I Joist Blocking
Old 10-21-2008, 10:45 PM   #1
airhose's Avatar
Trade: carpentry
I Joist Blocking
when framing with TGI's are you allowed to nail blocking into the sides of the flanges without filling in the web and useing hangers that wrap on top of the joists?
airhose is offline
Old 10-21-2008, 11:02 PM   #2
Joe Carola's Avatar
Trade: Framing Contractor
Re: I Joist Blocking
You don't need blocking when using I-joists unless it's spec'd on the plans.
Joe Carola
Joe Carola is offline
Old 10-21-2008, 11:16 PM   #3
RobertCDF's Avatar
Trade: Custom deck builder
We always nailed through the flange without filling the web unless specified on the prints.
RobertCDF is online now
Old 10-21-2008, 11:25 PM   #4
Joe Carola's Avatar
If you insist on using blocking follow TJI installtion guide and scroll down to where it says "Cantilever".
http://ilevel.com/literature/TJ-9001.pdf
Joe Carola
Old 10-21-2008, 11:42 PM   #5
Kgmz's Avatar
First that is a pretty vague question.
What kind of blocking are we talking about? Intermediate blocking for roll stiffness, cantilever blocking, intermediate blocking for walls above. etc. etc.
Now to answer the question. When you order a TJI package they are always engineered and have to be per code. So read and do what the engineered drawings tell you to do.
Kgmz is offline
Old 10-22-2008, 12:10 AM   #6
airhose's Avatar
Trade: carpentry
i mean for intermediate blocking just like u would for 2x joists also for if there was a wall above. mainly the question is can u nail into the sides of the flanges for any reason
airhose is offline
Old 10-22-2008, 12:16 AM   #7
Joe Carola's Avatar
Did you look at the link I sent you? It will answer all your questions especially since they are the I-joists you are using. What does your plans say?
Joe Carola
Old 10-22-2008, 12:28 AM   #8
airhose's Avatar
Trade: carpentry
yes joe i did veiw the page you posted that the whole reason i ask. i was told you shouldnt nail into the sides of the flanges. i didnt no if that meant for mid span things like block or at all. when i saw reinforcement being nailed into the flange i thought it might be because it was on the end.
also im not useing them i was just curious. just trying to learn.
airhose is offline
Old 11-06-2008, 12:03 AM   #9
"Your not done yet!!??"
Green Machine's Avatar
Trade: Framming/siding/millwork
Alot of time it will get speced out in the engineering to block between TJI's on all pony walls and/or interior walls (if you are running TJI's on the second floor). They will also have certain spots where 2 o3 blocks will need to be installed as well, but yes with your TJI package, you will recieve the engineering plans and it will tell you exactly what to do.
Green Machine is offline
Old 11-06-2008, 10:37 AM   #10
bee1706's Avatar
Trade: Remodle and Framing
Block the first three, to take the sway out, also block all bearing walls.
bee1706 is offline
Old 11-06-2008, 10:47 AM   #11
bee1706's Avatar
Problem with engineered I joist plans ,is they miss the toilets and tubs?
bee1706 is offline
Old 11-07-2008, 09:36 AM   #12
Kgmz's Avatar
And a good contractor you will catch that and adjust accordingly, even if it means adding more joists.
The worst problem I run in to is not the tub and toilets, but where the vent pipes go. There is always a joist centered under the wall, so I double the joists there and leave a space for the vent pipe. The engineers have had no problems with it, and you don't have the plumbers hacking it apart.
Kgmz is offline
Old 11-07-2008, 11:56 PM   #13
buckeyeso2's Avatar
Trade: carpentry
find a better engineer. My guy at least marks the plumbing on the layout, then it's up to me to confirm it.
buckeyeso2 is offline
Dryspace and mid-span blocking? Greg Di Decks & Fencing 4 09-17-2008 11:32 PM
??? Whats the best way to spread the news about your company? jmgrahamjr Marketing & Sales 21 06-24-2008 04:46 AM
Floor Joist Blocking barbie13607 Carpentry 10 10-09-2007 08:18 AM
3/4 Hardwood laid parallel to joist? pburchett Flooring 9 10-08-2006 11:37 AM
HELP! HELP! Joist Hangers allsolutions Construction 19 05-27-2006 11:08 PM
