Fun With Wood X-bridging
Old 11-14-2009, 10:28 AM   #81
ClemS's Avatar
Trade: Framing
Re: Fun With Wood X-bridging
Originally Posted by loneframer View Post
Let me know when you get that next big frame lined up, I'll try to work out a weekend if it works with your schedule. I'm itching to get on a woodframed project. I can still hang with you young whippersnappers.....I think.
brace yourself you may be in for some unusual techniques the architects around here are.... ummmm.. leaving a lot to be desired
i have a set of plans for a job we'll be doing beginning to mid december. the roof line is a mess. bearing walls and point loads flying wild. walls being built on brick ledges..... i've been trying to get the man on the phone all week to feel him out, he's unavailable for comment. almost looks like he died right after he drew these things. either that or he's just a jerk and screens his calls for obnoxious framers
ClemS is offline
Old 11-14-2009, 10:31 AM   #82
ClemS's Avatar
Trade: Framing
Lone,
I think its cool you are doing this. But for me, I'm sticking with the full floor testing that has been done and the data measured. If they say bridging doesn't add significantly, then that's enough for me.
Our engineer emailed me back with the following:
guess they don't consider nail pops in the sheetrock, an effect. i'm with lone 100 percent. if someone who built 100 houses tell me one thing, and someone who built none has a different opinion. tough sh*t, i'm going with whatever EXPERIENCE tells me. not a piece of paper.
ClemS is offline
Old 11-14-2009, 10:36 AM   #83
KemoSabe
loneframer's Avatar
Lone,
Tim, I agree that at a 12' span, there may be no improvement in floor performance. However, many of the homes I frame are designed with maxed out spans where increasing joist depth will create problems with maintaining a minimum pitch on the roof. (Yes, they push the limits with height restrictions to the point that I've had to cut studs down 4" on both floors to get a 3.5/12 in some cases.) I also know that with spans of over 14' with a Hem/Fir 2x10, drywall has little effect of preventing deflection of a single joist at midspan when a 300 pound homeowner walks across the floor. Seeing this with my own 2 eyes prompted me to start using wood bridging. I could hear the metal bridging moving under foot and saw the deflection of the joists. We are required by local inspectors to install bridging midspan on anything unsupported over 8'. I've never known any different. I joists are the exception, but they must be strapped at the least if no ceiling is attached. I've seen conventional lumber do some crazy things as it stabilizes, bridging minimizes the amount of movement that occurs if nothing else.
loneframer is offline
Old 11-14-2009, 10:42 AM   #84
KemoSabe
loneframer's Avatar
How many F-bombs did you drop during your initial message? Maybe he's seaking protective custody.
Old 11-14-2009, 10:42 AM   #85
ClemS's Avatar
Trade: Framing
i wonder if and when they test their floor assemblies they actually let a 300lb douchebag parade around the deck for several years and see if he likes the feel
ClemS is offline
Old 11-14-2009, 10:47 AM   #86
ClemS's Avatar
Trade: Framing
none but he sounds like a fruit on his answering machine. i like to get them before i actually start working because if they're easy about making amendments then the job goes smoother for me. i don't really like to drag them out and make idiots out of them at the jobsite because then they feel threatened and start acting like little girls. the house i did where i hung all the tji's off the steel, the architect kept insisting that you DON'T need steel structure under brick veneers that fly over a roof. he said brick doesn't weigh that much and a steel angle bolted to the house is plenty strong.... what do you think?
ClemS is offline
Old 11-14-2009, 10:58 AM   #87
KemoSabe
loneframer's Avatar
Aside from wall ties and steel angles over openings, I think brick veneer should remain independant of the framing structure. A brick shelf incorporated into the foundation for bearing. What do I know though, I've only been in this game for 25 years.
Old 11-14-2009, 11:06 AM   #88
ClemS's Avatar
Trade: Framing
thing that got me was, i just did a job where we had to open up a good section of the roof, remove the veneer, drop a piece of steel in and patch things up. if that's not a testimony as to how things should be done to begin with, what is? a piece of paper from someone who's having a hard time drawing the things we're building with ease?
ClemS is offline
Old 11-14-2009, 11:14 AM   #89
KemoSabe
loneframer's Avatar
Just goes to show you, there is no education that compares with field experience. Calculations dictate what should work, real life scenarios dictate what actually does.
Old 11-14-2009, 11:16 AM   #90
ClemS's Avatar
Trade: Framing
goes to show me i should have been an architect. i could have been screening my calls RIGHT NOW
ClemS is offline
Old 11-14-2009, 11:25 AM   #91
KemoSabe
loneframer's Avatar
Both of my sons are very math minded. I'm leaning on them to pursue fields in engineering as well as architecture. They have to answer the phone when I call.
Old 11-14-2009, 11:57 AM   #92
The Deck Guy
Greg Di's Avatar
Lone,
Tim, is the under joist sheathing the engineer talking referring to applicable to drywall? It must be...I mean, who sheathes a ceiling, but then again, how does drywall have any strength in terms of pull through and such?
Greg Di is offline
The Following User Says Thank You to Greg Di For This Useful Post:
TimelessQuality (11-14-2009)
Old 11-14-2009, 12:12 PM   #93
KemoSabe
loneframer's Avatar
Another member sent me a link to this video. Thanks.
+ YouTube Video
http://www.youtube.com/watch?v=R_OF9KgWhzI
Old 11-14-2009, 12:21 PM   #94
solar guy
naptown CR's Avatar
Trade: solar contracting
Interesting video
I cannot imagine how labor intensive the last system would be unless you bought the bridging from the guy. But what about odd spacings etc.
The biggest difference is that the nails or screws are in shear and not pulling out.
I also agree with the other posts above that bridging will reduce bounce.
The jury is however out on what it adds to the ultimate strength of a floor structure.
naptown CR is offline
Old 11-14-2009, 12:41 PM   #95
Joe Carola's Avatar
Trade: Framing Contractor
Originally Posted by naptown CR View Post
I cannot imagine how labor intensive the last system would be unless you bought the bridging from the guy. .
I set up a jig with a floor joists, piece of 2x6 and a piece of 5/4 and some 10d nails. I set the debth of the saw, the angle of the bridging and set the piece of 5/4 to the table of the saw nailed on top of the 2x6.
1) Take a floor joist and lay on the horse.
2) Nial a 1' piece of 2x6 flush to the bottom of the 2x10 about 2' in from the right side.
3) I sit the saw on top of the 2x6 set the angle of the bridging and set the debth of the saw so the depth touches the 2x10 and the bottom of the balde touches the bottom of the 2x6 holding the saw square and scribe the left side of the table of a sidewinder (right side blade).
4) Nail an 8" piece of bridging on that mark.
5) Butt my tape against the bottom of the 2x6 and measure to the right the length of the 5/4 bridging and tack 2- 10d nails in.
6) On the left side of the 2x10 I tack a couple 10d nails 5-1/2" up from the bottom to equal the 1' 2x6 I have nailed in for the bridging to slide across.
7) Take 16' length of 5/4x3 bridging and slide from left to right with the saw in my right hand I slide the saw up and cut the first cut. Slide the 5/4 until it hits the two nails I have tracked at the length of the bridging and sklide the saw for the second cut and the bridging is now cut to length and pops off the 2x10.
I just keep sliding the bridging until it hits the 2 10d nails and sliding the saw and just keep cutting. It goes extremely fast and not one measurement. Just keep sliding the saw and cutting.
The jig takers a couple minutes to set up. This for me is the fastest way to cut bridging. When you cut through with the saw, you just turn the saw to the right slightly and the piece of bridging pops off.
Joe Carola
Joe Carola is offline
The Following User Says Thank You to Joe Carola For This Useful Post:
smeagol (11-14-2009)
Old 11-14-2009, 12:45 PM   #96
smeagol's Avatar
Trade: new construction and remodeling
Loneframer, you should test bridging with a 4"x6" piece of 1/2" ply sandwiched and stapled between the 1x3s perpendicular to the joists. I would guess on a 480lb breaking strength
smeagol is offline
Old 11-14-2009, 12:51 PM   #97
KemoSabe
loneframer's Avatar
Interesting video
I agree that a floor is only as strong as the joists overall, but it is undeniable that point loading a single joist in midspan will cause deflection. I advocate that bridging forces loadsharing of the adjacent joists, nothing more.
Old 11-14-2009, 01:54 PM   #98
Joe Carola's Avatar
Naptown,
Here's a drawing of the top view of the bridging jig.
Joe Carola
Old 11-14-2009, 02:03 PM   #99
KemoSabe
loneframer's Avatar
I always have a chopsaw table set up to cut wall parts. It takes about 30 seconds to set a stop block for bridging. I stand up 5 or 6 12' lengths of bridging material and gang cut them. It takes very little time to cut enough for the whole house. If I have more than one house under contract with the same builder, he will usually send out enough stock for several homes and bundle them for storage.
Old 11-14-2009, 02:11 PM   #100
Originally Posted by Joe Carola View Post
Naptown,
Cool Joe!
What I can't get over is....
once upon a time, in the primitive days,
I just ordered it with the lumber package.
neolitic is offline
Thermally Modified Wood Live test results naturalwood Decks & Fencing 0 09-17-2009 07:06 PM
Commercial wood framing mckellarman Commercial Construction 2 05-06-2009 06:11 PM
LEED Certified Wood CF Construction Business 6 02-27-2009 04:45 PM
Covered Patio 10 x 10 - Should I wood block? gussy1971 Roofing 1 01-27-2009 06:19 PM
Buckled Wood Floor LNG24 Flooring 2 11-17-2008 11:35 PM
