#121 |
The great cornholio
Trade: Framing/ICF
Re: Gable Studs
But it is ok if you build them to the bottom of the rafter aswell? And your saying as long as i nail it to the wall alot and it is held at the fascia it won't shear off?
#122 |
Trade: framing/remodeling
Re: Gable Studs |
#123 |
The great cornholio
Trade: Framing/ICF
Re: Gable Studs |
#124 | |
KemoSabe
Re: Gable StudsQuote:
I have never built them that way, due to the fact that I never had access to use a lift efficiently on the properties I've worked on. All my ridges get set first and the gable pins typically get notched onto the gable rafters. Just the way I learned and became efficient at.
__________________________________ "Walking the fine line between production and perfection" __________________________________ |
#125 | |
The great cornholio
Trade: Framing/ICF
#126 |
KemoSabe
Re: Gable Studs
Permanently disabled, not my buddy, but someone on his crew. I didn't know the guy myself.
#127 |
The great cornholio
Trade: Framing/ICF
Re: Gable Studs |
#128 | ||||
The great cornholio
Trade: Framing/ICF
![]() In the picture above i notice a pocket for the ridge but i notice part of the piece of the ladder on the wall covers the end..do you need to remove it so you could extend the ridge to hold the barge rafter or does it not matter |
#129 |
The great cornholio
Trade: Framing/ICF
Re: Gable Studs |
#130 |
KemoSabe
Re: Gable Studs
Situations like what happened to that guy are why I started sheathing my walls after they are standing. I've seen several walls get taken off the building by the winds that prevail along the coast. They can blow up out of nowhere and cause problems quickly. Many of the buildings are only 8' apart and I've seen some exterior stairways get crushed by lost walls. I also know of several buildings that blew completely over due to the roofs being sheathed before the walls. I always get my walls up to the roofline, then sheath them up before starting the roof framing. This is the only time I can remember framing the roof before sheathing the walls.
#131 |
The great cornholio
Trade: Framing/ICF
Re: Gable Studs |
#132 |
Re: Gable Studs
Wouldn't framing to the sheathing cause a shrinkage issue? The vertical wall wont shrink like the rafter will.
#133 |
The great cornholio
Trade: Framing/ICF
Re: Gable Studs |
#134 | |
KemoSabe
#135 |
Re: Gable Studs
I wouldnt sheath to the top of the gable either. Leave it short like gapping walls and floor breaks.
#136 |
Trade: Framing,Remodeling,General Contractor
Re: Gable Studs
What is going to shrink?
#137 |
David Festa
Trade: Framing Contractor
Re: Gable Studs
Sorry guys I was on a few estimates, anyway
Framepro for being 13/14 you got some spunk, I like that. When you turn 18[by then the market will be booming again] come to jersey, I’ll put ya to work. Tim good job, how long does it take to frame the gable wall your way verse stick framing, then sheath after?
Addition Contractor Bayville Home Addition Monmouth Beach NJ Contractor Jackson NJ “Photography is not art, It’s just a Xerox of what just happened” |
#138 | |
The great cornholio
Trade: Framing/ICF
#139 |
Custom Builder
Re: Gable Studs
What do you guys do about draft stops from walls to rafter bays. I framed my rake walls to bottom of sheething on one house a few years ago, thought i was slick skipping a step, then the inspector made me fire block at ceiling height. Not fun 6200 sq ft of house alot of blocking up in the air.
Haven't tried it again since.
#140 | |
The great cornholio
Trade: Framing/ICF
| Removing studs from a load bearing wall. | Russ25nys | Framing | 36 | 06-13-2009 09:52 PM |
| Extending 4" studs to 5 1/2" | Danno6102 | Carpentry | 18 | 05-29-2009 07:38 PM |
| Attaching wood studs to metal studs | AlSmith | Framing | 13 | 05-16-2009 11:58 PM |
| Grab bars - studs and spec hollow wall anchors | jmfrederick | Plumbing | 5 | 12-13-2008 01:12 PM |
| seal gable vents after ridge vent installed? | tacoma5050 | Roofing | 26 | 01-18-2008 10:50 PM |
