Fun With Wood X-bridging
Old 11-13-2009, 10:05 PM   #61
Jeff
jkfox624's Avatar
Trade: master turd burglar
Re: Fun With Wood X-bridging
Originally Posted by ClemS View Post
i'd say. you won't see me doing that though. too labor intensive.
bridging definitely stiffens the floor. does it have load bearing properties? no. it's a good practice to take some bounce off the joist. the other advantage is that under heavy loads bottom of the joists tends to want to kick out. bridging prevents that from happening. so does rim board and intermediate blocking.
Agreed just figuring if we're gonna blow loneframers date budget we might as well go all out for our entertainment.
jkfox624 is offline
Old 11-13-2009, 10:08 PM   #62
Jeff
jkfox624's Avatar
what do you gents think about web stiffeners (better known as squash blocks) for tjis?
My thought is if i got a load point that needs em use em. Im sure im not fully understanding your question though.
jkfox624 is offline
Old 11-13-2009, 10:10 PM   #63
ClemS's Avatar
Trade: Framing
manufacturer's not too clear on WHEN to use them. and then they tell you to cut the block 1/8" to 2-3/4" short. that's a broad range. i've always made them tight and always blocked all ends and mid bearings. seems a good practice being that the beams are made of junk. every little bit helps
ClemS is offline
Old 11-13-2009, 10:16 PM   #64
KemoSabe
loneframer's Avatar
I think they are time consuming if nothing else. We've done a few floors with TJIs cantilevered. That detail is costly. Rimboard and full height hangers virtually eliminate the web stiffener requirement, although we still put them in some cases. Framing roofs with TJIs is another story of blown budgets.
loneframer is offline
Old 11-13-2009, 10:29 PM   #65
ClemS's Avatar
Trade: Framing
yea cantilever can be a bitch. i did a roof raise beginning of this year. the architect wanted me to cantilever 2'-7" feet off the back. i called him and told him to come by the job. said you can't hang these f'ing things out over two feet to carry roof. he disagreed and said they're plenty big to hang out further than that (9.5")........................ what do i know?
ClemS is offline
Old 11-13-2009, 10:32 PM   #66
I like Green things
WarnerConstInc.'s Avatar
I got what you were getting at Lone.
Every house I work on has bridging. I also think it may have been a way to keep the old timber straight after it was framed and it dried out.
Guy's, it's the buddy system. Like taping two toes together when you break one.
Originally Posted by Leo G View Post
Thanks for that tidbit of information Darcy.
Warner Remodeling ll Auburn Indiana Remodeling ll Dekalb County Remodeling ll Custom Woodworking Auburn Indiana
Warner Remodeling Facebook
WarnerConstInc. is online now
loneframer (11-13-2009)
Old 11-13-2009, 10:35 PM   #67
KemoSabe
loneframer's Avatar
9.5s at 2'7"? Roof load? Did you get his signature?
Old 11-13-2009, 11:28 PM   #68
ClemS's Avatar
Trade: Framing
nope, framed it and ran. his name on the plans, not mine.
ClemS is offline
Old 11-13-2009, 11:34 PM   #69
KemoSabe
loneframer's Avatar
I know I've never hung 'em out that far, that's crazy right there.
Old 11-13-2009, 11:50 PM   #70
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Well I think some of you boys with big ideas about how to do this thing different should break out the junk and get er done.
Come on boys, back away from the key board and pony up. You know who you are. There should be at least 3 or 4 more experiments by my count.
Could be fun
Gus Dering is offline
The Following 3 Users Say Thank You to Gus Dering For This Useful Post:
loneframer (11-13-2009), TBFGhost (11-15-2009), Winchester (02-26-2011)
Old 11-14-2009, 12:07 AM   #71
TimelessQuality's Avatar
Trade: GC/Remodeling
no doubt maybe at 8" oc...
Hey lone, thanks for spending the time documenting and sharing
You've got me.. I'll add that detail next time I use dimensional..
One question.. do you staple the upper point, or just wedge it in?
Good stuff man!
-Steve
"The most beautiful thing we can experience is the mysterious. It is the source of all true art and science." ~ Albert Einstein
TimelessQuality is online now
Old 11-14-2009, 12:12 AM   #72
Lone....Preacher.
Neo....Choir.
neolitic is offline
The Following User Says Thank You to neolitic For This Useful Post:
loneframer (11-14-2009)
Old 11-14-2009, 12:31 AM   #73
Gus Dering's Avatar
Good stuff man!
He went night night.
I'm certain he staples the top as he is sheathing and leaves the bottoms for a pickup item for the cleanup boy.
Old 11-14-2009, 02:42 AM   #74
hughjazz's Avatar
Trade: carpenter
when an i joist intersects another i joist I install full height blocking (fill the webs) usually with 1" plywood . Or the rim joist (1 1/8") Glued and stapled
This imo is a good practise because it keeps the joist firmly in the hanger with no chance of roll over.
On any point loads. The squash blocks are cut 1/16" longer than the joist itself. And placed where appropriate.
I've never installed a mid span web stiffener. (never had the plans tell me to.)
hughjazz is offline
Old 11-14-2009, 08:19 AM   #75
KennMacMoragh's Avatar
Trade: Repair/Remodel
Send a message via MSN to KennMacMoragh
I think you should test this on your house, put some bridging in your crawl space then keep stacking weights in the center of your living room.
KennMacMoragh is offline
Old 11-14-2009, 09:01 AM   #76
KemoSabe
loneframer's Avatar
Good stuff man!
Upper connection is stapled as well. During assembly of the floor sustem, I run out as much decking as possible, straightening the joists with the plywood. When I get to the bridging line, I simply strike a chalkline and staple in the bridging. On larger spans I like to run 2 rows 4' apart from eack other. As soon as the decking is complete, the botttoms get stapled in. By the time drywall goes in, the lumber has dried somewhat and typically shrinks at least 3/16 on a 2x10. It's amazing how stiff the floor feels underfoot. In 24 years of framing, I have never built a house using conventional lumber without some type of bridging. All builders require it as well as most municipalities. I have tried several types and after a couple hundred homes, I prefer this method over all others.
Old 11-14-2009, 09:19 AM   #77
KemoSabe
loneframer's Avatar
I've tested wood bridging over the last 10 years in every home I've framed. I've tried metal straps, they always lead to squeeks in my experience, always the result of joist deflection. I've tried solid blocks, they sometimes lead to squeeks, usually due to cupping of the lumber and to some degree shrinkage. Drive in metal works well, but IMO is more labor intensive than wood, especially when additional joists are added under partitions. Now you're flip flopping back to wood to finish the project.
I know wood X works, my advice is for the nonbelievers to take a few hours on the next conventional framing job and try it for yourself. I have nothing to gain by railing for wood bridging. I am offering advice on good practice on a floor system. I have been called back for other types of bridging, sometimes it's not the bridging, it's gaspipe, water lines, joist panning or central vac lines, but it's always the result of joist deflection. I've not gotten the callbacks for squeeky floors using wood X.
Old 11-14-2009, 10:10 AM   #78
ClemS's Avatar
Trade: Framing
you can piecework my bridging any day. just come on up with your little staple gun
ClemS is offline
Old 11-14-2009, 10:17 AM   #79
Lone,
I think its cool you are doing this. But for me, I'm sticking with the full floor testing that has been done and the data measured. If they say bridging doesn't add significantly, then that's enough for me.
Our engineer emailed me back with the following:
I don't know where to find the paper, however, the industry (engineering) says that it makes no to little difference for spans up to about 12-ft. It's a consideration only for cases like main floors over crawls or basements when there is no continuous sheathing attached to the bottom of the joist. If a ceiling is attached to the underside of the joist, then there is really no need or effect from its inclusion for any span lengths.
Timuhler is offline
Old 11-14-2009, 10:18 AM   #80
KemoSabe
loneframer's Avatar
Let me know when you get that next big frame lined up, I'll try to work out a weekend if it works with your schedule. I'm itching to get on a woodframed project. I can still hang with you young whippersnappers.....I think.
Thermally Modified Wood Live test results naturalwood Decks & Fencing 0 09-17-2009 07:06 PM
Commercial wood framing mckellarman Commercial Construction 2 05-06-2009 06:11 PM
LEED Certified Wood CF Construction Business 6 02-27-2009 04:45 PM
Covered Patio 10 x 10 - Should I wood block? gussy1971 Roofing 1 01-27-2009 06:19 PM
Buckled Wood Floor LNG24 Flooring 2 11-17-2008 11:35 PM
