Hoses Freezing Up Help
Old 12-09-2006, 03:42 PM   #1
I prefer carpenter
marklo154's Avatar
Hello, this is my seventh winter framing and as the place starts to get cold i can`t keep the hoses from freezing up it is a struggle every day with these hoses any help would be great.
Great forum by the way
marklo154 is offline
Old 12-09-2006, 04:45 PM   #2
house bldr's Avatar
Trade: general contractor
Re: Hoses Freezing Up Help
Do you have a water-condensation filter on your compressor?
house bldr is offline
Old 12-09-2006, 05:08 PM   #3
fettycan's Avatar
Trade: roofer
dry gas or gas line antifreze works alittle in the tanks keeps every thing working and so far it hasint hurt the guns.
fettycan is offline
Old 12-09-2006, 05:29 PM   #4
Teetorbilt's Avatar
Get the water out! I use http://www.smcusa.com/ for most of my pneumatic needs. I think that you want a seperator/coalescing filter but I'm not sure about these in freezing temps. Your rep can help.
Albert Einstein
Teetorbilt is offline
Old 12-09-2006, 05:38 PM   #5
I prefer carpenter
marklo154's Avatar
the gas line anti freeze wear do i put it in a drip, i have a water filter but like its not doing much this year i thought it was the filter but i guess the filters good for life.
Old 12-09-2006, 07:31 PM   #6
Joe Carola's Avatar
Trade: Framing Contractor
What kind of hoses are you using?
I'm in NJ and it gets cold here. I use Flexeel hoses and they've never froze before.
http://www.coastaltool.com/cgi-bin/S...htm?E+coastest
Joe Carola
Joe Carola is offline
Old 12-09-2006, 08:04 PM   #7
I prefer carpenter
marklo154's Avatar
I have one of those hoses and it`s great i check out the link and saw the 3/8 hose i have never seen that in a store, you see i use a 3/8 25 foot hose from the compressor with a three way on in and then run hoses off of it the 25 footer is pvc i believe so maybe i`ll order one of those 3.8 from that link. I think i might try replacing the filter on my compressor thou the compressor is big 11 hp with a big tank on it .
Old 12-09-2006, 09:19 PM   #8
Joe Carola's Avatar
I use all 1/4" for all my guns and never had a problem.
Joe Carola
Old 12-09-2006, 09:27 PM   #9
T-KAT's Avatar
Trade: carpentry
air brake antifreeze works good. I pour a thimblefull in the line in the morning and blow the line out. no problems. My bigger problem is the guns. They freeze and jam up at around -20 celcius, even with the special cold weather oil.
T-KAT is offline
Old 12-09-2006, 10:40 PM   #10
GC / Remodeler
dshcontracting's Avatar
Trade: General Contractor/Remodeler
Send a message via AIM to dshcontracting
Joe is right, I've been using flexeels for a while now and no problems. The PVC hoses don't bend in the winter. flexeels are the way to go. Very light too.
dshcontracting is offline
Old 12-11-2006, 09:05 AM   #11
BirmanBuilders's Avatar
Trade: Framing
we use an antifreeze oil. It's for lubricating the guns and works great on the hoses too. We also keep the exhaust of the generator facing the compressor hose outlet. Seems to be working. You have to put the oil in first thing otherwise forget it.
BirmanBuilders is offline
Old 12-11-2006, 09:48 AM   #12
Joe Carola's Avatar
Buying a hose is just like buying the best tool and not a cheap one. Buy the best hose and use them and don't worry about those garbage hoses that freeze. Don't just use one flexeel and spring off with junk, use all flexeel and you'll be fine. It's an investment just like the rest of your tools.
Joe Carola
Old 12-11-2006, 07:10 PM   #13
I prefer carpenter
marklo154's Avatar
birman builders love the t shirt it made me laugh, i saw a tile company had a similar shirt that said we`ll lay anything
Old 12-11-2006, 07:18 PM   #14
RobertCDF's Avatar
Trade: Custom deck builder
We used to use "killfrost" just like gun oil but designed to keep hoses from freezing up. Then we went to flexeel when those came out.
Now that I am on my own I have a better solution... Dont work when its really cold out.
RobertCDF is offline
The Following User Says Thank You to RobertCDF For This Useful Post:
rkh (01-09-2012)
Old 12-11-2006, 08:30 PM   #15
Trade: Framing
funniest T shirt i ever saw was "Great Shag" carpeting back in England
Old 12-13-2006, 10:44 PM   #16
osborn's Avatar
Trade: Licensed Home Improvement Contractor
Yup..... Killfrost the lines. Also use 3/8.
osborn is offline
Old 12-18-2006, 07:41 PM   #17
CarpentryCrewMI's Avatar
Put a shop light facing your air 3-way, started doing this 2 years ago and it seems to work great. When it gets below zero nothing we have tried seems to work.
CarpentryCrewMI is offline
Old 12-18-2006, 10:19 PM   #18
Teetorbilt's Avatar
With over 10 yrs. of industrial pneumatics under my belt AND a knowledge of the construction business I would recommend totally dry air or an oiler using alcohol (NO SMOKING!).
You must think of those coming behind you and a discharge of glycol, glycerin or other inhibitors can cause painters many frustrations.
Just my 2 cents.
Albert Einstein
Old 01-04-2007, 01:44 PM   #19
brownie77's Avatar
Trade: Carpentry, Contractor Sales for Pella Window and Door
I am still at loss with frozen guns, hoses etc.
The only thing that I've found to work is to bring the guns and hoses home with me at night and stick them by a heater. This always gets me to at least lunch. Then stick them in the truck with the heat going at lunch. In real cool (+-0) I've rotate hoses in and out of the heated truck.
brownie77 is offline
Old 01-08-2007, 08:05 PM   #20
Trade: Framing
we also face the generator exhaust at the three way on the compressor, seems to work.
"Flexeel" air hoses MKECONTRACTOR Roofing 10 03-25-2007 10:52 PM
tips on keeping products from freezing in truck 72chevy4x4 Construction 2 02-11-2007 08:31 PM
Freezing Rain marklo154 Framing 1 01-16-2007 08:33 PM
CAC pipes freezing meone HVAC 1 09-23-2006 08:58 AM
Flexeel hoses Mike Finley Tools & Equipment 14 09-12-2006 06:17 PM
