Framing Against Block Wall
Old 10-01-2008, 03:26 AM   #1
JohnHomeMatters's Avatar
When you frame an unfinished basement with block exterior walls, are you concerned with moisture from the block touching the wall studs? If so, do you use treated wood, a gap, or a vapor barrier? (already assumes treated for the bottom plate).
JohnHomeMatters is offline
Old 10-01-2008, 07:24 AM   #2
amanandhisvan's Avatar
Trade: Home Improvements
Send a message via Yahoo to amanandhisvan
Re: Framing Against Block Wall
You can test the basement block wall and poured cement floor with a sheet of foil taped to the wall and to the floor. If condensation appears on the foil after a day or 2 then u have a moisture problem in the basement. I always staple a moisture barrier on the backside of my frame no matter what when I frame out basements. Just use a pressure treated bottom plate on the frame, thats all I have ever used with no problems.
amanandhisvan is offline
Old 10-01-2008, 07:28 AM   #3
genecarp's Avatar
Assuming, normal conditions
1-acq bottom plate
2-thoroughseal or equal masonry sealent /paint
3-DF framing, leave gap, no fir contact with masonry
4-insulate, and rock
genecarp is offline
Old 10-01-2008, 07:33 AM   #4
After addressing all of the moisture
problems.
I set the framing in 1"-1½" from
the masonry.
Treated sole plate only.
neolitic is offline
Old 10-01-2008, 09:47 AM   #5
KentWhitten's Avatar
Well, the code will tell you 1" away(depending on which code you read that is) for all non treated wood. I would just get a treated piece and be done with it. Don't mess with non treated in the basement.
Salmon Falls Cabinetry
KentWhitten is offline
Old 10-01-2008, 10:05 AM   #6
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Hope this helps. Now I'm going to leave and close the door behind me.
http://www.buildingscience.com/docum...lation-systems
We Fix Houses is offline
Old 10-01-2008, 12:49 PM   #7
TimNJ's Avatar
I use treated plate and metal studs 1" of the walls.
TimNJ is offline
Old 10-01-2008, 01:00 PM   #8
I'm thinking of the use of vapor barriers ? Plastic behind the frame wall, unfaced or faced insulation ? I've probably done them every which way over the years.
After reading the Building Science lit, looks like Styrofoam on the block wall, air space, metal studs and no insulation. I'm coming to the conclusion that batts in the wall cavity thermally don't do much except keep the dw at the heated temp instead of 55 deg underground temp.
Old 10-01-2008, 04:54 PM   #9
Thanks to everyone for your responses. This forum is GREAT.
I also found the building science website helpful, if a little thick. I downloaded and saved the article on basement insulation.
Since some of the walls in question are already in place from prior construction, the local building inspector says he'll allow me to slip strips of building felt between the studs and the block.
Old 10-01-2008, 05:41 PM   #10
Here goes...Just trying to help the new guy....
http://forums.jlconline.com/forums/s...sement+framing
Old 10-01-2008, 06:00 PM   #11
DavidC
DavidC's Avatar
Just researched this myself for a client, also went to BuildingScience.com (great website). they list 8 or 9 commonly used methods for finishing a basement and stated weather they approved or not. Only 2 methods ranked approval.
Foam board insulation applied directly to the block, sheetrock directly to the foam board, or
Wood framing with a 1" space between it and the block with kraft faced insulation and no sheetrock.
That was the only choices I offered to my client. FWIW, I would go with the first because I can't believe some future owner or contractor wouldn't see that frame and insulation and think the only thing left is drywall.
Good Luck
www.CookContractingLLC.com
DavidC is offline
Old 10-01-2008, 08:34 PM   #12
Get this...when I was an apprentice I worked a basement job in a newly bought house. The walls were just as you said. The whole basement, walls and ceiling then sprayed with white paint. They threw a carpet down. It was a play room. Saved thousands.
Old 10-01-2008, 10:19 PM   #13
orson's Avatar
Trade: Kitchen & Bath
The method I prefer is to apply foam board insulation(a vapor barrier) against the block, then leave a 1" space to the framing and insulate the stud wall as well. Building Science's first method does not account for condensation on the inside of the vapor barrier and their second method obviously doesnt' apply to a "finished" basement.
orson is offline
removing doorway from solid masonry wall Jamison Remodeling 3 08-15-2008 06:23 PM
Backyard office, retaining, and privacy wall Team Scream Masonry 8 08-02-2007 11:27 PM
framing a door in a steel stud wall River Rat Dad Framing 5 10-21-2006 07:37 AM
Repairing Jog In Wall for Stone Nailbird Windows, Siding and Doors 0 07-20-2006 06:58 PM
Wall framing using pressure treated lumber ChuckEA Carpentry 5 03-03-2006 11:23 PM
