Trade: Construction
How To Calculate Max Unsupported Span Of Trusses?
Hey guys. What do i need to know to calculate the max unsupported span of a truss. Just bought a house and wife wants a wall knocked down.
The lower chords are resting on a wall in one half of the house and on the other half of the house they span the whole width with no support! I cant tell if the wall not being there is from new or was done after it was built! They are same trusses along the length of the house also. This is going to decide if i have to replace a wall or can remove one so marriage could be in trouble depnding on answer ![]() Cheers guys |
Re: How To Calculate Max Unsupported Span Of Trusses?
Trusses are engineered so you need to get an engineer to sign off on it unless you happen to have the original plans and specifications on hand. You also need to get a permit as it is required to remove any wall regardless of whether it is bearing or not. Now for the information you are actually after:
dimensions, species, and grade of wood used to construct the trusses. Roof loading ground snow load for your area. deflection limitations truss spacing |
| The Following User Says Thank You to ARI001 For This Useful Post: | BCConstruction (11-20-2009) |
Trusses usually bear only on outside walls. Not very often is there any load bearing in mid span. You still need to get the truss engineer out to look at it and someone to sign off.
| The Following 2 Users Say Thank You to KentWhitten For This Useful Post: | BCConstruction (11-20-2009), bwalley (11-20-2009) |
Trade: Construction
Cheers guys. I will get some more details next time im at the place. should be tommorow.
Framerman perhaps this is why there is a wall missing in half the house and not the other. Always though some load had to be taken by internal walls. So its good to know the house is gonna be ok if i leave it how it is. |
#5 | |
Trade: Construction
Re: How To Calculate Max Unsupported Span Of Trusses?Quote:
Framerman you got any more info about getting a engineer out to take a look at this wall that needs removeing. I have never had to do this so im curious to know how i go about getting one? I have spoken to some contractors and they said they have never bothered when doing what im doing but i dont wanna take any chances. Plus it cant be that expensive can it? |
#6 | |
I want to say that it should be fine, but those too are famous last words. I cannot guarantee that your situation is good to go. I'm just saying that in general, trusses are designed to span from outside wall to outside wall. Take a camera into the attic and take pictures of the trusses in question. If they are a standard Fink truss (w-shape) ![]() or a Howe truss ![]() then it should be perfectly safe. These will be your most common truss designs. I would guess that you have Fink trusses. The final call is on your part. If they look any different than those two pictures, then absolutely get someone out to look at it. If it's a Fink or Howe, then like I said, it should be good to go. BTW, make sure it is a truss. Rafters and ceiling joists are a different ball game. Post those pictures.
If you correct your mind, the rest of your life will fall into place ~Lao Tzu Custom Cabinetry - Portland, Cape Elizabeth, Scarborough, Kennebunkport, Yarmouth, Falmouth, Cumberland, Ogunquit, Maine Salmon Falls Cabinetry Last edited by KentWhitten; 11-22-2009 at 04:27 PM. |
| The Following User Says Thank You to KentWhitten For This Useful Post: | BCConstruction (11-22-2009) |
#7 | |
Trade: Construction
Yeah i bet it's more than i am thinking. always is. heres the pics of the trusses. ![]()
Trade: Framing
Look like pretty standard truses.
Should be good to go! |
Trade: Construction
Cheers guys. The area of wall that she wants out is only going to leave 2-3 trusses without the wall under them so im not removing the whole length of support. Im just no truss expert so want to double check my options.
Also whats the deal with all that white stuff over areas of the ply? Their aint been no leaks but it the first time i ever seen ply go like that in a loft! |
You're all set to go, those are simple span trusses. No interior bearing needed.
The white stuff I hope is not mold. That would be a ventilation problem most likely and need attention ASAP. Check your eave vents to see if they're blocked.
Trade: Construction
I aint been up there and had a great looked around yet but seems to have very good ventilation with the 2 vents on each gable end. Hopefully it's not mould. it smells better up there than in the house lol
Isn't this a framing topic?
I don't think there is such a thing as an interior load bearing wall under roof trusses, is there? I have never heard of one. There are interior shear walls under roof trusses, that's the only thing you would have to watch out for. It's real unlikely the wall you want to tear out is going to be a shear wall though. |
| The Following User Says Thank You to KennMacMoragh For This Useful Post: | BCConstruction (11-22-2009) |
#13 | |
Trade: Construction
I def aint a expert but i thought shear walls used plywood or diagonal braces? These walls just have upright 2x4's with drywall! |
Dave from Macatawa
Trade: GC, cabinet maker and remodeler
Sheer walls are a whole other topic that gets involved. for instance a sheer wall can be gyp over 2x with the right screw pattern and layout.
go with framerman's recommendation |
| The Following User Says Thank You to macatawacab For This Useful Post: | BCConstruction (11-22-2009) |
Re: How To Calculate Max Unsupported Span Of Trusses? |
Trade: Custom deck builder
There are such things as load bearing interior walls with trusses. I have set many a girder atop a load bearing interior load bearing wall. I have also set many girders on point load posts in interior walls that someone might be in for a surprise if they think they could take out the wall.
In this case it is not an issue however.
#17 | |
Trade: carpenter
x2. |
#18 | |
Trade: Architect
If the framing contractors that you know can't steer you to an engineer or an architect, go to the building department in your municipality and ask them to give you names. They will usually give you a couple of names of ones they are familiar with. If all that fails, use the phone book, if there still is one, or just Google "Structural Engineers" for your area. It'll cost you $150 +/- for the site visit. Maybe $250 to give you an opinion. It'll cost much more if you guess wrong. |
#19 | |
#20 |
Not sure when the house was built but if built correctly.....
If the unknown support wall runs parrallel with the floor joist you could look for a pier/ beam or some support in the crawl space. Should be one if the wall is load bearing and parrallel with floor joist. With that said your truss design is made so that the weight is carried to the outside walls... Your interior wall is not load bearing. Although your truss/trusses will settle slightly after you remove this wall just from the roof load. Keep that in mind when you finish your rock. |
| Span for 2 x 4's? | Chris G | Decks & Fencing | 21 | 06-15-2009 11:06 PM |
| u ever dealt with POS scissor trusses? | IHI | Framing | 50 | 05-09-2009 07:50 PM |
| Handbuilt Clear span trusses, anyone in the NW want work? | BattleRidge | Framing | 33 | 03-27-2009 11:30 AM |
| Floating trusses | Snobnd | Framing | 15 | 02-24-2009 07:25 PM |
| Floor Joist Span | BuriedHammer | Framing | 16 | 12-30-2008 09:03 PM |
