How Would You Do These Stairs?
Old 04-24-2006, 06:15 PM   #1
GreenEggs's Avatar
Trade: General Contractor/Carpenter
Can I get some ideas how you would frame the 1st to 2nd story stairs? I want to mirror the 1st to basement stairs.
GreenEggs is offline
Old 04-24-2006, 06:21 PM   #2
jmic's Avatar
Re: How Would You Do These Stairs?
Green,
Whats the matter with the way you did the basement? The same way!
Joe
jmic is offline
Old 04-24-2006, 06:29 PM   #3
Mod / ArchiBuilder
Cole's Avatar
Originally Posted by jmic
Green,
I agree, what will change?
Just make sure to get your measurements right and go from there.
Can you be more specific?
Cole is online now
Old 04-24-2006, 06:31 PM   #4
GreenEggs's Avatar
Green,
Overhead is the problem between stairs I think. Am I wrong? I need 6'2". I need to assend as soon as I leave the 1st floor deck with the first floor stairs.
Old 04-24-2006, 06:35 PM   #5
Rambone's Avatar
Trade: Home Improvement Contractor
I HAD JUST DONE A CASE LIKE THIS AND I ROUNDED THE BOTTOM STEP ON THE FIRST FLOOR JUST TO SOFTEN IT A BIT SO IT DOES NOT HAVE ANY SHARP CONERS.
lOOKS GREAT!!
RAM
Rambone is offline
Old 04-24-2006, 06:37 PM   #6
GreenEggs's Avatar
Ok, so custom "stringers" nailed to the existing walls on the right side going up, and custom "stringers" supported by shortwalls under the left side going up? (I want the left side going up open).
Just want to get some ideas.
Thanks
Old 04-24-2006, 06:56 PM   #7
jmic's Avatar
Gee, I thought code was 6'-8" fpr head room
Joe
jmic is offline
Old 04-24-2006, 07:01 PM   #8
jmic's Avatar
Personally going from 1st floor to 2nd floor I'd have a stair co. make a nice finished set.
Joe
jmic is offline
Old 04-24-2006, 07:21 PM   #9
unlicensed hack
maj's Avatar
Trade: wood butcher
6'8" min. for headroom
Where does the headroom problem come into play?
I'm guessing the second story floor joists will be open to accomodate for the L-shaped stairs, correct?
Headroom shouldn't be a problem between the stairs if you mirror the lower set.
maj is offline
Old 04-24-2006, 08:30 PM   #10
GreenEggs's Avatar
Duh, your correct.
The first 5 1st floor-basement steps are series of "boxes" stack on top of each other. I cannot do that upstairs for headroom reasons. So custom "stringers" nailed to the existing walls on the right side going up, and custom "stringers" supported by shortwalls under the left side going up is my best bet right?
Old 04-24-2006, 10:32 PM   #11
Master Craftsman
Big Dave's Avatar
Trade: Rustic interior woodwork
I don't think that you are going to be able to build a mirror set to the bottom. What I would do is build a landing for the fourth step and run a short stringer from the floor to it and then from the landing to the second floor a set of stringers. You will need to support the landing on the inside corner of the L and nail the other two edges to the wall. I hope this is helpful.
Dave.
Do one thing at a time, do it well, then move on.
http://www.bigdaveswoodworks.com
Big Dave is offline
Old 04-25-2006, 10:28 PM   #12
CATSKINER's Avatar
Trade: FRAMING CONTACTOR
greeneggs: use 6'-10" in the rough for your headroom drywall & carpet will use up that 2" quikly
CATSKINER is offline
Old 04-25-2006, 10:45 PM   #13
CATSKINER's Avatar
greeneggs why is your front wall 9' & interior walls 8'? do you have roof right above the stairs?
Old 05-03-2006, 12:03 AM   #14
nailbanger138
nailbanger138's Avatar
Trade: Framing
Are you sure that the winding portion meets code? If I remember correctly the inside of the tread can be no less than 6".
nailbanger138 is offline
Old 05-03-2006, 07:23 AM   #15
GreenEggs's Avatar
They are 8"
Thanks for the help guys, maybe I will post a few more picture when it is done.
Complex Stairs wallmaxx Framing 4 07-09-2007 09:59 PM
Tiling Interior Stairs Rambo1224 Flooring 2 06-23-2007 12:32 PM
ceramic tile on stairs? TaylorBuilding Ceramic & Stone Tile 6 11-26-2006 02:23 PM
Concrete stairs summertime Masonry 20 11-04-2006 01:35 PM
Are uncut stringers old fashioned for stairs? atari Finish Carpentry 2 05-30-2006 01:59 PM
