#41 | |
KemoSabe
Re: Fun With Wood X-bridgingQuote:
__________________________________ "Walking the fine line between production and perfection" __________________________________ |
#42 |
Trade: framing/remodeling
Re: Fun With Wood X-bridging |
#43 |
Trade: Framing
the 1x3s will eventually creep and pull the staples out
#44 | |
solar guy
Trade: solar contracting
they are acting as a partial bottom chord in this case as the end joists are short and very stiff considering the spans. 2 dollah says the things collapses |
#45 |
KemoSabe
You almost got it right, the staples pulled through the firring strip bridging that has been out in the rain for 3 days.
I'm gonna do this again with 3/4 decking and 1x3 pine. 295lbs did it in. The OSB didn't fare well upon the staples pulling through either.
#46 |
Jeff
Trade: master turd burglar
Any close neighbors call the cops when it came crashing down? Dogs didnt go crazy, car alarms go off or anything?
#47 |
Trade: Framing
max out your credit card and buy a sheet of 3/4 cdx fir. try solid blocking. allegedly solid is the way to go. that's what i always do.
#48 | |
KemoSabe
A couple creaks and "KACHINGCLANGCLUNK". Nobody even came to their window to see if I was OK.
#49 |
Trade: Framing
allegedly metal x-bridging is a better connection than wood x-bridging. get some tji scrap and gear it up with metal x's. i wonder if the flanges will pull apart.
#50 | |
solar guy
Even if you use solid blocking if there is no chord on the bottom tensioning the structure the nails will start to pull. Tjhe only reason that experiment held together as long as it did was because of the blocks holding the very short end joists from spreading. Don't believe me repeat the experiment without the band blocking holding the two end joists together. I would be willing to bet that it fails much sooner. Nail a 2x to the bottom of the joists at the bridging and I bet it holds 4 times as much. |
#51 |
Al Smith
try the same rig with solid bridging. I'm wondering if the cross bridging out performs solid bridging due to end grain nail pullout.
#52 |
solar guy
You are correct simply because you are placing the nails that hold it together in shear and not pull out.
#53 | |
KemoSabe
#54 | |
Trade: Framing
2x by itself is likely to hold a good amount of weight without any x's. the whole point of what my south jersey friend is doing is to show that bridging adds rigidity to a floor system. he may also be showing off his staging gear a little.
#55 | |
Al Smith
I don't think the end joists were restrained by the lengths of 2 X 6 you see laying on the garage floor there. |
#56 | |
Trade: Framing
![]() hope you're using stainless steel staples on your ACQ boards |
#57 |
Jeff
#58 | |
KemoSabe
#59 | |
Trade: Framing
bridging definitely stiffens the floor. does it have load bearing properties? no. it's a good practice to take some bounce off the joist. the other advantage is that under heavy loads bottom of the joists tends to want to kick out. bridging prevents that from happening. so does rim board and intermediate blocking. |
| Thermally Modified Wood Live test results | naturalwood | Decks & Fencing | 0 | 09-17-2009 07:06 PM |
| Commercial wood framing | mckellarman | Commercial Construction | 2 | 05-06-2009 06:11 PM |
| LEED Certified Wood | CF Construction | Business | 6 | 02-27-2009 04:45 PM |
| Covered Patio 10 x 10 - Should I wood block? | gussy1971 | Roofing | 1 | 01-27-2009 06:19 PM |
| Buckled Wood Floor | LNG24 | Flooring | 2 | 11-17-2008 11:35 PM |
