Help With - Inside Corner Trim For Vertical Cedar Siding
Old 07-21-2007, 02:19 AM   #1
I used to think so.......
wallmaxx's Avatar
For typical horizontal siding I put a 1x1 or 2x2 in the corner first and then butt the siding into it. But on this job, I have the fortune of using cedar channel in the vertical direction. Any suggestions? I haven't used vertical cedar since 1989 and I was just a lumber toter back then.
I am thinking that I can rip the lips off and butt one in tight to the other in the inside corner, and then rip a 3/4" x 3/4" piece to install over the vertical length of the seam.
Any help would be appreciated.
Thanks. Mike
wallmaxx is online now
Old 07-21-2007, 03:42 AM   #2
Priced In
JustaFramer's Avatar
Trade: Exiled For Life
Re: Help With - Inside Corner Trim For Vertical Cedar Siding
I did some cedar channel about 2 years ago on a addition. I had to match a 22.5 degree outside corner first before I could tackle the corner. I had some pictures of it on here awhile go. I ripped the 22.5 degree bevel and matched existing cut. I continued putting up pieces till I came to the corner. Measured the width and ripped a inside 22.5 degree bevel. The cuts I thought came out sweet but because of the rain I still caulked it as it was being painted anyway.
Because there wasn't a option of corner trim all the outside and inside cuts were beveled.
JustaFramer is offline
Old 07-21-2007, 08:30 PM   #3
KentWhitten's Avatar
you wouldn't need to put a 1x1 over it unless you aren't using a table saw. I just did 2 condos with vertical siding and didn't need inside corners or outside corners. What you do have to watch out for is the layout of your vertical lines near any object vertical, meaning doors and windows and the like.
Are they painting? staining? or leaving it?
I miss red cedar
lol, I just noticed, they still have christmas lights up!
Salmon Falls Cabinetry
KentWhitten is offline
Old 07-22-2007, 06:47 PM   #4
wallmaxx's Avatar
Thanks for the quick replies. I am using a table saw...so I will incorporate biscuits and glue and finish nails.
I just thought all inside corners were trimmed. I need to get out with cedar more.
PS
The cedar sawdust pile smells GREAT!!!
Cedar siding removal bid help haskl33 Windows, Siding and Doors 21 07-03-2009 12:55 PM
Watertight integrity of viynl siding? mci2980 Windows, Siding and Doors 71 11-24-2007 04:15 PM
cedar siding backer question Home Serve Windows, Siding and Doors 7 04-26-2007 02:09 PM
OLD unprotected cedar siding DeanV Painting & Finish Work 4 11-13-2006 08:36 PM
