Drywall Fasteners Or Clips
Old 06-14-2007, 01:23 PM   #1
Biff O'Shay's Avatar
Trade: Custom Builder
There's a good dialogue going on at the Journal of Light Construction's forum about the use of drywall fasteners for inside corners, truss uplift, etc. Adding my two bits, I wouldn't go back to framing by using blocking. What's your experience?
Biff O'Shay is offline
Old 06-15-2007, 10:39 PM   #2
benchmark2323's Avatar
Trade: general contractor
Re: Drywall Fasteners Or Clips
i read something like that somewhere to. the only problem is getting my drywall guys to try something new. you save lumber and labor cost but is it costly for the rockers? that was always my question. cost effectivness. if its costly for them it hits us somewhere.
benchmark2323 is offline
Old 06-23-2007, 07:25 PM   #3
DrewD's Avatar
Trade: Log Home Construction/College Student
Not clear, do sheetrockers screw to the clips or what? Currently I find myself going back in closets and what not peicing in corner nailers with cuttoffs and scraps. It seems there should be an easier method to save time and money.
DrewD is offline
Old 06-23-2007, 09:23 PM   #4
KentWhitten's Avatar
I've called them sheetrock clips, but Simpson calls the drywall stops. They've changed a little since I've seen them. We did one job in WA state that required no framing backing. The sheetrockers used these clips instead. It's cheaper for material, but who knows about time wise. The ones I've seen are shaped like the letter F. You slide the clips onto the end of the sheetrock and there's a little hole in the end of the clip to attach it to the framing member perpendicular to the sheet, if that makes sense to you.
Here's the link for the Simpson catalog. Just look up "DS" or go to page 187.
http://www.strongtie.com/ftp/catalogs/C-2007/C-2007.pdf
KentWhitten is offline
Ceiling Drywall popping and creaking trimco Drywall 12 06-20-2010 09:54 AM
Competitive rates for a drywall crew airborneSGT Drywall 20 06-29-2009 09:19 PM
Lots of questions about drywall and bathrooms nobody Drywall 30 11-27-2008 01:33 PM
Drywall primer peeling problem?? DeanV Painting & Finish Work 23 02-02-2008 11:02 AM
Proper Shower Drywall Fasteners pawned Drywall 13 11-17-2006 10:04 AM
