kramer12
Guest
Posts: n/a
Framing A Door For Non-Load Bearing Wall
Will a 2x4 header for a Non-Load bearing wall meet code in AB Canada?
Re: Framing A Door For Non-Load Bearing Wall
yes, but you need to make sure with your local inspector that it's OK to do this. Almost all will tell you to knock yourself out, but there's always that one guy.
| Load bearing wall or not??? | BMAN | Remodeling | 26 | 07-28-2008 07:16 PM |
| Load Bearing Wall | tsicby | Framing | 5 | 08-22-2007 08:58 PM |
| Framing a header after removing a load bearing wall | tnt | Framing | 2 | 12-13-2006 10:17 PM |
| ?? removing a load bearing wall | bamaboy | Framing | 9 | 11-01-2006 04:30 PM |
| Load bearing wall | pitterpat | Framing | 11 | 12-12-2005 06:11 PM |
