How Do You Guys Set Your First Truss?
Old 03-15-2009, 04:31 PM   #1
Mr. Constructio's Avatar
Trade: Residential contractor
Rewards Points: 25
I am just wondering how everyone else does this. I usually either set the first truss far enough from the gable end to get a brace to it. then after setting about 8 trusses and bracing them up I come back and remove first brace and set to the gable. I am wondering how much work it would be to put 4 trusses together on the ground, braced and lift together. I know I have seen pics of someone on here lifting the whole roof system up at once, I am not looking for that, just maybe an easier way than I normally do it. Any input??
Mr. Constructio is offline
Old 03-15-2009, 04:34 PM   #2
Framer53's Avatar
Trade: Handyman
Rewards Points: 320
Re: How Do You Guys Set Your First Truss?
We always put the gable up with braces at an extreeme angle. Haven't lost one yet!
Framer53 is offline
Old 03-15-2009, 04:36 PM   #3
Rewards Points: 25
do you put your braces to the outside, into the dirt? otherwise they are in the way to keep setting?
Old 03-15-2009, 04:49 PM   #4
Framer53's Avatar
Trade: Handyman
Rewards Points: 320
Nope, very seldom do we do a ranch where we could,
When we set the gable it is sheathed with s&F, and a ceiling nailor fastened to the bot, before we set. Then we put up 2 tbaces nailed to the exterior into a stud. Raise the truss, nail the nailor to double plate and brace to the floor with e lineal 3x4 nailed to gether for length, nail that up as high as person can reach to the gable keeping this brace at extreem angle. The we bring up min of 2 sometimes 3 trusses up and install with braces done normally!
Framer53 is offline
Old 03-15-2009, 04:54 PM   #5
Kent Whitten's Avatar
Rewards Points: 2,040
On gables, I will put 2 uprights on the outside wall offset from the center about4' or so. I will always nail it good to a stud below, preferably on the side of a window opening . Nail from the inside face of the plywood through into the stud.
Once you get a few up, you can brace it off to your hearts desire. I don't like the bracing that goes through the web down to the floor. I usually end up putting the web bracing in, then put a diagonal up to the peak of the gable.
SalmonFallsCabinetry.com
Kent Whitten is offline
The Following User Says Thank You to Kent Whitten For This Useful Post:
SC sawdaddy (02-22-2012)
Old 03-15-2009, 05:51 PM   #6
JT Wood's Avatar
Trade: carpenter
Rewards Points: 2,494
I do like framerman. 2 or more 16' braces. 10' down 6' up.
nailed to studs.
when the gable end is up I nail it to the braces.
Usually however I build a 16' +/- section on the ground. web braces,angle braces and facia. Then have it lifted into place. then lean the rest of the pile against it.
Usually I have the crane place the sheathing on the section of built trusses. so I don't haveto lift it from the deck below.
JT Wood is offline
Old 03-15-2009, 05:58 PM   #7
WICKED WOODCHUCKER
mnjconstruction's Avatar
Trade: Finish carpentry, drywall, Tile
I just slap them up with a little caulking and call it good !!!!!
mnjconstruction is offline
Old 03-15-2009, 06:17 PM   #8
Rewards Points: 25
On the trusses I am getting ready to set this week the gables are cantilevered out over brick so the 2x4 or 2x6 nailed on the wall wont work. I think I will do as framer53 said and just brace to the wall short of the next truss and set 5 then brace up. Thanks all for the good input, it is interesting how similar and/or different things are done all over the country .
Old 03-15-2009, 06:18 PM   #9
dkillianjr's Avatar
Rewards Points: 2,464
I do just about the same as framerman does. I have never really prebuilt any trusses or anything, usually just do one at a time.
dkillianjr is offline
Old 03-15-2009, 06:44 PM   #10
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Rewards Points: 12,490
I used to fly the gable truss and 2 more on the first lift.
Keep tension on the strap while we nailed the gable to the wall. Then loosen the strap enough to slide the other 2 trusses slightly out of the way of a brace that can pass through the webbing of the two common trusses but miss the bottom cord of the 4th truss.
A quick rafter length calculation for the length and height of the brace is very helpful.
Once that is secure release the crane and brace those 2 to the gable on layout.
Once the 4th truss is up and tacked off to the first 3 there is enough to cross brace safely for the rest to fly in.
Anybody use those metal folding gizmos that capture the top cord with pinching prongs? I know I didn't describe them well but I got to use them a few times and man they were sweet.
No long 1X4 dangling out there in the way.
Gus Dering is offline
Old 03-15-2009, 07:03 PM   #11
KemoSabe
loneframer's Avatar
Rewards Points: 12,202
I always set two strongbacks like framerman. Hey Gus, you mean these things?
loneframer is offline
Old 03-15-2009, 07:23 PM   #12
CAD Services
wallmaxx's Avatar
Trade: So done with this place...
Rewards Points: 144
So, not like this.
wallmaxx is offline
Old 03-15-2009, 07:32 PM   #13
KemoSabe
loneframer's Avatar
Originally Posted by wallmaxx View Post
So, not like this.
Maybe, if I were geared for that. I've only done 6 truss jobs in 25 years and 2 of those were ranchers that we handed up from the gable ends Every other job was stick built.
Old 03-15-2009, 07:40 PM   #14
Rewards Points: 25
the metal truss spacers are awesome, nail em on and deck over the top of them.
Old 03-15-2009, 07:56 PM   #15
Project Manager HFH..
JumboJack's Avatar
Rewards Points: 2,004
on gables, i will put 2 uprights on the outside wall offset from the center about4' or so. I will always nail it good to a stud below, preferably on the side of a window opening . Nail from the inside face of the plywood through into the stud.
+1...
in texas with framing and cornish people will do it for 3.00 a foot. What do yall think about that? Just laber
JumboJack is offline
Old 03-15-2009, 08:46 PM   #16
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 68
What - Stabilizers? They work great
You can get three boxes free - posted earlier http://www.contractortalk.com/f11/st...er-free-55116/
SLSTech is offline
Old 03-15-2009, 10:23 PM   #17
CAD Services
wallmaxx's Avatar
Rewards Points: 144
Me too. On commercial...it pays to think big. The guy I was working with was a truss genius. He had that metal rack welded to his specs. It worked great and kept the guys on the ground - safe - which always made OSHA happy.
My only truss experience is with multi-family structures with HUGE clear spans...or cheap builders / or a region where the truss plants had killed all the smart framers. (now I don't mean anything bad about truss guys) It just seems that in some regions...the skillz and knowledge are evaporating.
I just did my second stick roof here in town (I guess that's around 300 total in 20 years). The inspector said he hadn't seen a roof like this in the 12 years he's been the city inspector. He was asking for my engineering stamp. I held up the IBC 2006 and showed him how everything I did was within the allowances of the code book...thus it was "engineered".
wallmaxx is offline
The Following User Says Thank You to wallmaxx For This Useful Post:
loneframer (03-15-2009)
Old 03-28-2009, 03:37 PM   #18
roscoe8423's Avatar
Trade: framer/carpenter
Rewards Points: 25
I think that the easiest way is to set any girters that you need for the main truss system, then set a truss in the middle and brace it to the subfloor or to an interior wall and work your way toward the gable, using 25 1/2 inch blocks to stabilize as you set each truss. Then when you get to the gable, get the bottom nailed to a backer and run a rat run (2x4 on top of the bottom chord of the trusses, connected to the gable) and run a plumb brace from the peak of the gable to the rat run. Run all of your lateral bracing and then pop the brace loose from that first truss you set and start setting them the other way. If we are setting big trusses we will plumb the first one in a couple spots, then set 8, run lateral braces (16 footers...), set 8, run braces, etc. When we are doing small houses up to 2500 square, we use the gradeall to set trusses, just pick up a set and set em on the wall and have a guy on each end and one in the middle and drag em. I dont see many other people do that but it sure beats 125 an hour for a crane.
roscoe8423 is offline
Old 03-28-2009, 03:40 PM   #19
roscoe8423's Avatar
Rewards Points: 25
wallmaxx, what are those yellow things that you have the trusses sitting on?
Old 04-05-2009, 05:26 PM   #20
mikewith's Avatar
Trade: remodeling/framing
Yup. I also set the gable first. To feel more at ease, put a strong back on that same wall, up the gable 6ft
mikewith is offline
Any Of You Guys Use This Drywall? Ed the Roofer Drywall 12 03-02-2009 10:16 AM
Hey Guys, Got a 300KW, 16KW and 12.5KW Generator(rent) atessler1 Tools & Equipment 1 02-10-2009 07:08 AM
how much of an overhang is possible w/ truss AustinDB Construction 3 08-16-2008 09:16 PM
Stick or truss frame, Fire and collapse issue nywoodwizard Framing 16 06-25-2008 09:20 AM
??? Whats the best way to spread the news about your company? jmgrahamjr Marketing & Sales 21 06-24-2008 03:46 AM
