Getting The First Floor Perfectly Level...
Old 04-30-2006, 01:21 PM   #1
OntarioFramer's Avatar
Trade: Rough Carpentry
All framers know the importance of getting the first floor really level after capping since a 1/4 inch problem on the first floor could become a 2 inch difference come roof. I've always used a transit to find the highest point as a reference and get every corner to that highest point. I've seen guys level the first floor with as much success without the transit. Any of you guys have better mothods than me or things that i should try since using the transit is the only method I've every been taught and used
OntarioFramer is offline
Old 04-30-2006, 04:14 PM   #2
Custom Builder
Glasshousebltr's Avatar
Re: Getting The First Floor Perfectly Level...
I use a time machine, then go back in time to the fella pouring the footers and foundation.....then kick him in the ars.
Bob
Bob
Glasshousebltr is offline
The Following User Says Thank You to Glasshousebltr For This Useful Post:
FramingPro (01-06-2011)
Old 04-30-2006, 05:58 PM   #3
ricpacer69's Avatar
Bob
You better watch out, his head is probably up there too!
Do you know the muffin man?
www.rhcontracting.net
ricpacer69 is offline
Old 04-30-2006, 09:09 PM   #4
fettycan's Avatar
Trade: roofer
we use a dry line from mud plate to mud plate then jack beam to line its simple . (mud plate is 2/8 on top of block)
fettycan is offline
Old 04-30-2006, 09:31 PM   #5
ABLE1's Avatar
This is not exactly on topic but close and also funny.
When my Dad was building his house in 1955 he did a lot of the work himself. After the excavator dug the hole and footers Dad put forms in the footers leveled and screeded off. When the block layers showed up they were amazed by such a level flat footer. They remarked that they never laid block on a level footer before.
After all block was laid and the block layers had gone my Dad started on the cap and framing. He was amazed that he had to build up one corner by over 2" to get the floorl level.
I guess it is necessary to start out UN-level to end up Level????
Have a good day getting it level.
Les
ABLE1 is offline
Old 05-04-2006, 08:19 PM   #6
never leave
trianglecustom's Avatar
Trade: General Contracting
bring me a perfectly straight 2x4 off the pile....ill keep it in my truck and frame the Pentagon.
trianglecustom is offline
Old 05-04-2006, 09:19 PM   #7
joasis's Avatar
Can't tell where this thread is heading, but I use the transit for location and the laser for level. I can set all my grade pins with no help and check them as needed. I have heard pro and con on lasers, but I'm sold on them and their accuracy is great.
Kind of a past way of doing it was the water level...funny thing is I see them for sale again. The first slab I helped pour was set with a water level...and I remember watching a block layer use one...I have no idea why he wasn't using a string line.
joasis is offline
Old 05-05-2006, 09:39 PM   #8
Dan
ApgarNJ's Avatar
Send a message via AIM to ApgarNJ
my mason is pretty much right on, all the way around, so we just frame the floor right on that and right on up. never had any issues with anything being way off later on.
ApgarNJ is offline
Old 05-06-2006, 08:14 PM   #9
Chris
cjc21021's Avatar
Trade: Starting Company/ College Student
Since still being wet behind the ears it was just yesterday (last year) that I learned to level the first floor with a builders level. Find the highest corner and make the others equal. Pretty simple.
cjc21021 is offline
Framing Roof Joists for Addition when top Plate is not Level personalt Framing 3 07-20-2007 06:52 AM
PM, Man Days, and Water Level? WNYcarpenter Carpentry 9 04-28-2007 07:07 PM
level decks on the top floors adman1900 Carpentry 1 11-11-2006 11:20 AM
Stabila Plate Level? dayspring Tools & Equipment 7 09-14-2006 12:44 AM
