Framing A 60 Ft Wide X 18 Ft High Wall
Hi,
I need to build a partition in a commercial space. The wall will not be used for any shelving or carry any weight besides being drywalled with 1/2 sheetrock. I was thinking of using 2x4's, putting anchors in the concrete floor and bolting down the bottom plates. I was going to build six 10x10 walls and bolt them together to create a 60 x 10 foot wall. Then I was going to build 10x8 walls and place them on top of the 60 x 10 foot walls. I will bolt the top walls to the bottom walls in addtion to nailing. This is in a commercials space. Is there anything I have to watch out for to make this structurally sound and within code. Building is in Chicago. |
Re: Framing A 60 Ft Wide X 18 Ft High Wall
You'd be better off building 18' tall walls x 10' or how ever long you and the help can lift. Stacking walls like that will be very weak IMO. Also to make it worse for you I'd go with 2x6's.
Thom
I'd go with steel studs. You fasten the top and bottom tracks then insert the studs. Weight of the wall isn't an issue then.
I agree with jmic, no knuckle joint. |
I totally agree with Thom. As for building codes in commercial space. YOU NEED TO what the space your separating is being used for. You may need to have special prescriptive fire rating for finishes and penetrations. The wall may also need to extend all the way to the roof deck and fill and space if it butts to a corregated ceiling .
yep, no cutting studs in the middle. and an 18' 2x4....hmmm, not very good IMO. I'd go with at least 2x6. Something like this, metal studs would be a good choice too. I'd put the bottom plate down, figure where the top plate goes and nail it in place, get 2 guys, one on a rolling scaffold, the other cutting and nailing bottom. Or 3 guys total even. It'd go quick.
Trade: Licensed Home Improvement Contractor
I agree with framerman. You dont wont the "hinge factor" by having walls stacked on top of each other. Since itsw commercial I think steel studs are the right way to go.
Definately do not stack walls. You are just creating a "hinge" and there will always be a problem there.
Also, check ahead on what is required of the wall for inspections as suggested. If it is separating two independent "store fronts" it will have to be a firewall, and will be required to entend completely to the roof deck, where it will have to be sealed with firestopping sealant. Anything this tall is a perfect candidate for metal studs, be sure to use a heavy gauge, even if someone recommends flimsy drywall weight materials as being sufficient. They will flex so bad, and the entite wall will vibrate like a drum. |
Trade: Squirrel Handler
I agree with the heavier gauge metal studs, anyone know what a 18' - 2 x 4 stud costs? I know they make them, one wall on my house, which is only a few years old, is balloon framed and it's about 18' to 20' tall. If you're trying to do it on the cheap you could build 8' and 10' foot walls, stagger them and carriage bolt the over hang together to get rid of the hinge.
Some people climb mountains. I take out the trash. But we both do it for the same reason. |
#9 | |
Trade: Rremodeling..finish carpentry, etc
Re: Framing A 60 Ft Wide X 18 Ft High WallQuote:
A bunch of little rabbit turds banding together usually just makes one bigger piece of crap. -Mike Finley |
Mod / ArchiBuilder
Looks like photoshop, but you could have done it in 3d using sketchup.
Tulsa's Leader in Outdoor Living Construction | Facebook | Tulsa Pergola Builder | Tulsa Outdoor Kitchens |
I used PhotoShop and a picture of a pine board, it's not to scale or anything, just for illustrative purposes, faster to draw it than explain it.
yah, I was gonna say, can I have some of that material? Way better than what we get. 2 knots per board, yowsa!
#13 | |
it may be better to stagger the jointed studs-i.e. if using 10's, make one 10' and 8', then alternate 8' and 10'-you'll likely need fireblocks at the 10' mark (double check). call the building inspector first and get his take on this, if you haven't done it already. you may need a building permit since it's commercial space and making mini-walls may not fly. if these are partitions then additional fireblockrequirements may be necessary. 5/8" firecode wallboard at the least-doublewalls may be necessary or even OSB layered w/ two layers firecode wallboard.
good luck |
Trade: Framing Contractor
I'm having trouble as to why it's so hard to frame an 18' high wall whether you use 2x4's or 2x6's. I can't even comprehend why anyone would split this wall between 10' and 8' walls. This makes no sense at all to do this.
Joe Carola |
I passed a new service center under construction-it used very long metal studs for the outer walls-so I'm sure they make them in the length you need. Seems the conversation tended to making partial walls from the initial post. With my limited experience in metal studs, I haven't found longer then 10' studs...but then again I didn't look.
#17 | |
and 10' walls are considerably cheaper than full-length studs. I know they make 18' metal studs but I don't know the price, the last time I used metal studs they weren't much cheaper if at all, plus he might have a hard time finding 18 foot metal studs, I don't think they're a stock item at to many places.
#18 |
how long did it take you to make that mickyco?
#19 | |
#20 | |
There's no way that building 8' and 10' walls is cheaper whether you use metal or would. Your using more material and twice the amount of labor. I can buy 18' 2x4's and 2x6's any day at a lumberyard. 18' 2x4's might take a day or two if they're not in stock, 2x6's always stock item.
Joe Carola Last edited by Joe Carola; 09-10-2007 at 06:36 PM. |
| Does fireplace opening in block wall opening need support? | Square-One | Masonry | 6 | 11-22-2008 02:31 AM |
| Interior wall framing question | carlspackler | Framing | 4 | 05-16-2007 08:43 PM |
| Panelization Wall Framing? | Wildbillcody | Framing | 9 | 12-19-2006 12:17 AM |
| framing a door in a steel stud wall | River Rat Dad | Framing | 5 | 10-21-2006 07:37 AM |
| Does fireplace opening in block wall opening need support? | Square-One | Construction | 1 | 02-28-2006 01:59 AM |
