#21 |
Trade: new construction/remodel
Re: Installing Sill Plate?
this one is out 1 1/2" over 8 ft in some areas.
#22 |
I have a different solution that might work. You could clamp some 2x4s to the side of the foundation and pour in a self-leveler like this one http://www.quikrete.com/ProductLines...nkGroutPro.asp
Mix it to a pourable consistency and pour it in. The trick would be having enough clamps. If it is just one run, then this would get you back to level really quickly and cleanly. |
| The Following User Says Thank You to Timuhler For This Useful Post: | Toolwh@#e (10-06-2009) |
#23 | |
Re: Installing Sill Plate?Quote:
I see what you are doing there and understand it. What do you think about having one of your guys rip down some 3-1/2" wide shingles and shimming that way instead of your white plate you have there? I'm sure you've thought about it and decided against it for some reason, I'm curious what that reason would be.
#24 |
Carpenter
FramerMan, the metal plates you see are the hangers they use to screw the membrane to the plastic clips that are in thefoam forms. Your right on with using shims to lift up the joist.
THConstruction |
#25 |
Trade: contractor
I'd be kickin a forman in the arse and finding a new one.
#26 |
Carpenter
The general contractor that started and did the foundation was let go and now works at wal-mart. we had to take all eighty foot of 2' floor trusses 16" o.c. off and start over. He was also 7" out of square. he tried to sheet it but that didnt work, layout wasnt backed off an 1 3/4" so the butt joints of the floor where magically floating with no joist under them.
THConstruction |
#27 |
Thanks Tim for the self leveler idea sounds like it would get me back going. Rained here today no work so I will look it over tommorw.
#28 |
Thanks for all the replies, I was down this morning and set up transit and shot all the corners and mid spans the one area we were talking about which is and inside corner was off 1 3/8" high and block ran down hill to outside corners approximatly 8ft in each direction. The mason said he would cut the top block down to level. The rest of the walls are with-in 5/8" at the worst point and one wall for stairs is low by 7/8" which I believe we will build up with mortor and lay sill in it to level. I have some pictures but dont have them downloaded yet. I will post later tonight. Thanks again
| Flat plate heat exchanger | genecarp | Plumbing | 2 | 11-24-2008 10:09 PM |
| Replacing a door sill | DaHammer | Carpentry | 11 | 10-06-2008 12:17 AM |
| Please help sill plate problems | Triple J | Framing | 15 | 05-02-2008 12:28 AM |
| water under sill plate question(garage) | landcrafter | Construction | 5 | 03-10-2008 09:55 PM |
| Framing Roof Joists for Addition when top Plate is not Level | personalt | Framing | 3 | 07-20-2007 06:52 AM |
