#41 |
Trade: Framing,Remodeling,General Contractor
Re: Ellipses Made Easy.
Here is the way I do an arch for a cased opening
Lay out the width of your opening your material ![]() Mark the center ![]() Mark your drop and draw a line from that point to the top center ![]() Find the center of that and square down to the center of your opening, ![]() This determines your radius and pivot for scribing your arch ![]() Presto
#42 |
LRG WoodCrafting
That is a radius not an ellipse. Radiuses are simple. But each has its place.
#43 |
Trade: siding
what kind of hammer is that?
Tom |
#44 |
LRG WoodCrafting
Stiletto Tools Ti-Bone Titanium Hammer ?
#45 |
Maker of fine kindling
In case anyone is wondering what an ellipse is;
If you have a triangle, any triangle, keep the base the same size and connect all the dots of the apex created by all the triangles created with the same circumference. Take this ellipse as an example. ![]() The triangle shown has a base of 51 15/16" and two sides of 30" each. Visualize keeping the sum total of those two lines the same as it moves right or left from this point and the trail left behind is the elliptical shape. That is why the two nails and a string trick works. The hidden concept of how to lay out an ellipse to fit any opening is also displayed in that diagram. The key is to locate those two "significant points". Those points are easily found by scribing an arc from the apex across the long axis with a radius of 1/2 the length of the long axis. If you were to tack 3 nails at the corners of that triangle, then snug up some non stretch fishing line around them and lock it in place with a split shot weight. Then pull the top nail and stretch it tight with your pencil. Scribe the arc. This is best done with your larger elliptical openings that are two large for the other jigs described earlier.
Every parent who has walked barefoot into their child's room late at night hates Legos Last edited by Gus Dering; 02-28-2010 at 08:39 PM. |
#46 |
I used to think so.......
Re: Ellipses Made Easy. |
#47 | |
Trade: Carpentry & Remodeling
Re: Ellipses Made Easy.Quote:
Do what you would do, as if i won't Do anything after you Did It! |
| Easy Arches | FRAMERBEN | Framing | 16 | 05-07-2009 06:41 AM |
| Cabinet install made easy | Gus Dering | Finish Carpentry | 40 | 03-06-2009 05:04 PM |
| Easy Mat | AtlRemodeling | Flooring | 2 | 02-28-2009 09:02 PM |
| I Just Noticed That ContractorTalk Made A Top 10 List Last Year | Ed the Roofer | General Discussion | 7 | 02-05-2009 08:38 AM |
| American Made | wallmaxx | Tools & Equipment | 13 | 11-24-2008 06:16 PM |
