Framing A Header After Removing A Load Bearing Wall
Old 12-13-2006, 09:02 PM   #1
tnt's Avatar
Trade: remodeler
How do you frame the header where it is above the ceiling joists but supports appropriately?
tnt is offline
Old 12-13-2006, 09:51 PM   #2
T-KAT's Avatar
Trade: carpentry
Re: Framing A Header After Removing A Load Bearing Wall
a flush header: engineered lumber (eg:timberstrand) that is at the same width and sits on top of the wall flush with the joists. If joists run perpendicular, you must use joist hangers where they butt in. Also, you must build up jacks (double or tripple studs) on each end beneath the header.
T-KAT is offline
Old 12-13-2006, 10:17 PM   #3
osborn's Avatar
Trade: Licensed Home Improvement Contractor
Dont forget to carry the packpoints to a baem or foundation.
osborn is offline
Load bearing wall or not??? BMAN Remodeling 26 07-28-2008 07:16 PM
Window header 2x6 framing Atlantex Framing 20 11-06-2007 10:55 PM
?? removing a load bearing wall bamaboy Framing 9 11-01-2006 04:30 PM
Load bearing walls EDT Framing 3 06-21-2006 07:20 PM
Load bearing wall pitterpat Framing 11 12-12-2005 06:11 PM
