View Poll Results: Do you use bridging with conventional lumber? If so, what type?
No, I don't use bridging. 5 20.83%
I use metal tension strap. 0 0%
I use metal drive in type. 3 12.50%
I use solid blocking. 7 29.17%
I use wood X-bridging. 9 37.50%
Voters: 24. You may not vote on this poll
How Many Are Using Some Type Of Bridging With Conventional Lumber?
Old 11-15-2009, 08:08 AM   #1
KemoSabe
loneframer's Avatar
After seing the interest in "Fun with wood X-bridging", I thought a poll was in order. Thanks in advance for your responses.
loneframer is offline
Old 11-15-2009, 08:38 AM   #2
Joe Carola's Avatar
Trade: Framing Contractor
Re: How Many Are Using Some Type Of Bridging With Conventional Lumber?
Are you talking both 2x framing and using I-joists? That would make a difference on how I answer the poll for me because I don't use any type of bridging for I-joists. For 2x framing I use bridging with anything over 8'.
The few times for I-joists I used tension straps. Other than that, I don't use any type of bridging/straps or blocks for I-joists.
Joe Carola
Joe Carola is offline
Old 11-15-2009, 08:41 AM   #3
KemoSabe
loneframer's Avatar
Fixed it for ya.
Old 11-15-2009, 09:08 AM   #4
Framer53's Avatar
Trade: Framing
One other possibility you forgot.
I use what is specced on the plans!
Framer53 is offline
The Following User Says Thank You to Framer53 For This Useful Post:
loneframer (11-15-2009)
Old 11-15-2009, 09:34 AM   #5
crovello's Avatar
Trade: General contractor
I have always used bridging on the first floor framing but often don't on second floor framing since the strapping keeps the framing from moving.
With "I" joists I don't use anything.
crovello is offline
Old 11-15-2009, 10:26 AM   #6
Fixed it for ya.
You also left out, sometimes western,
sometimes block.
neolitic is offline
Old 11-15-2009, 10:40 AM   #7
NormW's Avatar
Trade: Builder
I like the poll idea... nice!
NormW is offline
Old 11-15-2009, 11:09 AM   #8
KemoSabe
loneframer's Avatar
What I find interesting is, for the first 10 years of framing, we were supplied tension strap bridging by every builder we framed for. It was the industry standard here, yet no one appears to be using it now. The fact that it caused sqeaks is testament to me that there is some deflection in the joists during normal traffic across the floor. We had so many problems with it, we started solid blocking instead. In those days, surfaced dry or S-dry lumber was not generally used due to cost and availability, so GRN lumber was prevalant. We began to see issues with solid blocks as well, primarily squeaks, assumed to be caused by shrinkage and cuping of joists as they dried. The next obvious choice was wood X. I have never had a callback for wood X-bridging.
Old 11-15-2009, 12:32 PM   #9
KentWhitten's Avatar
I have to say that it's been at least a good 20 years since I used any bridging.
Salmon Falls Cabinetry
KentWhitten is offline
Old 11-15-2009, 03:19 PM   #10
KemoSabe
loneframer's Avatar
bump
Bridging for tile floors JohnFRWhipple General Discussion 13 04-05-2010 03:34 PM
mortar type for fieldstone foundation repair chelsea Masonry 5 08-24-2009 06:09 PM
Dramatically Increase Your Sales Home Services Marketing & Sales 29 05-07-2009 12:42 PM
what type of holesaw/drill bit buletbob Flooring 3 01-02-2009 04:54 AM
Best type of Portable Heater?? kdub1777 General Discussion 7 10-12-2008 06:42 PM
