Trade: Framing Contractor
Dormer Shed Roof, Barrel Roof, CutIn Dormer, Eyebrow Dormer
We've been out of work this last month, so to to keep busy I wrote the following online scripts.
Dormer Shed Roof Rafter Calculator http://sbebuilders.com/tools/geometr..._shed_roof.php This Dormer Shed Roof calculator will return roof framing trigonometry & geometry details for: Dormer Shed Roof Rafter Length Dormer Shed Roof Miter Angle (Rake Cut Angle) Dormer Shed Roof Sleeper Bevel Length Dormer Shed Roof Intercept Run ( Intersection of Dormer Roof and Main Roof) Main Roof Intercept Length (Usefull for laying out Dormer Sleeper that is not Beveled) CutIn Dormer Shed Roof Rafter Calculator http://sbebuilders.com/tools/geometr..._shed_roof.php This CutIn Dormer Shed Roof calculator will return roof framing trigonometry & geometry details for: Dormer Shed Roof Rafter Length Dormer Shed Roof Miter Angle (Rake Cut Angle) Dormer Shed Roof Run Main Roof Rafter Intercept Length Dormer Intersect Length For Lapping Rafters Intersecting Roof Slope Angle Pitch Break Shed Roof Rafter Calculator http://sbebuilders.com/tools/geometr..._shed_roof.php This Pitch Break Shed Roof calculator will return roof framing trigonometry & geometry details for: Pitch Break Shed Roof Rafter Length Pitch Break Shed Roof Miter Angle (Rake Cut Angle) Total Pitch Break Run ( Intersection of Shed Roof and Main Roof) Main Roof Intercept Length Main Roof Run To Intersection of Main Roof And Shed Roof Barrel Roof Dormer Framing Calculator http://www.sbebuilders.com/tools/geo...arrel_roof.php This Barrel Roof Dormer calculator will return roof framing trigonometry & geometry details for: Barrel Roof Semi Major Axis of the Elliptical Valley Footprint Barrel Roof Plan View Run of the Ellipse from the intersection of the barrel roof and main roof. Total Arc Length of Barrel Roof Arc Angle of Purlin Rafter Spacing Cord Length of Purlin Rafter Spacing Ellipse layout points on Main Roof Surface Purlin Rafters cut perpendicular to Roof Surface Purlin Rafter Slope Angle Purlin Rafter Miter Angle Purlin Rafter Saw Blade Bevel Angle Barrel Roof Plan View Rafter Lengths X & Y Points for Elliptical Ploting of the Ellipse on the Main Roof Surface Real Roof Surface plotting points for the plywood roof sheathing Ellipse Valley Sleeper Offset Purlin Rafter Deduction for Ellipse Valley Sleeper Offset Eyebrow Roof Dormer Framing Calculator http://www.sbebuilders.com/tools/geo...oof_dormer.php This Eyebrow Roof Dormer calculator will return roof framing trigonometry & geometry details for: Eyebrow Roof Dormer Semi Major Axis of the Elliptical Valley Footprint Eyebrow Roof Dormer Plan View Run of the Ellipse from the intersection of the eyebrow roof and main roof. Total Arc Length of Eyebrow Roof Dormer Arc Angle of Purlin Rafter Spacing Cord Length of Purlin Rafter Spacing Ellipse layout points on Main Roof Surface Purlin Rafters cut perpendicular to Roof Surface Purlin Rafter Slope Angle Purlin Rafter Miter Angle Purlin Rafter Saw Blade Bevel Angle Eyebrow Roof Dormer Plan View Rafter Lengths X & Y Points for Elliptical Ploting of the Ellipse on the Main Roof Surface Real Roof Surface plotting points for the plywood roof sheathing Ellipse Valley Sleeper Offset Purlin Rafter Deduction for Ellipse Valley Sleeper Offset Sim |
| The Following 10 Users Say Thank You to sbebuilders For This Useful Post: | Brutus (03-21-2012), CanningCustom (04-11-2012), CENTERLINE MV (09-25-2012), ChimneyHill (04-13-2012), Cole (03-21-2012), Jason Y. (04-14-2012), jb4211 (04-11-2012), Kent Whitten (04-11-2012), Timuhler (03-22-2012), wallmaxx (03-22-2012) |
Re: Dormer Shed Roof, Barrel Roof, CutIn Dormer, Eyebrow Dormer
The Eyebrow Roof Dormer Framing Calculator is based on two tangent circles with the same radius. The script takes the total arc length of the eyebrow roof dormer face profile and divides it by the O.C. spacing of the purlin rafters to calculate the layout points on the plan view ellipse and the roof surface ellipse. It then uses these points to draw out an AutoCAD DXF file each time the script is run. You can download and view the DXF file in any CAD program. The script also draws the real roof surface of the eyebrow roof dormer (roof sheathing).
You can also import the DXF file into Google SketchUp and connect the plan view ellipse, main roof surface ellipse rotated to the slope angle of the roof and the eyebrow dormer face profile. Then connect the lines for a 3D image of the Eyebrow Roof Dormer. An Google SketchUp model of the eyebrow dormer created from the DXF is attached below. Sim |
The Barrel Roof Dormer Framing Calculator is based on a right cylinder intersecting with a sloping surface. The script takes the total arc length of the barrel roof dormer face profile and divides it by the O.C. spacing of the purlin rafters to calculate the layout points on the plan view ellipse and the roof surface ellipse. It then uses these points to draw out an AutoCAD DXF file each time the script is run. You can download and view the DXF file in any CAD program. The script also draws the real roof surface of the barrel roof dormer (roof sheathing).
You can also import the DXF file into Google SketchUp and connect the plan view ellipse, main roof surface ellipse rotated to the slope angle of the roof and the barrel dormer face profile. Then connect the lines for a 3D image of the Barrel Roof Dormer. A Google SketchUp model of the barrel roof dormer created from the DXF file is attached below. Sim |
The Dormer Shed Roof Rafter Calculator prints out something like like.
Dormer Shed Roof Calculations Calculations are rounded to the nearest 1/16 inch Main Roof Pitch = 8:12 Main Roof Pitch Angle = 33.69007° Main Rafter HAP = 0'-7 13/16'' Main Roof Sheathing Thickness = 0'-0 1/2'' Main Roof Rafter Material Depth = 0'-9 1/2'' Main Roof Rafter Plumb Height = 0'-11 7/16'' Main Run = 2'-8 9/16'' Dormer & Main Roof Plate Line Difference = 0'-0'' Dormer Roof Pitch = 3:12 Dormer Roof Pitch Angle = 14.03624° Dormer Rafter HAP = 0'-8 7/16'' Dormer Run = 4'-6'' Dormer Sleeper Material Thickness = 0'-1 1/2'' Dormer Roof Rafter Material Depth = 0'-9 1/2'' Dormer Roof Rafter Plumb Height = 0'-9 13/16'' Dormer Rafter Length = 7'-0 13/16'' Dormer Sleeper Bevel Length = 0'-4 1/2'' Dormer Miter Cut Angle = 19.65382° Dormer Rafter Miter Cut Length = 2'-4 1/4'' Dormer Intercept Run = 7'-2 9/16'' Main Roof Slope Intercept Length = 2'-10 15/16'' Dormer Rafter Length To Main Roof Sheathing Without Sleeper = 7'-5 1/4'' C1 = 75.96376° C2 = 70.34618° C = 146.30993° A = 19.65382° a = 54.00000 Using the Law of Sines c = ( a × sin( C ) ) ÷ sin( A) c = Dormer Rafter Length A = Main Roof Pitch Angle - Dormer Roof Pitch Angle C = 90° - Dormer Roof Pitch Angle + (90° - (Main Roof Pitch Angle - Dormer Roof Pitch Angle)) Dormer Rafter Length = Dormer Run × sin(90° - Dormer Roof Pitch Angle + ( 90° - (Main Roof Pitch Angle - Dormer Roof Pitch Angle))) ÷ sin(Main Roof Pitch Angle - Dormer Roof Pitch Angle)) Dormer Rafter Length = 54.00 × sin(90° - 33.69007° + (90° - (33.69007° - 14.03624°))) ÷ sin(33.69007° - 14.03624° ) Dormer Rafter Length = 54.00 × sin(146.30993) ÷ sin(19.65382 )= 89.05908 or Dormer Altitude = sin(Dormer Roof Pitch Angle) * Dormer Run Dormer Altitude Run = Dormer Altitude ÷ tan(Dormer Roof Pitch Angle) Dormer Miter Cut Angle = Main Roof Pitch Angle - Dormer Roof Pitch Angle Main Altitude Run = Dormer Altitude ÷ tan(Dormer Miter Cut Angle) Dormer Rafter Length = Dormer Altitude Run + Main Altitude Run Main Intercept Run = (Dormer Rafter Length * cos( Dormer Roof Pitch Angle)) - Dormer Run Dormer Altitude = 1'-1 1/8'' Dormer Altitude Run = 4'-4 1/2'' Dormer Miter Cut Angle = 19.65382° Main Altitude Run = 3'-0 3/4'' Dormer Rafter Length To Main Roof Sheathing Without Sleeper = 7'-5 1/4'' Main Intercept Run = 2'-8 1/2'' |
The CutIn Dormer Shed Roof Rafter Calculator prints out something like this.
CutIn Dormer Shed Roof Calculations Calculations are rounded to the nearest 1/16 inch Main Roof Pitch = 8:12 Main Roof Pitch Angle = 33.69007° Main Roof Rafter Material Depth = 0'-9 1/2'' Main Roof Rafter Plumb Height = 0'-11 7/16'' Dormer Plate Line Height Above Main Roof = 3'-0'' Dormer Roof Pitch = 3:12 Dormer Roof Pitch Angle = 14.03624° Dormer Rafter HAP = 0'-6 7/8'' Dormer Run = 8'-6 7/8'' Dormer Roof Rafter Material Depth = 0'-7 1/2'' Dormer Roof Rafter Plumb Height = 0'-7 3/4'' Dormer Rafter Length = 8'-10 1/16'' Dormer Miter Cut Angle = 19.65382° Dormer Rafter Miter Cut Length = 2'-4 1/4'' Main Roof Rafter Intercept Length = 10'-3 5/8'' Intersecting Roof Slope Angle = 22.61986° |
The Pitch Break Shed Roof Rafter Calculator prints out something like this.
Pitch Break Shed Roof Calculations Calculations are rounded to the nearest 1/16 inch Main Roof Pitch = 8:12 Main Roof Pitch Angle = 33.69007° Main Rafter HAP = 0'-7 13/16'' Main Roof Rafter Material Depth = 0'-9 1/2'' Main Roof Rafter Plumb Height = 0'-11 7/16'' Main Pitch Run = 8'-1 5/16'' Shed Roof Plate Line Difference = 0'-0'' Shed Roof Pitch = 4:12 Shed Roof Pitch Angle = 18.43495° Shed Rafter HAP = 0'-8 3/16'' Shed Roof Run = 8'-0'' Shed Roof Rafter Material Depth = 0'-9 1/2'' Shed Roof Rafter Plumb Height = 0'-10 1/16'' Shed Roof Rafter Length = 16'-11 3/4'' Intersect Miter Cut Angle = 15.25512° Intersect Miter Cut Length = 3'-0 1/8'' Total Pitch Break Run = 16'-1 5/16'' Main Roof Intercept Length = 9'-8 15/16'' |
Gen. Contractor
Trade: Residential small commercial
That's pretty cool. I only understand the shed roof one though
law of sines!
"slow makes smooth, smooth makes fast" |
| The Following 2 Users Say Thank You to Ninjaframer For This Useful Post: | CanningCustom (04-11-2012), FramingPro (09-29-2012) |
#8 | |
Re: Dormer Shed Roof, Barrel Roof, CutIn Dormer, Eyebrow DormerQuote:
I was able to build a model but the way in which I figured it was tedious and not practical for a full scale roof. Thanks for this. |
Trade: general contractor
I agree ^, this is the first time I've seen this thread. You did a great thing!
I've built eyebrow windows before and I could have used your information. Keep up the great work and hopefully you will get back to work soon |
This should be a sticky; my first time seeing this thread as well.
"The man who says it can't be done, shouldn't interrupt the man doing it." Jon The man who will use his skill and constructive imagination to see how much he can give for a dollar instead of how little he can give for a dollar is bound to succeed. Henry Ford |
| The Following User Says Thank You to jb4211 For This Useful Post: | Andrew6127 (09-26-2012) |
Time well spent and very informative . Great job
Trade: GC/Remodeling
I'll second that
Great work Sim... Thanks for sharing it
-Steve 'The more you explain it, the more I don't understand it.' - Mark Twain |
Resident Pain
Incredible break down Sim, very much appreciated. Some one please "sticky" this!
#14 | |
This is the first time I've seen anybody breakdown the eyebrow dormer mathematically,I was able to calculate the front and the remaining ribs of the roof,but it required so much math I didn't even want to mess with the elliptical sleeper boards. |
| The Following User Says Thank You to mike86 For This Useful Post: | CanningCustom (04-13-2012) |
really nice that someone shares their efforts, and there's definitely a lot of effort into those designs.
Trade: Remodel/Glazing
Thanks a bunch. It is nice to see folks sharing knowledge.
Your emergency does not constitute a problem with my Constitution. |
Trade: carpenter/sub contractor
Great info I am sure it will be very helpful. Thanks for taking the time to post!!
#18 |
Thanks for the comments.
Here's a link to a Google Sketchup plugin I just wrote. It draws outs roof framing tetrahedrons and roof framing kernels. http://www.sbebuilders.com/pdf/RoofFraming.zip Just unzip it in the Google SketchUp \Plugins directory. The file structure should look something like this. C:\Program Files\Google\Google SketchUp 8\Plugins\RoofFraming.rb C:\Program Files\Google\Google SketchUp 8\Plugins\RoofFraming\plan_angle.rb C:\Program Files\Google\Google SketchUp 8\Plugins\RoofFraming\draw_angle_dim.rb C:\Program Files\Google\Google SketchUp 8\Plugins\RoofFraming\interior.png C:\Program Files\Google\Google SketchUp 8\Plugins\RoofFraming\exterior.png Sim |
#19 | |
#20 | |
| Torch down(flat roof) leaks BAD...can you give advice ASAP? | Detail Guy | Roofing | 22 | 01-05-2013 05:42 PM |
| Roof repair, what to do? | offshorehs | Roofing | 15 | 02-19-2012 10:25 PM |
| Roof Framer's Bible Framing A Bay Window Roof | sbebuilders | Framing | 20 | 04-21-2011 11:22 PM |
| Ideas for venting a shed roof.... | kermmonk | Roofing | 5 | 08-16-2006 08:40 PM |
| Dormer Vs. New Roof | Baghuan | Construction | 13 | 02-01-2006 12:22 PM |
