Faming Roof For Metal Roofing.
Old 09-24-2017, 07:59 PM   #1
RobC's Avatar
Trade: Framing
Hello I am new to the forum and couldnt find the answer I was looking for in the discussions.
I am building a pole barn 70' long by 28' wide the home owner wanted a standard roof with shingles. Until the other day when they changed the plan to wanting an aluminum/ metal roof. I've never dealt with framing a roof for an aluminum roof and I've read a few things that say you need and osb underlayment and some say you don't you just have to nail 2x4 or 1x4 to the top of the rafters going the length of the building to screw the aluminum roof to. Was wonder what is the proper way to frame the roof for an aluminum roof?
If it matters any I am building this in southern Ohio where it gets some snow but not a lot. Thank you for the help.
RobC is offline
Old 09-24-2017, 11:25 PM   #2
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Framing, siding, decks
Rewards Points: 10,554
Re: Faming Roof For Metal Roofing.
Find the product they want and check the directions. My neighbors had a stone coated aluminum shingle roof put on a few months ago. It was installed over another layer of shingles with a hi temp undelayment underneath.
So I would guess an osb deck. (Strictly a guess)
A&E Exteriors is online now
The Following 2 Users Say Thank You to A&E Exteriors For This Useful Post:
CharlieDelta (10-05-2017), Rio (09-24-2017)
Old 09-24-2017, 11:41 PM   #3
Designer/Contractor
Rio's Avatar
Rewards Points: 778
Ditto on the 'find the product directions'. Consider contacting the manufacturer, easy to do lots of times in this instant information web most of us can access.
Also, if there's a building department see if they have any handouts on their requirements/regulations, they can be a wealth of information as well as a PITA.
Rio is online now
Old 09-25-2017, 12:08 AM   #4
Dirtywhiteboy's Avatar
Rewards Points: 7,878
Shouldn't that info be on the plans What about the local code
We can't do skip sheathing any more.
Dirtywhiteboy is offline
Big Shoe (10-14-2017)
Old 09-25-2017, 08:26 AM   #5
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 502
Personally I feel you end up with a better and longer lasting job with a solid deck. Believe it will hold up better to like hail storms. With the cost of 2x material OSB is not much more.
Randy Bush is offline
Old 10-05-2017, 02:56 PM   #6
51carpenter's Avatar
Trade: Carpenter Contractor
Rewards Points: 262
On a pole barn, standard practice around here is to just use perlins instead of sheeting.
Professional wood welder
51carpenter is offline
The Following User Says Thank You to 51carpenter For This Useful Post:
Old 10-05-2017, 03:11 PM   #7
CharlieDelta's Avatar
Trade: Carpentry/Building/Remodeling
Rewards Points: 1,662
Screwed to the perlins is typically how I see new construction pole-barns around here.
CharlieDelta is offline
The Following User Says Thank You to CharlieDelta For This Useful Post:
Old 10-14-2017, 08:18 PM   #8
ktmrider's Avatar
Trade: carpentry
I was always told when you lay over excesting roof you have to lay sleepers down
ktmrider is offline
Old 10-14-2017, 08:31 PM   #9
Big Shoe's Avatar
Rewards Points: 1,720
Same here.
Sent from my iPad using Tapatalk
Expect the Unexpected
Big Shoe is online now
Old 10-14-2017, 08:46 PM   #10
Big Shoe's Avatar
Most if not all building departments don't allow the practice of metal over shingles. Paper or not. My area for sure. South Florida Building Code.
All roofs here are stripped and nailed to current code with 2-3/4 ring shank nails.
The Following 2 Users Say Thank You to Big Shoe For This Useful Post:
A&E Exteriors (10-14-2017), Rio (10-14-2017)
Old 10-27-2017, 10:50 PM   #11
Rewards Points: 262
2-3/4? All we use are 2-3/8 for sheeting.
I agree about stripping the roof first when installing metal on a reroof. Our metal place sells a composite product that you can use as a perlin over shingles, I've never seen it used though. If a homeowner is too cheap to have it done properly I'm not interested. Why put a lifetime product like metal down on top of old shingles? Stripping a roof and replacing any water damaged sheeting and laying down new paper just makes sense.
Randy Bush (10-27-2017)
Old 10-29-2017, 07:42 PM   #12
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 1,836
the plywood is backing for the paper
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is offline
The Following User Says Thank You to parkers5150 For This Useful Post:
A&E Exteriors (10-30-2017)
Old 11-10-2017, 09:58 PM   #13
MeanWeen's Avatar
Trade: City worker
Rewards Points: 24
For that type of build I would screw into the purlins, if for some reason you use sheathing use plywood and not osb. The screws will work loose with osb overtime and the metal will potentially leak.
MeanWeen is offline
Old 11-10-2017, 11:32 PM   #14
Randy Bush's Avatar
Rewards Points: 502
Using the larger 5/16th headed screws make a big differences too in staying tight.
Liberty Roofing on Roof Deck Anderson Roofing 6 05-27-2015 01:19 PM
Flat roof - What roofing system should I use? acro Roofing 10 04-15-2013 05:47 PM
Joe Fusco's roof framing calculator bookmdanno Roofing 2 07-18-2012 03:41 PM
