Gambrel Roof Framing
Old 02-21-2012, 09:10 PM   #1
904sorock
904sorock's Avatar
Trade: General Building Contractor
Rewards Points: 75
Building a gambrel roof 14 ft X 20 ft.First time tackling one of these. There are many ways to frame this. Do gussets really provide good strength? Should they be of 1/2 or 3/4 plywood. with or without construction adhesive. Thanks for the input! SM
904sorock is offline
Old 02-21-2012, 09:19 PM   #2
Nail-Bender
Brutus's Avatar
Rewards Points: 2,020
Re: Gambrel Roof Framing
I didnt use gussets or glue the two times I did them.
Where would you be using either of those in a roof........................
Originally Posted by 2ndGen
If you haven't bled while working once in your life, you haven't worked!
Brutus is offline
Old 02-21-2012, 09:20 PM   #3
sevonty's Avatar
Trade: carpentry
Rewards Points: 75
gussets really do work, ask anyone who has ever walked the bottom cord of a 60' 2x4 truss. I have always used solid 2x material at the joint spaced evenly across the miter. the rafter should be self sustaining but codes are different when it comes to this.
sevonty is offline
Old 02-21-2012, 11:37 PM   #4
CAD Services
wallmaxx's Avatar
Trade: So done with this place...
Rewards Points: 144
Can you timber frame it? There are all kinds of cool joinery techniques that were used in barn building, back in the day, that would be fun to do.
wallmaxx is offline
The Following User Says Thank You to wallmaxx For This Useful Post:
Cole (02-22-2012)
Old 02-21-2012, 11:46 PM   #5
904sorock
904sorock's Avatar
Rewards Points: 75
I would be to costly to timber frame it wouldnt it?
Old 02-22-2012, 12:26 AM   #6
Fire up the BBQ
griz's Avatar
Rewards Points: 18
Yes
Use gussets and glue.
griz is offline
Old 02-22-2012, 01:01 AM   #7
904sorock
904sorock's Avatar
Rewards Points: 75
Originally Posted by griz View Post
Yes
What city in CA are you out of GRIZ?
Old 02-22-2012, 08:24 AM   #8
Aureli Construction
aureliconstruct's Avatar
Rewards Points: 75
I use wood and glue.
www.aureliconstruction.com
aureliconstruct is offline
Old 02-22-2012, 09:45 AM   #9
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Framing, siding, decks
Rewards Points: 10,396
Haven't made one in years but I learned 1/2" osb and pepper that **** with 1 3/4 roofing nails.
A&E Exteriors is offline
Old 02-23-2012, 11:32 PM   #10
CAD Services
wallmaxx's Avatar
Rewards Points: 144
It's a 14' x 20' "shed". It won't be all that expensive. Do something distinct and memorable.
I helped my best friend's dad build one from recovered free lumber.
Gambrel Roof Framing-bent-004.jpg   Gambrel Roof Framing-assembly-012.jpg   Gambrel Roof Framing-dsc02906.jpg
wallmaxx is offline
Old 02-23-2012, 11:40 PM   #11
Dirtywhiteboy's Avatar
Rewards Points: 7,614
This is top secret, no no really knows where Why He11 I don't even think he's in California maybe St. Pete. Fla.
Dirtywhiteboy is online now
griz (02-23-2012)
Old 02-23-2012, 11:57 PM   #12
CAD Services
wallmaxx's Avatar
Rewards Points: 144
I will try and find some timber framing for gambrel roofs
wallmaxx is offline
Old 02-24-2012, 06:47 AM   #13
General Contractor
greg24k's Avatar
Rewards Points: 7,024
If plywood is used, the rule of thumb is 3/4" to match the thickness of the sandwiched rafter. With that said, when designing Gambrel roof it's very important to consider wind load and other load factors, because of the odd angled shape and not having ceiling collar ties, you have increased chance for rafter movement under WL, LL and DL, so the gussets must be sized correctly, if not your roof will fail.... Let's say you have a large building span and your ridge beam location lets say 11'+ high, you will need a gusset which will extend anywhere from 18-24" on each side and they should be nailed 4"OC etc and each case will be different so a smart thing to do is have an Architect design your roof and gusset design.
greg24k is offline
Old 02-25-2012, 01:26 PM   #14
Raawwwrrrr
blackbear's Avatar
Trade: finish carpentry
Rewards Points: 1,394
I stick framed this one many years ago. Went off architects drawings and did a mock of the roof on the deck before went into production cutting mode. Was one of my last framing gigs. Good times
Didnt use any glue though
blackbear is offline
The Following 3 Users Say Thank You to blackbear For This Useful Post:
Brutus (02-25-2012), Dirtywhiteboy (02-25-2012), wallmaxx (02-25-2012)
Old 02-25-2012, 01:51 PM   #15
Nail-Bender
Brutus's Avatar
rawr, looks good blackbear
heres one I did in trade school, weird angle, but it was for the portfolio we had to do.
Brutus is offline
Old 02-26-2012, 06:02 PM   #16
Forming and Framing
FramingPro's Avatar
Trade: Shell builder
Rewards Points: 3,582
damn. i wanna make one now
Im after fortune and frame
http://www.proicf.com
FramingPro is offline
Roof Framer's Bible Framing A Bay Window Roof sbebuilders Framing 25 06-28-2015 09:28 PM
Framing Documents To Die For NC2X4 Framing 33 09-17-2010 11:45 AM
Mansard Roof Framing jesuscowboy Framing 5 08-25-2008 10:28 PM
Help tying in this roof to addition jaymay75 Framing 0 06-18-2006 10:54 PM
Flat roof framing red_cedar Framing 3 02-28-2006 10:48 AM
