Framing Knee Wall With Metal Studs
Old 02-18-2009, 07:47 AM   #1
arawas's Avatar
Hi, I just want your opinions on how to go about building a small knee wall (3' high, 6' long) for an office. The office has metal stud framing so to build a knee wall with wood framing and secure it to the existing wall with metal framing would be difficult. I just want to make sure its sturdy and need some tips on how to go about doing this. Thank you
arawas is offline
Old 02-18-2009, 01:34 PM   #2
BIG D
ribuilder's Avatar
Trade: Carpenter/Builder/Contractor
Re: Framing Knee Wall With Metal Studs
Well....you build the wall with metal studs then....Uh.......not sure why you would need advice on that?? GC? Not trying to be an A-hole, but its a pretty easy procedure that any GC should be able to figure out.
remember what you did right, then do it again!
ribuilder is offline
Old 02-18-2009, 01:41 PM   #3
mickeyco's Avatar
Trade: Squirrel Handler
Why would that be difficult, it might not be up to code, but I can't see how it would be difficult. If you want the wall to be sturdy toss in a couple of X's.
mickeyco is offline
Old 02-18-2009, 02:53 PM   #4
Eater of sins.
ScipioAfricanus's Avatar
Trade: Designer/Drafter Extrordinaire
You can use wood or metal just make sure that you secure the new wall to the existing wall securely. You may have to open the exist. and block between the studs to attach the new to. Also the end of the new wall should be secure to the floor with metal hardware (Simpson) if you use wood 4x4.
There are lots of other techniques as well.
I have saw cut out for 4x4 P.T. end post and poured Rapid-set in the new footing to secure the end.
Depends on how sturdy it should be.
Just don't ask what the price should be.
Andy.
ScipioAfricanus is offline
Old 02-18-2009, 05:52 PM   #5
D.Foster's Avatar
Trade: Carpentry & Remodeling
I agree with RI builder. But i will tell you this, you can put a piece of metal angle in the wall at the un attached end. Bolt to the floor and end stud. Or you if it is a wood framed floor you can run 2 end studs into the floor and attach to floor joists or bridging, i've done that with good results.
As Far as attaching wood studs to metal being difficult, that just comes with experience and blocking
Do what you would do, as if i won't Do anything after you Did It!
D.Foster is offline
The Following User Says Thank You to D.Foster For This Useful Post:
ribuilder (02-18-2009)
Old 02-18-2009, 07:08 PM   #6
Mod / ArchiBuilder
Cole's Avatar
Some of the questions on this forum, are just baffling.
Cole is offline
Old 02-18-2009, 08:03 PM   #7
BIG D
ribuilder's Avatar
Grab bars - studs and spec hollow wall anchors jmfrederick Plumbing 5 12-13-2008 01:12 PM
Framing addition to an existing block wall gajtguy Framing 3 12-08-2008 10:24 PM
Need to frame a wall over concrete wall. joseph Carpentry 3 10-07-2008 08:19 PM
framing against block wall JohnHomeMatters Framing 12 10-01-2008 10:19 PM
Cabinets mounted to metal studs dayspring Finish Carpentry 3 06-14-2007 10:03 PM
