#61 |
Mod / ArchiBuilder
Re: Hips And Valleys
Fair enough, if you see something you don't like happening. Use the report button.
Did you take your matter up with Joasis privately? Please keep conflicts free from further posts and you can stay here as long as you want.
Tulsa's Leader in Outdoor Living Construction | Facebook | Tulsa Pergola Builder | Tulsa Outdoor Kitchens |
#62 | |
Trade: Framing
Re: Hips And ValleysQuote:
#63 |
Trade: carpenter
Loneframer - I hate that you have those nice bump jack setups and I don't!
We just hang off our safety lines, or make tri-angle scaffold out of 2x4s. Oh, and nice job there |
#64 | |
KemoSabe
#65 | |
Trade: Framing
but still stay away from the four-footers -- don't speak their language
#66 | |
KemoSabe
#67 | |
KemoSabe
Had to let him go too.
#68 | |
Trade: Framing
#69 | |
Trade: Framing
#70 | |
KemoSabe
#71 |
Trade: Framing
you could say I'm doing the same. Down to 2 guys plus me. I piece out anything that I can't get to, which right now isn't a hole lot.
#72 | |
Trade: Roofing Contractor
Ed
Please Stay Tuned For A Very Important Message From Our Sponsor http://www.rightwayroofingcompany.com/ www.rightwayroofingcompany.com Roof Estimates, Roof Repairs, Roofers, Roof Leak Help, Elgin, Carpentersville, East Dundee, West Dundee, Sleepy Hollow, Algonquin, South Elgin, Huntley, Lake In The Hills, Illinois |
| The Following 4 Users Say Thank You to Ed the Roofer For This Useful Post: |
#73 | |
Trade: Framing and General Construction
this is the way I do it.. |
#74 | |
This is a different concept for H/V rafter cutting than most roof cutters employ. For Irregulars, it is the least complicated and most precise. See more on this topic discussed over at JLC’s rough framing forum. (see link in next post, No. 16 for me) I pre cut all H/V rafters, regulars and irregulars, the same as I simply calc and mark commons. HAPs are always equal. Both types of rafters, (Commons. & H/V’s), have similarities that once recognized, can be very useful in simplifying understanding how they fit geometrically. Both rafter types are contained in the same plane, and they extend from the same plate to the same ridge. So their lengths are based on the same effective run, the common’s. (As used by the better framing square’s H/V rafter length tables and also most reference books and the CM Master calculators too.) Both rafter types have pitch cuts and cheek cuts that are parallel. These cuts are known as compound miters, and are easier to recognize on the H/V rafters than the commons. The common’s compound miter is ‘pitch’ by 90 degs. (90 degs is the commons plan view angle) The H/V rafters have an ‘adjusted pitch’ by proportionate plan angle(s). (The regular pitch H/V roof will have a 1/1 proportionate plan angle, Irregulars will have proportionate angles defined by the tangent and cotangent of the given pitches. (or Major pitch/Minor pitch, and the reciprocal) On irregular pitches you should be able to use either pitch’s effective run and solve the Irreg. H/V’s length, and it will always calculate to be equal either way. Understanding the perpendicularly located relationship of the long points and the short points of the compound miters is the key to simplifying marking and cutting H/V rafters, both regular and irregular. Hips are measured and marked from top to bottom, along the top shoulder, and valleys are done reciprocally, bottom to top, along the bottom. The H/V rafter line lengths are the same length at their sides as the line length at the H/V’s apparent center prior to performing the cuts. All this means is that the H/V rafters can be marked and cut like the commons with the exception that the cheeks are not (90) square bevels. These compound angle points do mirror each other straight across the top of the boards and where these opposing angles cross is the apparent offset, or shift. This method does not require any additional ‘Hip Drop’ or shift adjustments. The geometry is self aligning and they usually fit perfect. Valleys cut this way are brought into plane at the top shoulder to valley jacks top, (not planning to the center as they are when marked as most guys mark them). I like to drop the valleys slightly so that I skip ‘V’ backing them but they are still high enough to easily support the sheathing cuts, and they are more forgiving of less perfect valley sheathing cuts too. |
#75 |
Re: Hips And Valleys |
#76 |
Trade: Framer/Remodeler
Thanks Birch.
I think that it is sad that i had to spend time sifting through all of this crap to find two useful posts that actually had a response to the question that i asked. |
#77 | |
I did respond but I did not answer your inquiry about how to “figure the (Hip) drop for a bastard hip.” I only reiterated in post No. 80 what I previously posted in No. 37. My approach to the solution for this common Roof Framing task is as simple as it can get. It is “easier done” than said (explained) and I believe that the geometric simplicity that is present in every hip/valley roof has been simply overlooked, or missed, in recent times. (As evidenced by the fact I can’t find a modern reference book on the subject that addresses this geometric view) I am simply trying to point out the geometry. Every book I’ve found on the subject over thinks the task and complicates the solutions. The geometry is set in stone and is true for every scenario of roof I have encountered. Hopefully you can view the Sketchup Demo I produced and you “see” what I’m talking about. I swear, once this concept ‘snaps’, all roofs are simple. (Draw yourself a full scale framing detail plan view of a one foot run hip roof, and study it.) Here is a isometric drawing I did. Notice the equal line lengths (congruent triangles) assosiated with the hip. |
#78 |
man I wish I could put easily into words what I do.. for starters on a bastard always think from the subfacia as a start. The corner of the sub is where it starts and the corner of the plates is simply a point of reference and not anything to do with the hip. Start with the HAP for the shallower pitch at wherever you need it for boxing heights to work.. lets just say for kicks it is one plate on top of joists with a standard hap depth.. If you draw a full scale mockup of the standard cornice and then draw the steep side pitch also starting from the same point (from the boxing) you will see that the hap on the steep side is a good bit (depending on pitch) higher than the shallow one ..I usually end up with an extra plate on the steep side so I dont have such a small birdsmouth cut. Whatever plates I add to the steep side I let extend all the way for the hip to sit on as well.Then if you draw a level line on the mockup from the hap of the steep side to where it intersects with the slope of the shallow side and measure that level line that will give you the distance that the hip is off of the corner pulling from shallow side plate along steep side plate. The hip should be cut using the hap of the steepside. Keep in mind that the hap of the hip is figured at the corners of it and not the center. I could show you with a framing square and a piece of plywood a lot quicker and easier than I can put it into words! All of this can be figured with a calculator but I find it easier to grasp and explain by drawing it... Then I have a cool picture to try to keep up with too! Hope some of this makes sense!
#79 | |
Trade: Framing Contractor
Using an 8/12 and 10/12 combination with 12" equal overhangs. Draw off the left side corners of the plywood for example 12" and then 3-1/2" for the top plate thickness. Now you have your overhang including sub-fascia and top plates with the outside corner. Now draw 8" in from left to right and 10" up from corner and draw the 8x10 rectangle which represents the two pitches in plan view. Also gives plan view angles and cheek cuts for hip and jack cheek cuts. Connect from the bottom left corner to the top of the 8x10 rectangle hypotenuse line and continue that line until it hits the outside top plate line. That's your center line of the hip offset from the outside corner towards the steep side which is 3". Now draw a 3/4" perpendicular line on both sides of the hip hypotenuse line and draw both sides of that line from the sub-fascia overhang to the outside of the plateline. That's where your HAP mark is. First drawing is the plan view where the center of the hip sits 3" off the corner. Second drawing shows the thickness of a 2x hip where that hits the outside of the top plate where to mark the HAP cut.
Joe Carola |
#80 | |
cool! I usually draw this view too but achieve the same results using a different method.. The "8x10" rectangle is a shortcut I'll be trying in the future! There are still alot of nuances to a bastard hip that even with all the info given in these posts someone with no experience with them will still struggle! Nobody has even addressed the top cut and plenty of people will assume it is just a standard double cheeked cut I love it when I ride through a neighborhood and see bastard hip houses with a little offset in boxing height at the corners! |
| Metal roof question | Burby | Roofing | 11 | 01-22-2009 01:16 PM |
| Roof Bracing Beam - Likes / Dislikes / ??? | wallmaxx | Framing | 13 | 01-01-2009 10:39 PM |
