Girder Hangers
Old 02-19-2006, 09:22 AM   #1
Hudson Valley
mjay's Avatar
Trade: Restorative Painting
Girder Hangers
Its a renovation, lots of plumbing in the way, so I have to be a little inventive.
Load bearing wall, two story house: Joists [2*10s 16o.c, 7ft span] on 1st floor. Would like to run a girder [3*2*10s] directly under a load bearing wall, and would like to maintain headroom in basement.
So ... Thoughts on using a girder/truss hanger attached to a small [3*2*10s 4ft] header sitting on block walls, I could also attach a ledger to the header and notch the girder.
Would appreciate opinions/advice.
www.blueskiesrestorations.com
There's some top class people on this forum,........and then there's me...Touching cloth.
mjay is offline
Old 02-19-2006, 02:25 PM   #2
Hudson Valley
mjay's Avatar
Re: Girder Hangers
What no takers?
Is a truss/girder hanger suitable in this situation, or do I have to stick a lolly underneath. I'm trying to save the homeowner some space, but the structure takes priority.
mjay is offline
Old 02-20-2006, 04:28 AM   #3
Hudson Valley
mjay's Avatar
Re: Girder Hangers
I'll let you know what the Inspector thought.
mjay is offline
Old 02-20-2006, 09:58 AM   #4
K2's Avatar
Re: Girder Hangers
I didn't see this thread but I'm not getting the picture but, I like to use truss girders.
K2 is offline
Old 02-21-2006, 10:01 AM   #5
Hudson Valley
mjay's Avatar
Re: Girder Hangers
Sorry the description threw you off. Hope this helps.
Plan view
- Header - Brick
----------IIIIIIII
||| 3*2*10s
This is the floor layout for the 1st floor, the joists run parallel from a sill to the brick wall, above the tripled 2*10s is a load bearing wall (not the roof trusses, but supporting the 2nd floor joists). The floor structure is being improved/replaced (old house = can of worms) because client wants tile entrance and bathroom first floor.
The question was at the intersection triple 2*10s and header would a truss girder hanger be effective or would I need to place a lolly underneath that point.
Inspector, says yes. The triple 2*10s are more than sufficient to bear weight of 2nd floor, and hanger used is able to hold/transfer weight to header over brick walls.
Yes, stamped engineer plans would have been nice, but common sense, research, and consulting with knowledgeable people work equally as well.
mjay is offline
Old 02-22-2006, 09:36 AM   #6
RowdyRed94's Avatar
Trade: Residential custom home builder
Re: Girder Hangers
IMO, it comes down to the capacity of the hanger. Check with Simpson or whoever your manufacturer is and, if necessary, have a steel hanger fabricated. You'll have to notch the bottoms of your beam members 1/4" to prevent a bump in the ceiling. Otherwise, no problem.
Clint - carpenter, coordinator, webmaster
RowdyRed94 is offline
Old 02-24-2006, 06:34 PM   #7
Hudson Valley
mjay's Avatar
Re: Girder Hangers
Thanks Rowdy.
Yes, the hanger go way beyond the capacity [Simpsons], no need to notch - the beams are 1st floor, unfinished basement.
mjay is offline
Door hangers & non-customer referrals Danno6102 Marketing & Sales 1 12-17-2007 01:47 PM
1 1/2" nails for hangers? boman47k Decks & Fencing 28 06-24-2007 04:53 PM
Stainless steel joist hangers? dougchips Decks & Fencing 32 02-07-2007 11:52 PM
girder & header sizing pesh Framing 5 10-09-2006 11:10 AM
Top mounted hangers against fire rated plywood, do studs and joists need to line up? personalt Carpentry 2 08-20-2006 04:24 PM
