Trade: residential remodeling
Identifying Load Bearing Wall
In my experience usually a load bearing wall rests over the girder visible from the basement and the load bearing wall directly above the girder
However I am know in S. Carolina and just want to be sure how to identify a load bearing wall unable to get underneath of home, can I identify by how the trusses or rafters are resting viewing from the attic? Is there another way without climbing up into attic to inspect the framing? Client just wants to open the wall 6' to add additional passthru access so I really dont think there would be much of a threat even if it was load bearing. Although I need to be sure thats why Im asking Any suggestions! ![]() thanks guys Brian |
Trade: Squirrel Handler
Re: Identifying Load Bearing Wall
Look for the "load bearing wall" tag, if it doesn't have the tag (sometimes people remove them) knock it down, if the house doesn't collapse it probably wasn't load bearing, if the house collapses it was a load bearing wall.
If you have the plans for the house (or get them at the building dept., depending on age), that should tell you. If you have to go in the attic, basement or crawl space, then that's what you have to do. Sometimes walls that weren't supposed to be load bearing become load bearing because some hack did some work he shouldn't have, so the standard indicators such as headers, posts, beams and footing aren't always going to be there. .
Some people climb mountains. I take out the trash. But we both do it for the same reason. |
Re: Identifying Load Bearing Wall |
step as follows
#1 begin to cut one stud with sawzall #2 try to remove blade from cut after cut is half way through #3 if blade comes out easy, non load bearing #4 if blade gets stuck, wall is load bearing
Take a picture of your hardhat on top of your sneakers so you can know now what you might look like later if you happen to pick the wrong comedian to listen to . . .
Trade: Framer, Carpenter
If you dont know the answer to your question then hire a engineer or get sued. In your case I think its that simple. Other wise get a job on a framing crew work there for a few years. Then you should be able to tell, if not find another occupation.
No offense but it sounds like you are in over your head. If you are and you screw up. Thats another bad story home owners tell, to make other homeowners scarred of the little guy who really knows his $heot!!!
#7 | |
Re: Identifying Load Bearing WallQuote:
I know there are a lot of cute answers to wade through....now glean the advice.
Handle It!
Sniff real hard. The older it is, the harder to tell, but load bearing walls smell like crap. Hence the word "Load".
#9 | |
Restoration Crazy
Jason E Whipple, General Manager Historic House Restoration, Cincinnati, Ohio Facebook | Twitter |
Just had to give a quick reply, thanks guys for all the advice, gonna try the
old saw blade approach and see if it sticks!!!!!!!!!!!! worst case the walls come down,and all above, no need to worry though Hozea and his crew gave me a great price to rebuild the house if things dont work out, as long as they dont get deported!!! Gotta go, busy hacking away!!!!!!!!!!!!!!!!!!!! |
#11 | |
Restoration Crazy
Yes, spelling will be most important on pay day when you write the checks.
Oh wait, they don't take checks, do they!
Al Smith
Why of course you need a load bearing wall detector!!
framer
check a bearing wall with a sawsall? wtf.......
get out your ladder and crawl into the attic. i have seen many a bearing wall supports (studs) taken out and have no downword pressure in certain areas due to the other framing components keeping the weight off where the studs were gone. if your going to be in this trade you need to know what the heck your doing and not guess. |
framer
ya know i thought about that but then he said he would try that approach! i hope your right.
#18 | |
I'd rather be sailing...
Trade: Building Remodeling
Just to be sure. |
#19 | |
WRONG!!! I CANT BELIEVE YOU WOULD GIVE ADVICE LIKE THIS!!!! How could you have the audacity to even suggest something like this without telling the poor guy to ALWAYS WEAR SAFETY GLASSES!!!OMG!!! Does the O.P. smell like a home owner to any one else?
#20 |
General Contractor
Trade: General Building Contractor
It's threads like this one that give legitimate contractors trying to give people sound advice a bad name.
The OP said right off the bat that he can't get under the house. This is a huge problem. Before he does ANYTHING, he needs to determine what KIND of load-bearing wall it is. Is the wall supporting the framing above it (which everyone here seems to be assuming), or is the floor below hanging from the wall (reverse load-bearing suspension wall). Cut that wall in the wrong place, and that floor is likely to drop right down to the bottom of the crawl. Do whatever you need to to get under the house and determine what the uplift rating is on the floor to bottom plate connectors, Cut out a test pier and see what kind of upward rebound you get, then you can start dealing with the joists or trusses above the wall. I can't tell you how many of those suspension walls I've seen cut that shot up like a scalded cat and blew tiles right off the roof. Big trouble there.... |
| Load bearing wall or not??? | BMAN | Remodeling | 26 | 07-28-2008 07:16 PM |
| removing a none load bearing wall?? | samiam | Framing | 7 | 09-12-2007 08:33 AM |
| Load Bearing Wall | tsicby | Framing | 5 | 08-22-2007 08:58 PM |
| ?? removing a load bearing wall | bamaboy | Framing | 9 | 11-01-2006 04:30 PM |
| Load bearing wall | pitterpat | Framing | 11 | 12-12-2005 06:11 PM |
