Trade: Framer/Siding
How To Lift HUGE Wall?
I just finished a HUGE wall. It took my head framer 2 days just to build it. It is 30' wide and 27' tall. It is a end wall with 12 windows in it and most of it is Paralam with multiple 2x10 headers across the top and it is sheathed and Tyveked. It is out in the boonies and a crane will not come to the site. It is on a 2nd floor on a lake. The only thing that I see that could help is an 18" Hemlock tree directly infront of the wall. How do I safely lift it with a 5 1/2 man crew (3 of us have all had back surgery)? It will be very top heavy. I'm just scared we will get it 4-5' off the ground and all bust a nut and drop it. Any suggestions?
Trade: Contractor
Re: How To Lift HUGE Wall?
Wall jacks, telescopic handler, come-a-longs tied to the big tree, etc....
Why did you build it that big without a back-up plan? |
A REALLY BIG 4x4 construction fork lift. but what you really need is a crane
I like Green things
Sounds like the guy that built a boat in his basement story.
We built it with the intention of getting a crane in to lift it. Unfortunately with the snow and the terrain, no crane will come in. We have lifted bigger ones by hand but not one this top heavy. This is what is scaring me. Now we are stuck and have no way to get it up. (I don't think Viagra will lift this one LOL)
Fentoozler
P-P-P-P-P-P
That about sums it up ![]()
That is one of my best sayings on the job site and fits this thread perfectly.
Proper planning prevents piss poor production My question is the same as everyone elses.....did ANYONE think about this?
Fentoozler
In all fairness....this sort of thing does seem to happen sometimes.
Here is an example of an epic fail: ![]() This one is just to take the sting off the first one:
Well we are going to lift it by hand tomorrow. I'll let you know how we make out.
| The Following User Says Thank You to squarehead For This Useful Post: | sinacalsider (02-11-2009) |
#10 | |
Re: How To Lift HUGE Wall?Quote:
#11 | |
Trade: Framing Contractor
Joe Carola |
where in the boonies are you bro, when i usually build big Composit decks and i mess up the level i use truck jacks, same thing when i change house beams, just gotta make sure you got the wall balance
Custom Decks Custom aquarium all salt water Renovation next on my list............planting trees for all those material i used |
Trade: Finish Carpenter, Framer, GC
Wall jack will lift anything!!!! Placed in the proper places with tie down strap attached to the wall.(so it doesnt go toppling over) I lifted a 35 foot gable end that was a 2x6 frame sheethed with half inch. Not to mention the soffit that was framed with 2x6 studs and trimmed with azac, All i'm saying is don't be afraid of the weight, just take the necessary precautiuons.
Maker of fine kindling
If the tree is close to the centerline of the wall I would be tempted to give it a shot.
Did the bottom plate get a butt load of nails to the deck prior to sheething? Is there a 4x4 truck on site? Good traction area to use it to pull a 3 part line? Good rope and pulleys on the pull side. Use 2 pick points and stiffen up the top of the wall with something. Rope up the interior side to prevent tip over. Maybe some A34,s to fold under the bottom plate. Blocks on the rim as a last resort. Keep the boys out of the fall zone. You got the idea. A little crazy but you won't be yawning while you're doin it. Impossible to give enough advise to make a big difference without a few pics. But sounds like your only hope at the moment. Time to man up, stay safe, and roll the dice. ![]() Or find a crane |
Handle It!
what need be done is fairly simple. It requires two pulleys. A double pulley at the anchor point, the tree and a single pulley on the wall placed about 2/3 the way up the wall. The rope is anchored to the wall, it then goes to the tree pulley, comes back to the pulley on the wall, then back to the second wheel of the tree pulley, back to who or what ever is doing the pulling. This will take up three times the amount of rope pulled but it will reduce the assumed weight to 1/3 therefore making it fairly easy to pull.
Something to One may be Nothing to another! Ultimate Wisdom--------- http://www.youtube.com/watch?v=OW-cnizLDEE Last edited by MALCO.New.York; 01-12-2009 at 12:28 AM. |
#16 | |
Anyway keeping it from going over is probably as much of a problem as getting it up there. Then securing it for wind until you get a couple of wall butted to it. |
#17 | |
Fentoozler
A few pictures would be nice too
#18 |
Trade: Contractor
Re: How To Lift HUGE Wall? |
#19 |
topsail's trimcat
why wasnt it stick framed
work off pipe staging on the inside while framing sheath if by working off pump jacks outside
putting down subfloor with glue and screws, well i saw dr. smith and the robot too , i had a martian burger and a sonic shake Last edited by woodworkbykirk; 01-11-2009 at 09:31 PM. Reason: ... |
| Wall papered brick wall repaint | sparehair | Painting & Finish Work | 1 | 12-28-2008 08:01 PM |
| Laying new ceramic tile on wall | faromic80 | Ceramic & Stone Tile | 4 | 09-17-2008 08:01 AM |
| Buckling Exterior Wall | Duntov | Framing | 15 | 09-12-2008 08:33 PM |
| Major wall frame remodel | Jackpine | Framing | 0 | 09-03-2008 10:06 AM |
| Retaining Wall Delima - Please help | nerd04 | Landscaping | 5 | 07-29-2008 10:58 PM |
