Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Carpentry > Framing
Old 07-26-2006, 11:01 PM   #1
Trade: Contractor
Hilti Hit HY20 Epoxy Anchor spacing
Hello,
I've got a set oif plans stating to attach 2-rows 1/2" ~ Hilti Hit HY20 Epoxy anchors @ 32" O.C. provie 2" edge distance at ledger. 2 questions:
1. since there are 2 rows, are the rows of anchors directly under each other, or are the rows staggered?
2. What does the 1/2" ~ mean?
Also, the plans are saying to use a Simpson LUS28 as a joist hanger with a 2x10 joist. Is this right? I thought we were suppossed to use 2x10 joist hangers with 2x10's.
Thanks.
mpro13 is offline   Reply With Quote
Old 07-26-2006, 11:13 PM   #2
Moderator
Double-A's Avatar
You can use an LUS28 on 2x10 if your load values are correct, according to the Simpson website. This is the Doug Fir/Southern Yellow Pine Numbers page. I think the ~ in this case means approximate. I might be wrong.
http://www.strongtie.com/products/co...ce_ss-df1.html
New York Times, July 20, 2006
Double-A is offline   Reply With Quote
Old 07-26-2006, 11:37 PM   #3
Charitable animal
Bone Saw's Avatar
Trade: decks
the 1/2" means a 1/2" anchor
Custom Decks & Carpentry LLC.
play
more play
raped ape
Originally Posted by nilscraft View Post
I'm doing a bid for a homeowners ass
Bone Saw is offline   Reply With Quote
epoxy grout removal reveivl Flooring 15 09-15-2009 05:57 PM
Epoxy On Tile go do it Ceramic & Stone Tile 14 05-16-2007 08:10 PM
Ramset Cobra or Hilti A41I PLC-Landscape Tools & Equipment 7 04-19-2007 06:16 PM
Preping concrete for epoxy..... metomeya Painting & Finish Work 5 04-15-2007 04:44 PM
copper epoxy ELM Plumbing 6 12-11-2005 09:45 AM
