Fun With Wood X-bridging
Old 11-13-2009, 08:23 PM   #1
KemoSabe
loneframer's Avatar
I had an idea to test wood X-bridging. Here is the setup.
I built a mock floor with 2' 2x10s, used 7/16 OSB for decking, 1x3 firring strips for bridging, stapled with 2" 7/16 crown staples(3-4 per end, as I typically would.) Obviously the floor is severely underbuilt. I nailed a 2x6 "box" to only the end joists to prevent them from just kicking out as weight was applied. You can see in the last pic that the field joists are shorter. The first pic is before the bridging was stapled.
Here is where the fun begins.
1. How much weight can be loaded above only the center joist before catastrophic failure?
2. Any guesses what the point of failure will be?
Fun with wood X-bridging-001.jpg   Fun with wood X-bridging-003.jpg   Fun with wood X-bridging-006.jpg
loneframer is offline
Old 11-13-2009, 08:26 PM   #2
KemoSabe
loneframer's Avatar
Re: Fun With Wood X-bridging
Here is the complete system before applying weight.
Old 11-13-2009, 08:30 PM   #3
Project Manager/Carpenter
TBFGhost's Avatar
Trade: Carpentry/Reno
really...you are gonna make us wait....lol
TBFGhost is offline
Old 11-13-2009, 08:31 PM   #4
More than you'd expect?
Less than you'd hope?
The weight of a Lone Framer?
neolitic is offline
Old 11-13-2009, 08:32 PM   #5
KentWhitten's Avatar
You haven't had a date in awhile have you?
My hat's off to you man, test the "theories". I personally have never been a fan of bridging, but I understand the use.
Salmon Falls Cabinetry
KentWhitten is offline
Old 11-13-2009, 08:33 PM   #6
KemoSabe
loneframer's Avatar
I did get up there to test it out, but I want to see some guesses before I tell you what happened.
Old 11-13-2009, 08:40 PM   #7
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Well you did it. Good for you.
I still say 220 lbs
And the cause of failure is the bottom connections on the outer most bridging pulled away and I hope you got your feet out of the way when it went kaboom.
Gus Dering is online now
Old 11-13-2009, 08:42 PM   #8
KemoSabe
loneframer's Avatar
Had a date with the ballet instructor 2 weeks ago.
I got the idea to test bridging a few days ago, couldn't let it go.
Old 11-13-2009, 08:43 PM   #9
J.C.'s Avatar
I'll say 800 lbs
J.C. is offline
Old 11-13-2009, 08:43 PM   #10
tgeb's Avatar
700 lbs.
And I have no idea the cause of failure, but you should probably refer to it as the point of failure, the weakest link. The cause is, of course the excess weight.
edit: How did you add weight?
www.gebcon.com
tgeb is offline
Old 11-13-2009, 08:44 PM   #11
Warren's Avatar
Trade: framing/remodeling
sawhorse will flip under
Warren is offline
Old 11-13-2009, 08:46 PM   #12
Jeff
jkfox624's Avatar
Trade: master turd burglar
I'm gonna guess it held a loneframer, the ballet instructor, a case of beer but failed when the pizza delivery guy slammed dinner down. If it wasnt for the 3 meat bonanza the ballet instructor had to have it might have held. And it failed at the anchor of the 2x6 first causing a chain reaction and alot of shook up beer.
jkfox624 is offline
The Following User Says Thank You to jkfox624 For This Useful Post:
Inner10 (11-14-2009)
Old 11-13-2009, 08:48 PM   #13
DrewD's Avatar
Trade: Log Home Construction/College Student
I'm not clear what you are exactly trying to test here? Is it the strength of the joist or the X-bridging?
DrewD is offline
Old 11-13-2009, 08:48 PM   #14
KemoSabe
loneframer's Avatar
Thats why I nailed the box on, to pin the end joists from splaying out.
Old 11-13-2009, 08:49 PM   #15
KemoSabe
loneframer's Avatar
Originally Posted by tgeb View Post
700 lbs.
Centered 2 ten pound plates over the center joist, then started adding 50s.
Old 11-13-2009, 08:50 PM   #16
Warren's Avatar
Why not repeat the setup without the bridging? I am guessing thats where this is headed. Quick somebody alert the engineers that they are about to be proven WRONG!!!!
Warren is offline
Old 11-13-2009, 08:52 PM   #17
KemoSabe
loneframer's Avatar
The ability to transfer and share load over the whole assembly using wood bridging.
Old 11-13-2009, 08:53 PM   #18
Gus Dering's Avatar
If you had something tying the horses together it would have held more weight.
I think
Old 11-13-2009, 08:55 PM   #19
KemoSabe
loneframer's Avatar
This is pretty much what it would look like minus the box across the end joists
Old 11-13-2009, 08:56 PM   #20
KemoSabe
loneframer's Avatar
I think
That is what I thought would start the failure, it is not the case.
Thermally Modified Wood Live test results naturalwood Decks & Fencing 0 09-17-2009 07:06 PM
Commercial wood framing mckellarman Commercial Construction 2 05-06-2009 06:11 PM
LEED Certified Wood CF Construction Business 6 02-27-2009 04:45 PM
Covered Patio 10 x 10 - Should I wood block? gussy1971 Roofing 1 01-27-2009 06:19 PM
Buckled Wood Floor LNG24 Flooring 2 11-17-2008 11:35 PM
