#21 | |
Jeff
Trade: master turd burglar
Re: Efficient FramingQuote:
| The Following User Says Thank You to jkfox624 For This Useful Post: | Tinstaafl (11-21-2009) |
#22 | |||
KemoSabe
![]() Quote:
__________________________________ "Walking the fine line between production and perfection" __________________________________ |
| The Following User Says Thank You to loneframer For This Useful Post: | Tinstaafl (11-21-2009) |
#23 |
Well, so much for the guidelines in the op eh?
I personally am in favor of many of the principles of OVE, but it isn't going to work here quite yet due to the seismic activity. Washington state also has strict energy codes, so a lot of the energy details like sheathing the house in foam doesn't calc out. But stacking loads, and minimizing the amount of wood in the wall. Eliminating headers by using strong enough rim, etc etc are all no brainers if it can be made to work well. If we had say 4 plans that we were going to build many times over, I'd go this route. And I really don't think it would end up in a less "bomb proof" house. |
#24 |
solar guy
Trade: solar contracting
don't forget to block all bearing walls at the mid point.
#25 |
I don't understand why that framing technique hasn't been put into practice yet, I've never seen anyone do it. There was another thread on this here http://www.contractortalk.com/f91/gr...-course-47739/ I posted a picture of a green framing mock-up at a trade show I went to.
As a framer you basically have to look at the prints and do what you're told. But I don't understand why builders don't look into this more, it was all engineered 35 years ago, and it's allowed in the building code. It's just got to be designed that way and implemented. |
#26 |
Back in my first energy crisis, in the 70's
I experimented with the ladder leads. No one liked them. Some guys left all interior walls ¾" off the perimeter walls and shoved the drywall behind, used clips or "floating corners" where ther would have been traditional 3 member built up corners. These sucked for base and chair, and often split or cracked. Eventually I thought I invented the California corner. ![]() I have even used 1X6 for these with no apparent problems. As far as leads, a flat 2X6 or 2X8 is the most reasonable compromise solution for me. No jack studs looks like another trim nightmare unless one was happy with drywall jambs and no casing, and I wonder about any R value saving with those big chunks of metal in the corners? I can't bring myself to think about gluing all the trim. ![]() Waiting to hear more from the real experts now.
#27 | |
solar guy
A flat 2x6 of 1x6 would work behind a double stud on an intersecting partition wall and eliminate the base/ chair issue. Running the base /chair with the exterior piece installed first and the partition wall coped to it will eliminate the nailing issue as one piece will capture the other and you always have a bottom plate to prevent pushing too far. |
#28 | |
the drywall if you didn't frame it...... or if you slept since then.
#29 | |
solar guy
Of course geting two people to do thngs the same way is next to impossible. I can't imagine getting everyone to do things the same way. Wait I know Just make it a code
| Framing Documents To Die For | NC2X4 | Framing | 33 | 09-17-2010 11:45 AM |
| Framing Safety | Safety Guy | Tools & Equipment | 3 | 08-13-2009 09:46 PM |
| Structural Framing inside a Brick Building | Builder1962 | Framing | 7 | 06-22-2009 09:08 PM |
| Steel Framing Fasteners | Orca | Construction | 12 | 05-23-2009 08:25 AM |
| Commercial wood framing | mckellarman | Commercial Construction | 2 | 05-06-2009 06:11 PM |
