HELP Need Advice For A Sagging Beam
Old 04-03-2009, 11:01 PM   #1
highpeaks's Avatar
Trade: Renovations
The main steel beam of my home is sagging 1/4" to 1/2" about the last third of the beam. Is it worth will to fix a 1/4 ti 1/2 sag?
It seem's to be caused by a few issues. First, the end of the beam meets another beam perpedicular. The main beam is attached to the other via some L-brackets. THere is a column under the other beam, the the l brackets seem to have dropped over time. The other issue seems to be too much weight on one column which is bowing. My thought were two jack up these two points with screw jacks. I would replace the bowed column. Then I was going to pour a new footing mid-way between these two points for an additional column. Possible a 2nd new column at the intersetion of these two beams. Although maybe new brackets would do the job. Any thoughts our advice. The beam is like a 6x3 steel beam circa 1958. Probably equal to 2 2x10's today.
highpeaks is offline
Sagging Main Beam! wizendwizard Flooring 59 03-02-2009 07:55 PM
need advice on beam winn Framing 21 11-18-2008 11:01 PM
Need help on beam advice for a loft mcu Framing 16 11-08-2008 02:40 PM
need some advice framing to a beam Vabuilder Framing 23 02-22-2008 04:41 PM
Main beam sagging 1/2 inch? AllGoNoShow Construction 10 10-12-2006 08:20 PM
