carpenter and builder
Trade: carpenter and builder
Garage Roof
I've got to put a cut roof on a friends garage and wonder what size cieling joists and rafters you might use.
The garage is 30' X 20' and is to have a straight hipped roof. There is a beam centrally lengthways so max joist span is 10'. Pitch is around 35 deg and it will have a clay tile roof. I figure to run purlins at mid span of the rafters and strut down to the central beam. The rafters need to be at 16" centres. From other roofs i've done I reckon 6x2 joists and rafters will do it but would be interested in what you guys think. Thanks, Nick
Dont give me problems, give me solutions. |
Trade: carpenter
Re: Garage Roof
To be right up front, I have never made a roof like this yet. But that said, I was thinking along the same lines - 2x6 rafters and joists, and 2x4 struts. Instead of purlins, I was thinking of 2x4 ridge posts.
I assume theres a post in the middle of the garage, between the two car bays. Or is it three car bays? What's the layout of a 20 by 30 garage? ![]() Only reason the joists need to be 2x6 is because people put stuff up there in the pseudo "attic" and kids climb up there. Otherwise it's a tension member only, not a beam, and could even be a cable. Last edited by karma_carpentry; 03-28-2006 at 05:53 PM. |
Capitalist
Trade: Framing Sub/Building Contractor(Custom Homes)/Dock Builder
Re: Garage Roof
man always check a span chart. There is one online and you just punch in what you are doing, figure worst case if your not paying for materials(snow/tile) and go at it. Its something like national lumber ass. or something.
| Low Pitch Roof solutions | Fixer | Roofing | 4 | 02-18-2007 11:09 AM |
| Help tying in this roof to addition | jaymay75 | Framing | 0 | 06-18-2006 10:54 PM |
| Flat roof over garage leaking under exterior walk out door | IHI | Roofing | 18 | 05-30-2006 10:28 PM |
| Torch down(flat roof) leaks BAD...can you give advice ASAP? | Detail Guy | Roofing | 21 | 01-16-2006 02:36 PM |
| Do You Need A New Roof ??? | Perfect Roofing | Roofing | 0 | 02-10-2005 02:46 AM |
