Gable Wall Framing
Old 02-15-2012, 06:40 PM   #1
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 828
Gable Wall Framing
When doing tall balloon walls how does everyone go about the gable walls? I used the construction master to figure the rise every 16 inches for the roof pitch and started cutting. Worked well. We did not have room to build them and then stand them. The one wall was 12' on one end up to 25' on the other.
Just curious for other methods.
overanalyze is offline
Old 02-15-2012, 06:43 PM   #2
Gen. Contractor
Ninjaframer's Avatar
Trade: Residential Light commercial
Rewards Points: 2,602
Re: Gable Wall Framing
You know that calculator has a rake wall function right?
"slow makes smooth, smooth makes fast"
Ninjaframer is offline
The Following User Says Thank You to Ninjaframer For This Useful Post:
Seven-Delta-FortyOne (02-15-2012)
Old 02-15-2012, 06:44 PM   #3
Always Learning
Rewards Points: 828
...I do now..lol...I will have to dig up the manual now.
Old 02-15-2012, 07:15 PM   #4
Forming and Framing
FramingPro's Avatar
Trade: Shell builder
Rewards Points: 3,582
i build my rake walls to the underside of the sheathing so...
i measure my wall height on each end of the wall. then the HAP on both sides. and on the far side measure the rise on top of the hap and snap your lines. put your plates down make sure your end studs are parallel and then fill in your regular studs. mark 2 bottom plates. use one on the bottom and one top to keep the shoulders good and use it to transfer your layout. Mark the studs in place. cut nail. sheath and overhang.
bam
or measure your wall height on each side and trace your rafters. fool proof
Im after fortune and frame
http://www.proicf.com
FramingPro is offline
Old 02-15-2012, 07:16 PM   #5
Always Learning
Rewards Points: 828
I looked at my manual. Time for a new construction master. I have an older one that does not have that feature. I saw that they sell an app for my droid that is from the same company.might give that a try.
Old 02-15-2012, 07:47 PM   #6
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 6,463
I just figure the math. Call me old fashioned. It keeps my mind Sharp.
Easy Gibson
Warren is online now
Old 02-15-2012, 08:11 PM   #7
Dirtywhiteboy's Avatar
Rewards Points: 8,006
Attachment 65738
Sounds good all I could add is to layout the top plate and when you have all your studs cut line the kit up and mark your 8' and 16' block line and you can nail the block on before you stand it up.
Dirtywhiteboy is offline
overanalyze (02-15-2012)
Old 02-15-2012, 09:43 PM   #8
Gen. Contractor
Right above the rise button
Old 02-15-2012, 10:06 PM   #9
Always Learning
Rewards Points: 828
Mine is a construction master 3...old...no rwall button. Just downloaded buildcalc for my android. That has it as well as some sweet stair layout tools. I was able to get my calcs to work on my old calc just had some extra steps.
Old 02-16-2012, 08:58 PM   #10
Rewards Points: 746
We don't do any math anymore except for calculating the topplates, which is the same length as the rafter.
So often here the deck it too wet to snap it out, so we frame the perimeter of the wall and measure in the studs. It is slower, but we find it easier.
If the wall is framed after the fact, we'll use a laser plumbbob to get the studs laid out.
Timuhler is offline
Old 02-16-2012, 09:22 PM   #11
Forming and Framing
FramingPro's Avatar
i learned how to build them from you and your pics
The Following User Says Thank You to FramingPro For This Useful Post:
Timuhler (02-16-2012)
Old 02-16-2012, 09:24 PM   #12
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
ohiohomedoctor is offline
Old 02-16-2012, 09:32 PM   #13
CAD Services
wallmaxx's Avatar
Trade: So done with this place...
Rewards Points: 144
I CAD everything
Gable wall framing-ocean_home_lindal-236.jpg   Gable wall framing-dsc00013.jpg   Gable wall framing-dsc00026.jpg
wallmaxx is offline
The Following User Says Thank You to wallmaxx For This Useful Post:
Blackfly (02-17-2012)
Old 02-16-2012, 09:38 PM   #14
CAD Services
wallmaxx's Avatar
Rewards Points: 144
like this
Gable wall framing-lake-samish-lindal-001-402-details.jpg   Gable wall framing-camelot-ii-rake-wall.jpg
wallmaxx is offline
Old 02-16-2012, 09:41 PM   #15
Originally Posted by wallmaxx
like this
Is that sketchup?
Old 02-16-2012, 09:42 PM   #16
Forming and Framing
FramingPro's Avatar
Originally Posted by ohiohomedoctor View Post
Is that sketchup?
read post 13
Old 02-16-2012, 10:06 PM   #17
CAD Services
wallmaxx's Avatar
Rewards Points: 144
AutoCAD 2007 / 2010
Sometimes SolidBuilder or Softplan. I haven't really learned Sketchup. Some guys here are masters at it.
I'd like to try Chief some day.
wallmaxx is offline
Old 02-16-2012, 10:21 PM   #18
Gary H's Avatar
Rewards Points: 2,342
That is cool.
Gary H is offline
Old 02-16-2012, 10:29 PM   #19
go do it's Avatar
Trade: general contracting
Rewards Points: 258
i get my stud lengths from my framing square
tells you how much difference to add for whatever rise
go do it is offline
Old 02-17-2012, 11:48 AM   #20
KennMacMoragh's Avatar
Trade: Repair/Remodel
Rewards Points: 3,168
I've done it the same way as you basically. If it's an easy pitch then it's easy to do the math in your head, a 6:12 roof and you cut each stud 8 inches longer. Another way you can do it, I haven't tried this, but snap out the rake wall on the floor, put in your fire blocking but only nail one side of the block on each bay, then take your saw and sight down the chalk line and make each cut by eye, you don't even have to adjust the bevel on your saw. Then finish nailing off your blocks. Ask if they want one or two top plates on your rake wall as well. Code allows just one top plate on a rake wall, but some people prefer two.
kenparsonscontracting.com
KennMacMoragh is offline
Up Against A Brick Wall Meticularius Introductions 5 09-28-2011 05:06 PM
Pressure treated lumber for interior wall framing WJTR Framing 38 06-24-2011 05:41 PM
Major wall frame remodel Jackpine Framing 0 09-03-2008 09:06 AM
removing a retaining wall Cache Excavation & Site Work 30 07-16-2008 04:57 PM
Framing a 60 ft wide x 18 ft high wall crno_gorac Framing 45 11-22-2007 04:55 AM
