How Do I Get A New Roof Over This Porch That Has Drop?
Old 10-05-2009, 07:51 PM   #1
Jeff
jkfox624's Avatar
Trade: master turd burglar
HO was thinking of replacing the deck roof with a hip here, i dont see a way to make it look right and work. He wants to turn this into a sunroom, the roof now is like a 1/12 pitch at best with that stupid corrugated fiberglass crap. Not sure how it holds the snow in the winter its all rotted to hell.
other end....
I've tried drawing something up and just cant come up with anything thats gonna look right. Anyone got some advice?
jkfox624 is offline
Old 10-05-2009, 08:19 PM   #2
N.Schiffer's Avatar
Trade: Custom Carpentry
Send a message via AIM to N.Schiffer
Re: How Do I Get A New Roof Over This Porch That Has Drop?
Is that gable to the right finished on the inside, or is it just in the attic space and could be removed without extensive interior remodeling?
Nick Schiffer
Specializing in Custom Sheds
Custom Carpentry
& General Construction
N.Schiffer is offline
Old 10-05-2009, 08:31 PM   #3
Paul in Raleigh
Lifestylebuilds's Avatar
Trade: General Contractor & Remodeler
You can put a 3/12 or up to a 5/12 shed roof in place of the shed roof...easy tie in.
Lifestylebuilds is offline
Old 10-05-2009, 08:43 PM   #4
solar guy
naptown CR's Avatar
Trade: solar contracting
raise it up and put a hip on it what's the problem?
naptown CR is offline
Old 10-05-2009, 08:50 PM   #5
Jeff
jkfox624's Avatar
I'm pretty sure the gable is nothing. deck sticks out 10', if i go to the existing ridge i can only get a 2.8/12 give or take. The end of the house with the gable is highly visible from the road, trying to avoid a dual pitch with a long shallow pitch.
jkfox624 is offline
Old 10-05-2009, 08:52 PM   #6
Jeff
jkfox624's Avatar
I guess thats what im gonna have to take to him, from what i drew up gonna have to raise it 4'. I have a tendency to way overthink things, just getting some other opinions to make sure i wasnt overlooking the obvious.
jkfox624 is offline
Old 10-05-2009, 09:00 PM   #7
solar guy
naptown CR's Avatar
I meant raise the beam height to match the wall height and then put the hip pn it. Where did the raise it 4' come from
Old 10-05-2009, 09:14 PM   #8
Paul in Raleigh
There is a couple of ways to approach this...cost = shed...IMO
However to run a full hip on the back?? you have a serious height problem, as you will be higher then the original gable. By the look of the house....shed will be easier, clean and cost effective. Good luck
Old 10-05-2009, 09:22 PM   #9
Jeff
jkfox624's Avatar
No matter what theres a height issue, a shed from deck edge to ridge is giving me under a 3/12. No way in hell building inspector will go for that.
jkfox624 is offline
Old 10-05-2009, 09:33 PM   #10
oldfrt's Avatar
Why not?
oldfrt is offline
Old 10-15-2009, 09:51 PM   #11
ClemS's Avatar
Trade: Framing
i'll side with naptown on this. what's the problem? day's worth of demo/framing.
ClemS is offline
Old 10-15-2009, 10:13 PM   #12
Starving Tile Artist
wizendwizard's Avatar
Trade: Carpentry, Flooring & (UGLY) Tile installs.
Send a message via Yahoo to wizendwizard
After running a few SK variations on this I have to agree. Trash the gable and run a shed roof. I'll post my SK's if needed.
"If you start the grout process over, you too could use sparkly grout!"
There is no such thing as an illegal immigrant, they are either illegal or immigrants.
I'm Retired, or a student, don't really know anymore.
wizendwizard is offline
Old 10-15-2009, 10:24 PM   #13
SC sawdaddy's Avatar
I'm just not seeing the height problem. Maybe I'm overlooking something.
I gotta go with Naptown too, raise the beam to the soffit line.
SC sawdaddy is offline
Old 10-16-2009, 08:10 AM   #14
Jeff
jkfox624's Avatar
He's just gonna keep it flat and put rubber on it i guess.
jkfox624 is offline
Roof Estimating And Drawing Program Ed the Roofer Roofing 32 03-07-2011 10:50 AM
Porch Column Repair mpt1123 Historical Restoration 5 01-11-2010 07:33 PM
Porcelain Tile Porch jbtn9 Flooring 1 09-22-2009 04:45 PM
Tying into existing roof Milhaus Framing 9 11-06-2008 12:03 PM
Ice Problems on a roof J-Peffer Roofing 4 10-01-2008 11:12 AM
