EVIL GENIUS
I Need Help With This Question On Roof Framing
Im studying for my builders license and in the study guide I bought there is a question that had me thinking. I figured it out but I would like to know how the pros do it and if you would do it the same as me. The study guide didnt cover this at all but they have a question on it in the practice questions.
A 28x28 foot building has a 12" overhang. If the roof has a 4/12 pitch, what is the height of the roof rise at the heighest point? a. 3feet b. 4feet c. 5feet d. 6feet I came up with 5 feet. 28 divided by 2 =14+1=15, 15x4=60, 60divided by 12=5 Is this the only way to do it or do you guys have a fast way to figure it out? |
Recovering IT Guy
Trade: Handyman, Home Improvement, Kitchen & Bath Remodeling
Re: I Need Help With This Question On Roof Framing
You'll probably eventually memorize the roof pitches so you know that a 4/12 roof rises a third of a foot for every foot of run. Then when you get the 15 foot number, you just divide by 3.
Second Look home improvement www.SecondLookHome.com Handyman and Home Repair Specialist in Rhode Island RI Licensed Lead Safe Remodeler/Renovator, RI Registered & Insured Contractor |
Trade: student
You need to calculate the rise using the pathagorean theorem.
Formula of right triangle..a2+b2=c2 4feet- 8inch should be your rise for this roof slope with a run of 14. |
Trade: Framing
You can't really use the Pythagorean theorem, as you only know 1 side and 1 angle.
Just think of it.....you have to go over(run) of 15 feet....and it goes up 4" per every 1 foot. So, take the 15 x 4......= 60"......which is 5 foot. Now, that you have that 5 foot, you could figure out the last slope using Pythagorean theorem |
Super B
The run is 14' (28 divided by 2) 4' plus 4" for every additional foot. 4' 8" is the rise as Jeff stated.
Trade: Remodeling contractor
Bradracer is correct since the run is actually 15' not 14'.
That is the easiest way I've found also. 4/12 pitch means 4" of rise for every foot of run. That is 4" x 15 = 60" = 5'-0"
Back in Maine Dubbin' Around Doin' good stuff ...... |
Trade: Framing
Yep, that seems to be the easiest way...and you guys are forgetting the extra foot on each side.....either way, I suppose you are explaining how to do it.
For this particular situation, I know that 60" is correct....I actually drew it up, to make sure....haha |
#8 | |
Trade: Framing Contractor
Re: I Need Help With This Question On Roof FramingQuote:
The exact ridge height using run from outside of top plate: Run - 1/2 ridge thickness x pitch + H.A.P. cut (Height above Plate) = Ridge Height
Joe Carola Last edited by Joe Carola; 04-20-2007 at 06:20 PM. |
Super B
the extra foot is overhange, the span is 28' .
Trade: Framing
I agree, and disagree. I agree, in that I understand how they are......but I disagree in how "we" are finding them.....
If you are using some sort of triangle method(pyth) then you would have to go out to the furthest point(12" past the top plate). And, seens how they don't have more exact answers....I'm betting this is the way "they" want you do to it. |
#11 | |
Joe Carola |
Super B
4'8"
#13 | |
It's all about the Avatar
Trade: I have no face!
Trade: general contracting
56"
#15 | |
EVIL GENIUS
Joe, this is what really screwed me up, I was thinking the same way. I hate this question because of it. I decided the only way fo figure it would be like if they used a truss with the bottom chord extending over the top plate to for a sofit. |
Home Repair Specialist.co
Trade: carpentry
Never seen them count the over hang its from the plt
It's the question that is the problem. Everyone here can interpret in different ways.
#18 | ||
The problem is also in the answers they give to you.
Joe Carola |
#19 |
Not what I meant and it's obvious others are interpreting it differently so don't shake your head about it. The interpretation I'm talking about is where it STARTS, not ends.
If they made the question a little clearer, we wouldn't be arguing about this. It's dumb without the proper wording.
#20 | |
Joe Carola |
| Roof framing question | snuddenstang | Framing | 37 | 01-31-2010 07:19 PM |
| Tight Space Stucco Question - Undershot between roof sections | CGofMP | Construction | 3 | 03-24-2009 09:10 AM |
| Low Pitch Roof solutions | Fixer | Roofing | 4 | 02-18-2007 11:09 AM |
| Structurally Unstable Roof Pricing Question? | APC | Construction | 14 | 02-01-2007 09:14 AM |
| Do You Need A New Roof ??? | Perfect Roofing | Roofing | 0 | 02-10-2005 02:46 AM |
