Framing A Door In A Steel Stud Wall
Old 10-15-2006, 08:17 AM   #1
River Rat Dad's Avatar
Trade: Roofing, siding, framing
At my church there is a need to install a prehung interior door in to a wall with steel studs. No load bearing issues. My thought is to open things up to the nearest studs wider than the door, screw my wood 2X4's to the steel studs and proceed from there with standard wood framing.
Is that the correct plan of action?
River Rat Dad is offline
Old 10-15-2006, 09:53 AM   #2
Peladu's Avatar
Re: Framing A Door In A Steel Stud Wall
Why not use a KD Door.
In many places putting wood into a commercial steel framed wall is against code, usually state.
Steel stud wall is usually 3 5/8" with 5/8" rock on both sides.
You will need an extension jamb, or custom jamb if you use a wood door.
Which also may not be up to fire code, isn't by me.
I would use a KD.
Peladu is offline
Old 10-15-2006, 10:03 AM   #3
My background is residential roofing, siding, etc and the associated wood work. So.... I gotta ask, whats a KD door?
I see your point on the drywall and stud width. Something I hadn't thought about.
Old 10-15-2006, 10:13 AM   #4
Peladu's Avatar
KD is Knock Down.
The door frame will be three pieces; Head and two legs.
Slap it together and then use the tension screws to plumb it.
Two screws on each leg at the feet also to screw into the bottom track.
You will have to do some framing, but you should be able to use the steel stud you cut out to make room.
No need for additional material, and the KD door is already ready for what you need.
Peladu is offline
Old 10-15-2006, 10:19 AM   #5
Old 10-21-2006, 07:37 AM   #6
72chevy4x4's Avatar
I priced a couple of KD's for a church project and they were a bit pricey, over $600 for a 36". We had a couple of commercial metal frames/doors left over from a remodel and used them-they were meant to be installed in new construction and it was quite a job putting them in. Would have loved to use the KD's.
72chevy4x4 is offline
steel stud framing Wensdy Drywall 6 09-19-2007 01:47 AM
estimate/contract for steel stud framing Wensdy Drywall 5 09-19-2007 01:34 AM
Interior wall framing question carlspackler Framing 4 05-16-2007 08:43 PM
Panelization Wall Framing? Wildbillcody Framing 9 12-19-2006 12:17 AM
ideas for wood stud wall attachment to steel "I" beam? durham Construction 9 05-10-2006 06:45 PM
