Fun With Wood X-bridging
Old 11-13-2009, 08:57 PM   #21
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Re: Fun With Wood X-bridging
Originally Posted by jkfox624 View Post
I'm gonna guess it held a loneframer, the ballet instructor, a case of beer but failed when the pizza delivery guy slammed dinner down. If it wasnt for the 3 meat bonanza the ballet instructor had to have it might have held. And it failed at the anchor of the 2x6 first causing a chain reaction and alot of shook up beer.
If he had a woman willing to play erector set out in the cold night, on a Friday night, he would have a ring on that finger so fast he would be the Notloneframer.
Oh wait, we aren't much different playing with him on a Friday night are we?
Nevermind, as you were
Gus Dering is offline
Old 11-13-2009, 08:59 PM   #22
KemoSabe
loneframer's Avatar
Here is the deflection caused by 220 lbs.
loneframer is offline
Old 11-13-2009, 08:59 PM   #23
tgeb's Avatar
So....maybe you got bored with adding weight and ran into it with the truck parked outside??
www.gebcon.com
tgeb is offline
Old 11-13-2009, 09:01 PM   #24
Jeff
jkfox624's Avatar
Trade: master turd burglar
I tried to show my wife how to lay out a stair stringer the other night out of boredom. She went upstairs before i got my framing square out of the truck. And yes the suspense is killing me.
jkfox624 is offline
Old 11-13-2009, 09:03 PM   #25
solar guy
naptown CR's Avatar
Trade: solar contracting
Methinks you misunderstand the purpose of bridging
naptown CR is offline
Old 11-13-2009, 09:05 PM   #26
Jeff
jkfox624's Avatar
Why is that?
jkfox624 is offline
Old 11-13-2009, 09:06 PM   #27
DrewD's Avatar
Trade: Log Home Construction/College Student
Do the joist have end bearing or simply end nailed through the 2x? I guess I'm just no clear on what it is your exactly trying to prove. Do you want to see how much weight the system can support by transferring the load through the x-bracing and into the the saw horses or something else?
DrewD is offline
Old 11-13-2009, 09:08 PM   #28
Jeff
jkfox624's Avatar
Unless im mistaken hes trying to prove how x bracing makes a floor system act as 1 unit instead of individual pieces. Taking it to the point that the x bracing can support joists sitting on nothing.
jkfox624 is offline
Old 11-13-2009, 09:11 PM   #29
Gus Dering's Avatar
I'm thinking he is seeing if his scaffolding planks and pump poles can handle about 300 lbs falling about 4 feet straight down on them.
The Following User Says Thank You to Gus Dering For This Useful Post:
neolitic (11-14-2009)
Old 11-13-2009, 09:12 PM   #30
KemoSabe
loneframer's Avatar
Exactly. All the weight is being carried by the bridging essentially, transfered to the end joists. The field joists are not attached to the box or supported in any other way.
Old 11-13-2009, 09:12 PM   #31
Warren's Avatar
Trade: framing/remodeling
Upon further review, I think this "test" is flawed. In the real application, the joist would be supported on both ends as well as being tied together. How about a side by side test. Build 2 mini floor systems out of 2x4's and install bridging in one system. Then add the weight and see how much differently they perform.
Warren is offline
The Following User Says Thank You to Warren For This Useful Post:
Timuhler (11-14-2009)
Old 11-13-2009, 09:14 PM   #32
KemoSabe
loneframer's Avatar
Then what is it's purpose if it's not to unify the floor and force weight loading to be shared by adjacent joists?
Old 11-13-2009, 09:15 PM   #33
solar guy
naptown CR's Avatar
Why is that?
Bridging would be much stonger if there were a bottom chord tying the joists together.
None of the codes allow a reduction in joist size because of the addition of bridging.
Bridging is used primarily for the STIFFINING of a floor structure by partially transferring the load on one joist onto the two on either side.
If a properly attached bottom cord were added then each row of bridging would become in effect a floor truss and would add to the structure.
Although The theory behind the experiment is valid the lack of a bottom chord invalidates the prescribed system strength.
Old 11-13-2009, 09:16 PM   #34
KemoSabe
loneframer's Avatar
That is exactly what I'm getting at.
Old 11-13-2009, 09:21 PM   #35
KemoSabe
loneframer's Avatar
Which is the point of the test, taken to an extreme. The bridging is the structure in this case. Centerloading the model and transfering the load to adjacent joists. It's really not about the science as much as it is the destruction.
Old 11-13-2009, 09:23 PM   #36
KemoSabe
loneframer's Avatar
Here is 270 lbs.
Old 11-13-2009, 09:23 PM   #37
oldfrt's Avatar
Very impressive!
oldfrt is offline
Old 11-13-2009, 09:25 PM   #38
JonM's Avatar
FYI According to code, bridging is not required until you use a 2 x 14
R502.7.1 Bridging. Joists exceeding a nominal 2 inches by
12 inches (51 mm by 305 mm) shall be supported laterally by solid
blocking, diagonal bridging (wood or metal), or a continuous 1-inchby-
3-inch (25.4 mm by 76 mm) strip nailed across the bottom of joists
perpendicular to joists at intervals not exceeding 8 feet
JonM is offline
Old 11-13-2009, 09:26 PM   #39
BuiltByMAC's Avatar
Trade: Construction
This is a cool experiment, Lone! I'm gonna go off the deep end and say you could drive a Smart or a Metro up onto that thing. you got enough weight plates?
I'd say easy more than 1,000 maybe not more than 2.
Mac
BuiltByMAC is offline
The Following 2 Users Say Thank You to BuiltByMAC For This Useful Post:
loneframer (11-13-2009), wallmaxx (11-14-2009)
Old 11-13-2009, 09:26 PM   #40
Jeff
jkfox624's Avatar
Originally Posted by oldfrt View Post
Very impressive!
Damnit its taking you soooo long to add more weight. I got a kid that wants me to take him hunting in the morning lets speed this up.
jkfox624 is offline
Thermally Modified Wood Live test results naturalwood Decks & Fencing 0 09-17-2009 07:06 PM
Commercial wood framing mckellarman Commercial Construction 2 05-06-2009 06:11 PM
LEED Certified Wood CF Construction Business 6 02-27-2009 04:45 PM
Covered Patio 10 x 10 - Should I wood block? gussy1971 Roofing 1 01-27-2009 06:19 PM
Buckled Wood Floor LNG24 Flooring 2 11-17-2008 11:35 PM
