How To Fasten 1/2" Plywood To 14 Gauge Steel Studs
Old 12-06-2007, 04:31 PM   #1
Nail banger's Avatar
Got a call from a contractor I work for alot and they are building a mini storage building and need a quote to close it in, my question is what is the best way to fasten 1/2" plywood to 14 gauge steel studs? There is going to be approx. 350 sheets of plywood.
Nail banger is offline
Old 12-06-2007, 04:34 PM   #2
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Re: How To Fasten 1/2" Plywood To 14 Gauge Steel Studs
Check www.grabber.com they have plenty of fasteners for steel framing
14g is pretty heavy, get a few samples and see which one you like best. They have Hardi screws for steel framing which will work, but on 14g they might be slow. I have also used Simpson truck bed screws which are probably the fastest and also most expensive, I used them on 12g floor joists with 1 1/8 plywood.
Chris
Chris Johnson is offline
Old 12-07-2007, 01:04 AM   #3
GFer2's Avatar
Trade: Construction Sales
There is a product on the market now that gets fired in with a nail gun but can be screwed out with a screw driver, Its a ballistic nail screw. They are available from UFO fasteners. You can check them out by searching ballistic nail screws on the net. The type of screw/nail you are looking for is the pow-r-drive. I tested them out on some 20 gauge studs worked well but found that the thicker the gauge the better holding power they have. they really speed up installation and have the advantage of being adjustable afterwards.
GFer2 is offline
Old 12-19-2007, 06:38 PM   #4
VINCE BLACK's Avatar
Trade: CARPENTRY
IN A NUTSHELL.................GYPFAST. Holds as well as screws and at least 10 times faster.
VINCE BLACK is offline
Old 12-19-2007, 07:20 PM   #5
joasis's Avatar
I think I saw a hilti nail for a power nailer that is ringed or shanked for grip.....A tek gun and self drillers would be my choice.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
joasis is online now
cutting steel studs 25BRIAN General Discussion 28 05-22-2009 09:41 AM
Steel Studs in Bulkhead DSB_Const Framing 3 04-02-2009 03:12 PM
Crown and steel studs maddface Finish Carpentry 12 12-08-2007 02:14 PM
Gauge for steel framing JonM Framing 1 11-19-2007 02:04 PM
Top mounted hangers against fire rated plywood, do studs and joists need to line up? personalt Carpentry 2 08-20-2006 04:24 PM
