#141 | |
KemoSabe
Re: Gable StudsQuote:
__________________________________ "Walking the fine line between production and perfection" __________________________________ |
#142 |
The great cornholio
Trade: Framing/ICF
Re: Gable Studs |
#143 |
Custom Builder
Re: Gable Studs
Yes, then run outriggers to barge. Most of the eves we do are 16 in plus, 80 % of the houses I do are 2 ft to 3 ft eves so the outriggers are 2ft oc 2X4 or 4 ft oc 2X6 flat, or i drop the rake and run 2X on edge. The house were on now has 2X8 on edge 24 in oc A 35 to gable rafter a35 rafter to wall, lots of outlooks. Alot of our eves are exposed here to.
#144 |
The great cornholio
Trade: Framing/ICF
Re: Gable Studs
Ok so for my shed I want a cathedral ceiling to save on ceiling joists and stuff so I need to make my ridge loadbearing so it does not push the walls out because the ridge carries the load..over an 8 foot span would 2 2 x6s be ok?
#145 |
Custom Builder
Re: Gable Studs
lone,
I had thought about that cause it would make a closed cavity, but when I drop my rake I would have to rip the rafter or cut outlooks in so ive just stuck with a gable rafter. 6 of one half dozen of another with live outlooks |
#146 |
The great cornholio
Trade: Framing/ICF
Re: Gable Studs
why would you have to rip your gable rafter
#147 |
Custom Builder
Re: Gable Studs
To let my outlooks go over the top, they would either get ripped or more likely notched for outlooks.
#148 |
The great cornholio
Trade: Framing/ICF
Re: Gable Studs |
#149 |
Custom Builder
Re: Gable Studs
If I was using 2x12 rafters and was running my outlooks over the rake wall the rafter that lone said to put in against the wall would either need to be notched for the outlooks or just ripped down 1 1/2 or what ever we where running for outlooks.
#150 |
The great cornholio
Trade: Framing/ICF
Re: Gable Studs
O true sorry i couldn't figure it out
#151 |
Trade: Framing,Remodeling,General Contractor
Re: Gable Studs
You don't need anything special for a ridge
#152 |
The great cornholio
Trade: Framing/ICF
Re: Gable Studs |
#153 | |
The great cornholio
Trade: Framing/ICF
#154 |
Re: Gable Studs
You said a shed? How big? I have never used a double anything for a ridge that I remember
#155 |
The great cornholio
Trade: Framing/ICF
Re: Gable Studs |
#156 |
KemoSabe
Re: Gable Studs
If you rip 'em, you lose the draft stop, rendering it a waste of time and money.
#157 |
The great cornholio
Trade: Framing/ICF
Re: Gable Studs |
#158 | |
The wall is stiffer framing it all the way up instead of to the rafter. |
| The Following User Says Thank You to Timuhler For This Useful Post: | FramingPro (02-08-2010) |
#159 | |
The great cornholio
Trade: Framing/ICF
#160 |
KemoSabe
Re: Gable Studs
Get yourself a box-O-gangnailers and build trusses, no ridge to deal with at all.
| Removing studs from a load bearing wall. | Russ25nys | Framing | 36 | 06-13-2009 09:52 PM |
| Extending 4" studs to 5 1/2" | Danno6102 | Carpentry | 18 | 05-29-2009 07:38 PM |
| Attaching wood studs to metal studs | AlSmith | Framing | 13 | 05-16-2009 11:58 PM |
| Grab bars - studs and spec hollow wall anchors | jmfrederick | Plumbing | 5 | 12-13-2008 01:12 PM |
| seal gable vents after ridge vent installed? | tacoma5050 | Roofing | 26 | 01-18-2008 10:50 PM |
