualizer, a .jpeg screencap of a Sketchup model, showing an unbacked 2x4 hip having an 8:12 major and 10:12 minor. You can see the two arrises in plane, and the angle of the shot clearly shows that the member is not centered under the hip line.
UpNorth is offline   Reply With Quote
Old 09-04-2009, 03:24 PM   #2
Trade: Framing and General Construction
you are overthinking this. See the hip and valley thread. dont think of it as shifting... think like this. The 10 side will plane with the 10/12 rafters and the 12 side will plane with the 12 rafters. the edge of the hip planes so dont worry about the center of the hip itself. Just keep the edge right and there is only one place it can be in... the right spot
cbfx3 is offline   Reply With Quote
Old 09-04-2009, 05:23 PM   #3
Trade: General contractor
I do not know of a formula to calculate the position of the hip, which I think is what you are asking.
When doing a bastard hip I always made an "L" shaped template out of plywood the depth of the overhang. I put a nail in the outside edge of the template where the edge of the hip would be. Then hold the template on the corner with a string going from the nail to the top of the hip location. The line falls over the plate where the hip needs to be located. It always lands on the steeper side of the roof.
Bill
BillD is offline   Reply With Quote
Old 09-04-2009, 05:25 PM   #4
This is as High Tech as my math expertise gets. I hope you get it, sorry if you don’t. ( let me know…)
(Sqr. rt. (A^+B^) /A ) x C = one sides off the corner layout (offset for B)
(Sqr. rt. (A^+B^) /B ) x C = the other sides off the corner layout (offset for A)
What this does is scales down a triangle at the proportions of the split pitches with the hypotenuse of the triangle equal to the Hip’s thickness (C). The dimensions solved are the right angle legs of the scaled triangle. I usually solve for these when doing my roof calc because I need this info to help calculate the longest jacks, I step them down from there. (I believe the formulas above are the ones I am using in my roof calculator spreadsheet.)
*The formulas will apply to the reciprocal roofs layout as shown. IOW, if you are dividing by A then that is for the layout on the B wall, and vice versa. (/B for A) *(I just use the rule that the larger leg is always for the lesser pitch)
This is easier to do with the CM Calculator;
Enter Pitch A as a Run, enter pitch B as a Rise, press Diag, (save settings, Stor pitch), Enter the hips thickness ass the Diag, press the Rise and Run keys for your dimensions.
Also, you can lay the hip out with a framing square as I described in the Hips and Valleys thread and just measure them.
Birch is offline   Reply With Quote
Old 09-05-2009, 09:44 AM   #5
When I took the eyebrow class in Porland last January, Billy Dillon (Timber Framer-in caps because it is so cool) showed a way to figure out the hip shift.
Of course I can't remember it, but I will try this weekend. I'm attaching a picture that showed him drawing it. It took just a few seconds.
http://picasaweb.google.com/TimothyU...eat=directlink
Timuhler is offline   Reply With Quote
The Following User Says Thank You to Timuhler For This Useful Post:
Birch (09-05-2009)
Old 09-05-2009, 11:43 AM   #6
Tim,
Thanks for your post.
While working up an edit overlay on you photo I realized I made a mistake in my Offset formulas in my previous post. Sorry for any confusion, I got my numerators and denominators reversed.
They should read like this;
A / (Sqr. rt. (A^+B^)) x C = one side’s off the corner layout (offset for B)
B / (Sqr. rt. (A^+B^)) x C = the other side’s off the corner layout (offset for A)
Old 09-05-2009, 12:39 PM   #7
Originally Posted by Birch View Post
Tim,
B /(Sqr. rt. (A^+B^)) x C = the other side’s off the corner layout (offset for A)
Tim, UpNorth, all,
I edited over Tim’s photo of Billy Dillon's drawing to show the geometry of the proportionately placed Irregular Hip, unbacked. Billy’s drawing did not line up perfect with my edits and I did not try to make any perspective corrections. The concept is shown and I hope it is understandable.
Since the lines at the shoulders (arrises ?) can be visualized as the same length as the effective hip line (Center line, prior to cutting) the Hip can be simply calculated from the same effective run as an adjacent common, marked in a similar fashon as a common with the standard HAP, and cut using the plan view bevels.
Also, I gave Billy’s drawing some real proportions to work with, 4 and 8 pitches, since it appeared to be approximately a 1 by 2 rectangle.
Square hung facia on irregular hip roof? skinnyjimmy Framing 22 07-28-2009 01:15 AM
55 volts on both hot and neutral, what the heck!? karma_carpentry Electrical 32 02-28-2009 09:12 AM
Irregular tenn crab production rates.. ruskent Masonry 18 07-29-2007 08:41 PM
