How Much Weight Can A 8' 2x4 Stud Hold?
Old 05-23-2010, 03:25 PM   #1
Nailerconstruct's Avatar
Trade: Framer from head to toe!!!
Rewards Points: 45
Does anybody know where I can find specs or ratings on common construction material? lumber nails ect...
I was asked the other day whats the shear strength of a joist
hangar nail. I have no Idea and when I looked it up All I could find was a bunch of other questions about common construction material that for the most part were unanswered.
Nailerconstruct is offline
Old 05-23-2010, 03:59 PM   #2
topsail's trimcat
woodworkbykirk's Avatar
Rewards Points: 384
Re: How Much Weight Can A 8' 2x4 Stud Hold?
you can probably find that info the website for the american lumber association, or whatever their calling themselves these day, other wise ask a engineera at a mill
as for hangers and such, its probably on simpson strongtie's site or in their little catalogue near the hangers at the lumber yard
woodworkbykirk is offline
Old 05-23-2010, 05:07 PM   #3
Wood Butcher
bhock's Avatar
Trade: Remodels/Custom Cabinets/Granite Countertops
heres a link from USPs site with a shear value table http://www.uspconnectors.com/nails.shtml. I guess a guy would have to check every manufacture depending on whos joist hanger nail. I am sure they are close to the same though. As far as lumber have you checked the AWC website?
bhock is offline
Old 05-23-2010, 05:17 PM   #4
Rewards Points: 2,000
http://www.eng-tips.com/viewthread.cfm?qid=92870&page=1
"CSEllc (Structural)
27 May 04 0:47
Check out this Tech Note published by the WWPA. http://www.wwpa.org/pdf/TN1.pdf
According to this publication, assuming 2x4 DF-L STUD grade at 16"oc, with an 8 ft. wall height, and a 20 psf wind load. Than maximum allowable axial load on the wall is approximately 1100 pounds. "
neolitic is offline
Old 05-23-2010, 06:10 PM   #5
galla35's Avatar
Rewards Points: 250
27 May 04 0:47
No way is that a finger jointed stud
In the 80's we had Reagan in office, Bob Hope, and Johnny Cash. Now, we have President Obama, no hope and no cash
galla35 is offline
Old 05-23-2010, 06:53 PM   #6
Champion Thread Derailer
Jeff G's Avatar
Trade: Home Renovations
Rewards Points: 380
There are several manufactures who list their specific data and have such readily available to mail to you, or online, or through a distributor. But in regards to any mechanical connectors, keep in mind the moisture content of the wood effects the strength of the mechanical connection. For instance, bolts and nails are 10 to 20 percent weaker in wet wood than in seasoned lumber. The hardness and density of the wood also effect the strength of connections.
In regards to lumber, there are several things to take into consideration when calculating loads and/or stresses on various wood building components (i.e., what is the intended use, the species of lumber, the modulus of elasticity, moment of inertia, live + dead + wind + seismic loads, and the list goes on depending upon the intended use). But one should always consult your local building code since it will dictate many calculations required in your locale. However, you may find the following link to the public domain USDA Wood Handbook helpful.
http://www.fpl.fs.fed.us/documnts/fp.../fplgtr113.pdf
Jeff G is offline
Old 05-25-2010, 12:12 AM   #7
Rewards Points: 45
Thats exactly what I was looking for. These are all great links Thanks to everybody.
Old 05-27-2010, 06:14 PM   #8
Civil / Structural PE
Tim Garrison PE's Avatar
Trade: Software and business coaching
Rewards Points: 75
Here's a subject about which no one is more passionate than me.
What IS the shear strength of a joist hanger nail? The answer is so frigging complicated you wouldn't believe it. It depends on the nail diameter, embedment, species of wood, moisture content, gauge of metal, duration of applied load, and probably the brand of underwear you have on. In round numbers an 8d is good for about 100 lbs in shear and a 16d goes to about 150. But the bigger question is, how do you apply that information?
Regarding the load capacity of an 8' stud, again, the analysis is insanely complicated. You might find published data such as Neolitic found but I think your best bet is to check it with software. I discuss this very topic and actually show you how to design a stud in my latest book.
There's a lot of technical data out there but unless you understand the underlying concepts, your chances of misapplication are huge. My brother for example, a seasoned contractor with a masters degree and about 30 years under his belt, and who's been a student of the industry his whole life, still goofs basic structural issues.
I started out as a framer then went on to become an engineer. Along the way I realized that builders, designers, and code officials need someone who's been in their shoes to teach them what's really going on with a structure. That's precisely why I've written three books on the subject and teach seminars. If you're serious about learning I'd love to be the guy to teach you. Check me out by clicking on my name next to my avatar.
Tim Garrison PE is offline
Insulating a timber stud cavity wall - Query? AlanC Insulation 1 05-08-2010 11:58 PM
fiberock aqua tough board on 25 gage stud Miked55 Drywall 8 02-06-2010 10:50 AM
Lag Bolts in Metal Stud motomoto General Discussion 21 12-22-2009 09:11 AM
Vents to hold down membrane??? tekwrytr Roofing 9 05-27-2009 07:44 AM
Jack stud question billderboots Framing 45 12-31-2008 06:13 PM
