Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Carpentry > Framing
Old 08-31-2009, 04:40 AM   #1
Trade: residential remodel
dr suess house roof
i'm redoing the roof on a 1940s war box house w/ 2x4 @ 2' o.c. rafters and ship lap sheathing on a 5/12 slope. i thought i was just doing the roofing then discovered the ship lap was rough so started tearing that off. now i've noticed that the rafters are not connected to any of the ceiling joists which are on a completely different lay out. and one section of the the front of the house notches in about 18" so with the roof line, the rafters don't sit on the wall top plate, instead there is a little 7" wall built on top of the top plate that the rafters sit on in that section. there is no connection to hold this little mickey mouse wall in so it is pushing out and the roof is sagging a few inches at the peak in this section... oh, and no ridge board, and no gussets on many of the rafters.
i'd prefer to reframe the entire roof with at least 2x6 rafters and the same 16" o.c. layout as the ceiling joists. but this likely wont happen. and even if i do, how should i secure the platform that the rafters push out on that is raised above the top plate? would running 2x4's across horizontally to the other rafter to mimic a truss system be sufficient? any other suggestions? pardon the pun, but this roof job is a little over my head...
thanks
charlie
wedgwoodchuck is offline   Reply With Quote
Old 08-31-2009, 05:23 AM   #2
Charlie, photos and pics would be 100% helpful with your question.
Morning Wood is offline   Reply With Quote
Old 08-31-2009, 07:57 PM   #3
Trade: Framing
thanks
charlie
if you don't want to re-frame the entire roof, consider putting a structural ridge underneath where existing ridge would be if there was one. i typically use a 2x on the flat (2x4 on a shallow pitch like you have) to go below existing ridge line, then add 2 or 3 lvl's spanning the length of your box. strap existing rafters together before you start jacking the ridge into final position, otherwise you'll just pop individual rafters. in this scenario you're able to leave existing mismatched layout.
if you were to replace the roof then you'd simply framer it up to work with your ceiling layout and spike everything together. when you get to the jog, replace existing ceiling beams with 2x6s and plate the top with a 2x4 should give you 7" rise you're looking for and tie it in for you.
ClemS is offline   Reply With Quote
New roof on an old house knucklehead Roofing 12 06-09-2009 07:13 AM
Ice Problems on a roof J-Peffer Roofing 4 10-01-2008 10:12 AM
Framing of gable roof on existing house. loogout1 Framing 25 06-05-2007 07:14 AM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 21 01-16-2006 02:36 PM
